    โš ๏ธ Important | Libfredo 15.8b introduces important bugfixes for Fredo's Extensions Update
    [Plugin] FollowMe and keep (v0.04 update 20090210)
    223 Posts 79 Posters 181.7k Views 79 Watching
      You can add a hori line at the end of curve to avoid it.
      So we must make that ๐Ÿ˜‰ (a vertical is more easy to draw in the space)
      (bending effect on the right on the smooth view is just perspective !)
      Works but curious method ๐Ÿ’š
      Another thing : measure of lengh of the "rectangle facet" must be less than the radius of the curve else auto intersections become! ๐Ÿ˜‰
        0.02 is the version, I had believed that was a parameter ๐Ÿ˜„
        But sorry seems you have uploaded a false version! I have always the same result and not your result !
        • W Offline
          wikii
          ๐Ÿ˜ณ
          I have uploaded a wrong package.
          Sorry for that,please download v0.02 again.
          • X Offline
            xrok1
            an option for the sweep to start at the beginning of the line no matter where the profile is drawn would make this perfect. maybe a checkbox for start at path or start at profile. then maybe a normal(size of path) or distance from(size*distance from path) instead of the construction point. it seems a pain to make a construction point?
            โ€œThere are three classes of people: those who see. Those who see when they are shown. Those who do not see.โ€
            • X Offline
              xrok1
              hey ๐Ÿ˜ฎ , i just noticed the
              follow me rotate
              script is written by wikii too! any chance the two will be combined ๐Ÿ˜„
                Now it's perfect! ๐Ÿ˜Ž
                Can you make a version where the plug is in the Draw menu, because I have no more place on the Plugins menu! ๐Ÿ˜ž
                (Click on image if scroll bars exist)
                  gata
                  I have some paths where both versions of the script failed. On the bright side, they will be good for future testing.
                  Edit: More fun things to play with (done on the figure 8 path):
                  1. different results if the path is welded verses non-welded.
                  2. if the edges of the extruding face are also selected, the extrusion face is reversed and the extrusion location changes.
                  Follow Me boo-boo.skp
                    bianhai
                    Thanks Wikii!
                    ๐Ÿ‘
                    FAK.skp
                    • gillesG Offline
                      gilles
                      I've been waiting for this tool for a while.
                      Thanks.
                      But there is something wrong:
                      It does not really follow the path, see attached files.
                      And sometimes SU quite.
                      OSX 10.4 SU6
                      FAK.skp
                      • Jean-FrancoJ Offline
                        Jean-Franco
                        Hi, that was also my remark from yesterday. Have a look at the beginning of this thread.
                        You have to place a construction point at the origin of your curved path. Then it works.
                        This is equivalent to scene 2 in the WiKi's file FAK.skp
                        Jean-Franco
                          boilingsnow
                          Thanks.
                          OSX 10.4 SU6
                          I think it will be no problem if you make the path in the middle of the profile instead at one side of it.
                          • W Offline
                            wikii
                            download v0.03
                            all problems in your skp is solved.
                            • W Offline
                              wikii
                              Thanks.
                              OSX 10.4 SU6
                              Add a construciont point at the start piont of path and select it before running.
                                bellwells
                                I think this would be a great improvement. Regardless, this is a tremendous script, wikii. Thank you so very much!!
                                Ron
                                  gata
                                  Good job. There was a big improvement in just a few hours.
                                  Using the same SKP file with the face position in the same locations, some of the face profiles extruded on the wrong side and one relocated.
                                  In all cases the path, construction point, face+edges were selected to run the plugin.
                                  Paths that intersect will most likely need to be done in sections. Plugins have limited mind-reading abilities, but version .03 at least was able to do extrude something along the entire complex path in one step.
                                  (These two paths upset the last plugin attempt to correct the follow me twist.)
                                    Is there a conceptual difference with the Profile Builder by Whaat ?
                                      PB uses the FollowMe tool to create the profiles and therefore suffers from twisting. This one if a custom implmentation that prevents twisting.
                                        Thx for precision ๐Ÿ˜Ž
                                        • W Offline
                                          wikii
                                          Try to reverse face before using FAK.
                                            dtrarch
                                            Wikii
                                            Any chance of adding an align face/profile perpendicular to endpoint fcn?
                                            Maybe just a separate script would do or does one exist that will pick face and align by selecting the endpoint of the path??
                                            dtr
                                            • 11
                                            • 12
                                            • 9 / 12
