    [Plugin] Color by Z (Updated August 27th, 2009)
    54 Posts 21 Posters 57.0k Views 21 Watching
      Works now! ๐Ÿ˜‰ โ˜€
      • H
        Heven7_floor
        Thanks Chris , your creation is still very cool and fantastic, ๐Ÿ‘ ๐Ÿ‘ my model is look better now
        • K
          kwistenbiebel
          @pixero said:
          I've experimented with something similar in the past but gave up because I didnt find a way of getting a smooth gradient. Colors are applied to every polygon and not the UV values. Also it resulted in a "LOT" of color swatches in the material browser. Is there a way of applying colors but not having them added to the materials? And is there a way of using the UV values to get a smooth gradient?
          Yes, that is exactly what the new SU 7 feature 'Make unique texture' does. It makes one big gradient texture to project on your geometry.
          If you go to the other plugin thread by chris (Random Color Select), he demonstrates this feauture in his proof of concept video in the first post.
          Since I don't use SU 7 (various reasons, the handicapped component browser is one of them), I truely miss that 'make texture unique' option. ๐Ÿ˜•
            Daniel S
            SU7 has an option called Combine Textures (The Combine Textures menu item combines separate textures on adjacent co-planar faces into a single larger texture. This feature also, optionally, removes edges between co-planar faces to reduce the polygon count for the model as a whole. Context-click on multiple selected parallel faces, with at least one face having a texture, and select Combine Textures to create a texture which is unique to that set of faces.)
            This is a great tool, but it will be more usefull if it`s extended into curved surfaces. This Color by Z or the Tools On Surface are examples of plugins that will be benefit.
            Daniel S
            • PixeroP
              Pixero
              I still don't get a smooth gradient. ๐Ÿ˜•
              • Chris FullmerC
                The way to get a smooth gradient is to make a material in photoshop that is a big smooth gradient. Then bring it into your model and turn it so it is standing vertical next to your model. Set it to "Projected". THen select all of the land for it to be applied to and apply it to your model. You'll get all faces nicely mapped with a single image.
                I just don't know how to do all that in one clean ruby unfortunately. So painting each face its own material is the closest I can get for now ๐Ÿ˜„
                And with the combine textures bit....theres a HUGE downside to that. While it works great in that video I did, it only works on planar faces. So to get it to work on something like this, I would need to create a flat version of my terrain mesh, then apply all my materials to it, then run combine textures, then re-apply the new textuire onto my non-flattened terrain. So thats not terribly smooth either.
                But it is what it is. Hopefully this script will be helpful for someone ๐Ÿ˜„
                • PixeroP
                  Pixero
                  The script idea I played with was to apply different colors based on slope and the side projected gradient doesnt work for that. ๐Ÿ˜ž
                  Texturing is another area in SU we could wish for improvements in.
                  • Chris FullmerC
                    Ahh, tis true! If you wanted to do slopes as gradients, then you're out of luck. The only possible workaround I can think of is to use the subdivide scrip to subdivide faces into a tone of smaller faces. Then apply a single color to each face. Then somehow turn the whole thing into a single material and re-apply it to the pre-subdivided mesh. But I have a feeling that is 1. beyond the scope of Ruby and 2. probably just not very efficient and would be better suited for another 3d modeler? Maybe someone like Al's team could write an entirely separate app that reads the SU model and does all that work with the UV and gradients, and then sticks the model back into SU.
                    • JClementsJ
                      JClements
                      Hi Chris, again.
                      Other ideas:
                      1. enable the script to "remember" the settings last used during the same SU session.
                      2. save the settings in to a library (each "style" would be saved a record in a text file).
                      3. call up the color wheel dialog
                      And OMG, is Mt Hood going following in the foot steps of Mt St. Helens?
                      EDIT: 14 Feb 09
                      Here is the skp , Chris. It may be that I didn't input the same values for the two terrains. It is geolocated, it will take you back to Mt. Hood in GE.
                      Mt Hood gone Active Vulcanic AGAIN.skp
                      • JClementsJ
                        JClements
                        Chris, .skp was added to my previous posting.
                        • Chris FullmerC
                          Cool, thanks John. I see it now. There is some overlapping geometry that I couldn't see in the image. That accounts for the coloration working the way it is. Thanks John!
                          • X
                            xrok1
                            maybe a better direction for this would be to create a plug that creates 'real' gradient textures based on the height of geo in a scene. they could then be projected manually or auto matically based on a plane that is created with a similiar prcess to a section plane?
                            โ€œThere are three classes of people: those who see. Those who see when they are shown. Those who do not see.โ€
                            • Chris FullmerC
                              THats a nice arrow their John. It took me a while to find it on the image, but once I clicked on the image to expand it, it all made sense. Very nice. And your mountain looks great too! It works out really nice with white at the top that changes quickly into a brown and works its way down to give a nice snow capped mountain appearance ๐Ÿ˜„
                              • X
                                xrok1
                                Daniel S
                                how can you get to this tool? i can't find it, tried RC menu?
                                • Chris FullmerC
                                  Here's a video on using combine textures.
                                  [flash=727,635:2s0w7uxd]http://www.chrisfullmer.com/chrisfullmer/forums/combine_textures.swf[/flash:2s0w7uxd]
                                  • X
                                    xrok1
                                    thats sweet. thank you very much for that. coincidentally you just answer a another question, i was trying to figure out how to make a painted wall texture for skindigo, but i couldn't figure out how get SK to UV map surfaces with just white material on it so i could apply displacement. now after watching your vid i figure i can just make unique my material then it should be uv'ed.
                                    thank you
                                    • L
                                      linea
                                      Good idea Chris, thanks
                                      • urgenU
                                        urgen
                                        ...nice idea Chris! ๐Ÿ‘ ๐Ÿ˜„
                                        --pupil forever...------
                                        • soloS
                                          Cool and thanks, this should come in handy.
                                          http://img13.imageshack.us/img13/6384/colorfulkk4.jpg
                                          • JClementsJ
                                            JClements
                                            It never occurred to me to project a gradient color onto a terrain, great idea.
                                            However, I do project gradient transparency along with gradient color onto a single surface to make arrow-shaped objects and "swooshes" that indicate direction or motion.
                                            Mt Hood gone Active Vulcanic AGAIN 2.skp
                                            Gradient Arrow.skp
                                            • 2 / 3
