How do you move vertices?
I can't work out how to move vertices around via scripting. I can't find any methods to the
Vertexclass. Nor withvertex.position. (I thought maybevertex.position.x=would work, but no.)So how do you modify existing entities?
You an use the 2 methods of the Sketchup::Entitiesclass called transform_entitiesand transform_by_vectors. They both accept vertices.
Transformation is taking me a long time to figure out. Is there a resource that everyone uses to learn how to transform things? I assumed it would be a little easier than it is......
I second this. The documentation entry on the transformation class didn't make me much wiser.
Let's discuss it. What do you want to know?
What I'm trying to do specificity at the moment is trying to move a vertex to a new 3D location.
Then at a later point I will try to rotate an object (group/component or selection of entities) around an axis. For instance, you have a component and a line that goes through that component at some position. How would you rotate the component with the pivot point being that line?
What happens when you modify entities within nested groups or components, will you need to take into account the nested rotation and scaling?
From the doc on the Transformation class:
Second, and foremost, the transformation class can be used to apply transformations on geometry, such as a move (called a translation),
Then the entry on translation:
The translation method is used to create a transformation that does translation.I don't understand much more of that.
p1 = Geom;;Point3d.new [Point3d(0, 0, 0)] > p1 Point3d(0, 0, 0) > p2 = Geom;;Point3d.new [Point3d(0, 0, 0)] > p3 = Geom;;Point3d.new [Point3d(0, 0, 0)] > p4 = Geom;;Point3d.new Point3d(0, 0, 0) > p2 = [10,0,0] [10, 0, 0] > p3 = [10,10,0] [10, 10, 0] > p4 = [0,10,0] [0, 10, 0] > am = Sketchup.active_model #<Sketchup;;Model;0x19935d64> > am.entities.add_face(p1,p2,p3,p4) #<Sketchup;;Face;0x199358c8> # # select one of the edges at this point # > v = Sketchup.active_model.selection[0].start #<Sketchup;;Vertex;0x19935710> # # a vector transform, 5 in +x direction and 5 in +y direction # > t = Geom;;Transformation.new([ 5,5,0]) ; #<Geom;;Transformation;0x19935508> > am.entities.transform_entities(t,v) true -
In simple terms, (terms good enough to code by), think of a "transformation" as the "equation" or "specification" for how to move (translate) an entity.
A transformation can define a translation (a move) or a rotation or a scaling.
There is a fairly recent thread here that Scott L. posted that went through the whole group/component nest translation thingy. And yes, you have to apply all those transformations when working with groups/components and nested groups/components.
Thanks for stepping in Todd. Here's what I am wanting to do.
I have a rectangular face that is not lying flat, its slanted (like a sphere, one of the faces that is pointing at an odd angle for example). So I pushpull the face a distance. I know how to isolate the push/pulled face and its normal. I would like to scale it using its normal as the Z direction, and then scale it equally on the X and Y. Does that make any sense? I just want to scale the face so it stays flat (well, flat to its original off kilter angle - so flat to its normal).
I started to set it up last night, and I got it to scale, but not how I wanted, and its the "normal" info that I'm not taking into account. That would be of interest to me. Thanks Todd and anyone else who joins in,
Is this what you mean?
require 'sketchup.rb' am = Sketchup.active_model ; # Make a face, and tilt it some p1 = Geom;;Point3d.new(0,0,0) ; p2 = Geom;;Point3d.new(10,0,5) ; p3 = Geom;;Point3d.new(10,10,5) ; p4 = Geom;;Point3d.new(0,10,0) ; am.entities.add_face(p1,p2,p3,p4) ; # find the face just created # call it "oface", for "original face" oface = nil ; am.entities.each {|ent| if ent.is_a? Sketchup;;Face then oface = ent ; break; end } # point it "up" so it won't be inside out or upside down oface.reverse! if oface.normal.z < 0 ; # save the orignal face's normal before we extrude it normal = oface.normal ; # extrude it oface.pushpull(10) ; # find the opposite face with the same normal as the original face # call it "nface" for "new face" nface = nil ; am.entities.each {|ent| next if !(ent.is_a? Sketchup;;Face) next if (oface==ent) ; next if (normal != ent.normal) nface = ent ; break } # nface is the face we want to scale. # Find it's center point cp = Geom;;Point3d.new( nface.bounds.center ) ; # A uniform scaling transformation about a point scale_t = Geom;;Transformation.scaling( cp, 0.5) ; am.entities.transform_entities(scale_t, nface) ;(edited: forgot to add the normal check in the loop to find the opposite face)
Thanks Todd. I'll dig into this when I get back from work today.
One thing, when you created the face, you then searched for it afterwards:
am.entities.add_face(p1,p2,p3,p4) ; # find the face just created # call it "oface", for "original face" oface = nil ; am.entities.each {|ent| if ent.is_a? Sketchup;;Face then oface = ent ; break; end }Why not not use the return value of add_face? Is it not reliable?
oface = am.entities.add_face(p1,p2,p3,p4) ; -
That's how I originally coded it, but I changed it and don't remember why now. You are right, that would have been simpler.
Hey Todd, the example you gave me worked great (as expected)! I am wondering if there is an easier way to located the push/pulled face though. I tried
new_face = orig_face.pushpull length
And I was hoping thay would return the name of the new face, but it doesn't. I think it returns a true/false status or something.
So is there a built in way to get the name of the newly created face? In my actual model, I have lots of faces that will be parallel, so just comparing normals does not quite do it in practice. So if there is no built in way to get the name of the newface, I'll play around with how to compare vertices or edges of the original face to the push/pulled distance and see if I can find the face that way.
Thanks so much Todd! (and thanks for letting me piggy back on your transformation thread Thom!)
hm.. if you do a pushpull on a face, and do not create a copy of the starting face, you still have a reference to it.
sel = Sketchup.active_model.selection someFace = sel[0] # Assuming it's a face sel.clear someFace.pushpull(100) sel.add someFace # someFace still refers to your original faceIf you create a copy of the starting face I can see it being a problem though.
someFace.pushpull(100, true)I suppose you could traverse the connected faces of your original face.
Oh yes, I did not specify. I do need to make a copy of the face when I push.pull. I think I have some ideas of how to find that face using the distance I pushpulled and vertices or edges locations or something. I was hoping there was an easier way though
ok, question about when and why to create a method. So lets say I do write code that does the above for me. Is that an example of something that might be nice to write as its own method that I could call anytime I wanted to find the newly created push.pulled face? Because for example, I have 6 different ways that I might create that face, so there are 6 places in my code that I might have to write out the test to find the name of the new face. Is that a good reason to write it as its own method? So instead of re-writing it, I can just call the method, pass the original face name and the pushpull distance into the method and make it return the new face name?
Yes. That's when you want a method. You don't want code doing the same thing multiple places. You'll eventually forget to update all occurrences.
An idea to find the new push pulled face:
# get a face myFace = Sketchup.active_model.selection[0] # build an array of the currently connected faces connected_faces = [] myFace.edges.each { |edge| connected_faces += edge.faces } connected_faces.uniq! # push/pull myFace.pushpull 100, true # find the new faces connected to our face new_faces = [] myFace.edges.each { |edge| new_faces += edge.faces } new_faces.uniq! # eliminate the ones we had before side_faces = new_faces - connected_faces # find the new push/pulled face opposite_face = get_opposite_face(side_faces[0], myFace) # find the opposite face def get_opposite_face(connected_face, original_face) # We take one of the side faces, # loop through all it's edges, # until we find a face that has the same normal # as our original face. connected_face].edges.each { |edge| edge.faces.each { |face| if face != original_face && (face.normal == original_face.normal || face.normal.reverse == original_face.normal) return face end } } return nil # method failed endNote: code not tested.
Chris and Thom, I think I've posted maybe 6 times (in different forums) how to reliably get the new face. The process boils down to using set arithmetic on arrays.
- Basically, take an inventory of your active_entities.
- Perform the push pull. In the simplest form of push pull, you get a minimum of 4 new faces and 6 new edges (the case when you extrude a triangle), perhaps thousands of new faces and edges.
- Subtract the initial inventory of entities from the now current active_entities and that result is all the new geometry created.
Now, you can weed through the result to find the geo you want to work with.
If you can find it via distance, good luck, and I hope you don't run into a pre-existing face at the same distance. I would like to see .pushpull return an array of newly created edges and faces, with the opposite face listed first.
@Chris - a terminology thing: we're not dealing with "names" of faces. We're dealing with Object References. No, there is no built in method. When you .pushpull, you will ONLY EVER get one face with the same normal.
Todd
Thanks Todd.
I second this.
