    How do you move vertices?
    24 Posts 4 Posters 1.8k Views 4 Watching
      todd burch
      p1 = Geom;;Point3d.new
      [Point3d(0, 0, 0)]
      > p1
      Point3d(0, 0, 0)
      > p2 = Geom;;Point3d.new
      [Point3d(0, 0, 0)]
      > p3 = Geom;;Point3d.new
      [Point3d(0, 0, 0)]
      > p4 = Geom;;Point3d.new
      Point3d(0, 0, 0)
      > p2 = [10,0,0]
      [10, 0, 0]
      > p3 = [10,10,0]
      [10, 10, 0]
      > p4 = [0,10,0]
      [0, 10, 0]
      > am = Sketchup.active_model
      #<Sketchup;;Model;0x19935d64>
      > am.entities.add_face(p1,p2,p3,p4)
      #<Sketchup;;Face;0x199358c8>
      # select one of the edges at this point
      > v = Sketchup.active_model.selection[0].start
      #<Sketchup;;Vertex;0x19935710>
      # a vector transform, 5 in +x direction and 5 in +y direction
      > t = Geom;;Transformation.new([ 5,5,0]) ;
      #<Geom;;Transformation;0x19935508>
      > am.entities.transform_entities(t,v)
      true
        todd burch
        In simple terms, (terms good enough to code by), think of a "transformation" as the "equation" or "specification" for how to move (translate) an entity.
        A transformation can define a translation (a move) or a rotation or a scaling.
        There is a fairly recent thread here that Scott L. posted that went through the whole group/component nest translation thingy. And yes, you have to apply all those transformations when working with groups/components and nested groups/components.
        • Chris FullmerC Offline
          Thanks for stepping in Todd. Here's what I am wanting to do.
          I have a rectangular face that is not lying flat, its slanted (like a sphere, one of the faces that is pointing at an odd angle for example). So I pushpull the face a distance. I know how to isolate the push/pulled face and its normal. I would like to scale it using its normal as the Z direction, and then scale it equally on the X and Y. Does that make any sense? I just want to scale the face so it stays flat (well, flat to its original off kilter angle - so flat to its normal).
          I started to set it up last night, and I got it to scale, but not how I wanted, and its the "normal" info that I'm not taking into account. That would be of interest to me. Thanks Todd and anyone else who joins in,
            todd burch
            Is this what you mean?
            require 'sketchup.rb'
            am = Sketchup.active_model ;
            # Make a face, and tilt it some
            p1 = Geom;;Point3d.new(0,0,0) ;
            p2 = Geom;;Point3d.new(10,0,5) ;
            p3 = Geom;;Point3d.new(10,10,5) ;
            p4 = Geom;;Point3d.new(0,10,0) ;
            am.entities.add_face(p1,p2,p3,p4) ;
            # find the face just created
            # call it "oface", for "original face"
            oface = nil ;
            am.entities.each {|ent| if ent.is_a? Sketchup;;Face then oface = ent ; break; end }
            # point it "up" so it won't be inside out or upside down
            oface.reverse! if oface.normal.z < 0 ;
            # save the orignal face's normal before we extrude it
            normal = oface.normal ;
            # extrude it
            oface.pushpull(10) ;
            # find the opposite face with the same normal as the original face
            # call it "nface" for "new face"
            nface = nil ;
            	next if !(ent.is_a? Sketchup;;Face)
            	next if (oface==ent) ;
            	next if (normal != ent.normal)
            	nface = ent ;
            	break
            # nface is the face we want to scale.
            # Find it's center point
            cp = Geom;;Point3d.new( nface.bounds.center ) ;
            # A uniform scaling transformation about a point
            scale_t = Geom;;Transformation.scaling( cp, 0.5) ;
            am.entities.transform_entities(scale_t, nface) ;
            (edited: forgot to add the normal check in the loop to find the opposite face)
              Thanks Todd. I'll dig into this when I get back from work today.
              One thing, when you created the face, you then searched for it afterwards:
              oface = nil ;
              Why not not use the return value of add_face? Is it not reliable?
              oface = am.entities.add_face(p1,p2,p3,p4) ;
                todd burch
                That's how I originally coded it, but I changed it and don't remember why now. You are right, that would have been simpler.
                  Hey Todd, the example you gave me worked great (as expected)! I am wondering if there is an easier way to located the push/pulled face though. I tried
                  new_face = orig_face.pushpull length
                  And I was hoping thay would return the name of the new face, but it doesn't. I think it returns a true/false status or something.
                  So is there a built in way to get the name of the newly created face? In my actual model, I have lots of faces that will be parallel, so just comparing normals does not quite do it in practice. So if there is no built in way to get the name of the newface, I'll play around with how to compare vertices or edges of the original face to the push/pulled distance and see if I can find the face that way.
                  Thanks so much Todd! (and thanks for letting me piggy back on your transformation thread Thom!)
                    hm.. if you do a pushpull on a face, and do not create a copy of the starting face, you still have a reference to it.
                    sel = Sketchup.active_model.selection
                    someFace = sel[0] # Assuming it's a face
                    sel.clear
                    someFace.pushpull(100)
                    sel.add someFace # someFace still refers to your original face
                    If you create a copy of the starting face I can see it being a problem though.
                    someFace.pushpull(100, true)
                    I suppose you could traverse the connected faces of your original face.
                      Oh yes, I did not specify. I do need to make a copy of the face when I push.pull. I think I have some ideas of how to find that face using the distance I pushpulled and vertices or edges locations or something. I was hoping there was an easier way though πŸ˜„
                      ok, question about when and why to create a method. So lets say I do write code that does the above for me. Is that an example of something that might be nice to write as its own method that I could call anytime I wanted to find the newly created push.pulled face? Because for example, I have 6 different ways that I might create that face, so there are 6 places in my code that I might have to write out the test to find the name of the new face. Is that a good reason to write it as its own method? So instead of re-writing it, I can just call the method, pass the original face name and the pushpull distance into the method and make it return the new face name?
                        Yes. That's when you want a method. You don't want code doing the same thing multiple places. You'll eventually forget to update all occurrences.
                          An idea to find the new push pulled face:
                          # get a face
                          myFace = Sketchup.active_model.selection[0]
                          # build an array of the currently connected faces
                          connected_faces = []
                          myFace.edges.each { |edge| connected_faces += edge.faces }
                          connected_faces.uniq!
                          # push/pull
                          myFace.pushpull 100, true
                          # find the new faces connected to our face
                          new_faces = []
                          myFace.edges.each { |edge| new_faces += edge.faces }
                          new_faces.uniq!
                          # eliminate the ones we had before
                          side_faces = new_faces - connected_faces
                          # find the new push/pulled face
                          opposite_face = get_opposite_face(side_faces[0], myFace)
                          def get_opposite_face(connected_face, original_face)
                            # We take one of the side faces,
                            # loop through all it's edges,
                            # until we find a face that has the same normal
                            # as our original face.
                            connected_face].edges.each { |edge|
                              edge.faces.each { |face|
                                if face != original_face && (face.normal == original_face.normal || face.normal.reverse == original_face.normal)
                                    return face
                            return nil # method failed
                          Note: code not tested.
                            todd burch
                            Chris and Thom, I think I've posted maybe 6 times (in different forums) how to reliably get the new face. The process boils down to using set arithmetic on arrays.
                            • Basically, take an inventory of your active_entities.
                            • Perform the push pull. In the simplest form of push pull, you get a minimum of 4 new faces and 6 new edges (the case when you extrude a triangle), perhaps thousands of new faces and edges.
                            • Subtract the initial inventory of entities from the now current active_entities and that result is all the new geometry created.
                              Now, you can weed through the result to find the geo you want to work with.
                            If you can find it via distance, good luck, and I hope you don't run into a pre-existing face at the same distance. I would like to see .pushpull return an array of newly created edges and faces, with the opposite face listed first.
                            @Chris - a terminology thing: we're not dealing with "names" of faces. We're dealing with Object References. No, there is no built in method. When you .pushpull, you will ONLY EVER get one face with the same normal.
                            Todd
                              Thanks Todd.
                              Seems that I wasn't too far of.
                              I second this.
                                That would be great.
                                That makes sense to compare and subtract, then find the leftover entity with the normal that matches the original face. That did not cross my mind to search that way. Thanks guys! I'll post it when I get it written (probably after work or during lunch).
                                Oops, I'll work on my terminology πŸ˜„
                                  ok, here is the code I put together based on your guys comments. It gets all geometry before pushpulling, then all geometry after pushpulling and does a subtraction, leavin just the new stuff. Then searches through that for a face with a normal == to the original face's normal. Thanks for the help on this. Now I can do a uniform scale on the new face. So I'll incorporate it all into my greeble script later today I hope. Thanks!
                                  model = Sketchup.active_model
                                  entities = model.selection
                                  # Initialize my Arrays
                                  existing_ents = []
                                  current_ents = []
                                  new_ents = []
                                  # Define existing entities and then push.pull my face
                                  existing_ents = entities[0].all_connected
                                  entities[0].pushpull( 100, true)
                                  # Define all entities after the push.pull
                                  current_ents = entities[0].all_connected
                                  # Define new entities through subtraction
                                  new_ents = current_ents - existing_ents
                                  # Loop through each new entity to find the faces,
                                  # then find just the face with its normal matching the original face
                                  # Send a quick text to the Ruby console and paint the face to show it worked
                                  new_ents.each do |ent|
                                  	if ent.typename == ( "Face" )
                                  		if ent.normal == entities[0].normal
                                  			puts "Found it!  The Object Reference is " + ent.to_s
                                  			ent.material = [0,0,0]
                                  This script requires having a single face selected when the script is run.
                                    todd burch
                                    For your playing around with stuff like this, (and I encourage it), here's a tip. Instead of this:
                                    Do this, and it's less typing:
                                    entity = model.selection[0]
                                    existing_ents = entity.all_connected
                                    That way, you get rid of the array reference early and no more qualifying every use with [0].
                                    For short stuff (shorter than this), I just use the console.
                                      Ahh, very helpful, thanks again Todd,
