    [Plugin] Zorro2 (beta)
    314 Posts 154 Posters 446.6k Views 154 Watching
    • B
      bellwells
      Dale, when I click on a section cut and select the "Slice Model at Section" nothing happens. I've read the tutorial, but I can't figure out what I'm doing wrong. I only have Zorro2.rb in my Plugins folder so it can't be a conflict with the original one.
      What a great feature this section option is!! I can't wait to get it working.
      Ron
      • Chris FullmerC
        After you do that Ron, try deleting the section plane. Your model should stay cut in half. I guess that is the desired functionality.
          AcesHigh
          @whaat said:
          @aceshigh said:
          I dont know what is happening but Zorro 2 is constantly failing to make any cuts here.
          in fact, sometimes it ABSOLUTELY refuses to cut anything... even simple models, be them grouped or completely exploded. It starts creating the line, but I click the other end of the line but the line doesnt goes away... it like if I was not clicking.
          Open the Ruby Console Window and tell me what error message you are getting. Thanks
          Error: #<ArgumentError: Points are not planar>
          C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/Zorro2.rb:273:in add_face' C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/Zorro2.rb:273:in cut_geometry'
          C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/Zorro2.rb:107:in `onLButtonUp'
          • B
            bellwells
            Hi Chris, I tried that but...no luck. I zorro sliced a cube, activated the section cut tool, selected "Slice Model at Section" and erased said section cut, but nothing. I'll keep fiddling around.
            Edit: When I erase the section cut the model goes back to being "whole". The section cut always stays normal to the model surface not the Zorro cut.
            Ron
            • B
              bellwells
              The Slice Section feature does not work for me. I've even deleted and reinstalled.....no worky. Am I the only one with this problem?
              Ron
              • Chris FullmerC
                Have you tried removing all other plugins except the new zorro?
                • B
                  bellwells
                  I hadn't thought to do this, but this didn't work either. Funny, I've never had any problems whatsoever installing and using plugins. I'm obviously doing something wrong.
                  I've invoked the slice-model option with the section cut plane inside and outside the model. I've tried grouping.....I've tried it with both drinking beer and not drinking beer....I've tried everything. Argggg...
                  Ron
                  • Chris FullmerC
                    So the option to slice the model (or whatever its called) does show up though, right? Try opening the ruby console and the running the slice. See if any error messages come up in the ruby console. If they do, post them here. BTW, what version of SU are you using this on?
                    • BurkhardB
                      Burkhard
                      [quote="bellwells"].. I zorro sliced a cube, activated the section cut tool, selected "Slice Model at Section" and erased said section cut, but nothing. quote]
                      Try the simple way...leave Zorro and use just the Sketchup sectionplane. Select the plane after the end position and run the script. For me it has nothing to do with zorro 😉
                      http://www.ia-plus.de
                      • Chris FullmerC
                        Ahh, I second what burkhaard says. I don't start zorro first or anything. just make a section plane, then right click on it to find the slice option.
                        • BurkhardB
                          Burkhard
                          ...and it works also with some beers 😉
                          • B
                            bellwells
                            Oh, I see. I was thinking you could "zorro" the model in any plane desired and then R-click "slice section" to achieve a section cut normal to that plane.
                            Apparently this script does NOT work with my beer.
                            Edit: I changed beer and everything is working fine....Thanks.
                            Ron
                              AcesHigh
                              dont any of you guys know whats causing this?
                              • W
                                Whaat
                                I have a theory. Can you post the SKP file please?
                                  AcesHigh
                                  here it is
                                  hivecity.skp
                                    AcesHigh
                                    hey Whaat, any thought on the matter? Thanks
                                    • W
                                      Whaat
                                      Yes, your scene scale is too big. I won't get into the details, but the plugin will fail if you are using a huge scene scale. Your scene is about 10km across!
                                        AcesHigh
                                        yup, it was supposed to be a sci-fi city.
                                        well, so you suggest that I scale down it. Haha, I cant even begin to understand whats the difference, to the PLUGIN, on the scale of the scene. Thanks for the help!
                                        • free agentF
                                          free agent
                                          hey thanx for this, really speeds up the process of making a roof with hard modeled roof tiles the only suggestion i could make is that it explodes and groups everything it cuts through (at least in the case of similar components), because at present it is making separate unique components out of the indidual components it cuts through, increaseing the amount of components intances dramatically, and slowing down the drawing.
                                          i then have to go in select all similar components, invert selection, group those, explode this groups contents and purge unused components, to get my component instances from 400 back to 1.
                                          any thoughts
                                          http://i167.photobucket.com/albums/u143/FreeAgent84/bug.gif
                                          • B
                                            blugarero
                                            AWESOME PLUGIN. Especially when used with section cut plane...
                                            Before I would have to explode all geometry and create a plane... then intersect with model, then erase everything I didn't need. On complex models this would take too long so I gave up. Now it took a minute at most on that same model.
                                            Thank you!
                                            • 15
                                            • 16
                                            • 3 / 16
