    [Plugin] FollowMe and keep (v0.04 update 20090210)
    223 Posts 79 Posters 220.5k Views 79 Watching
      dtrarch
      Wiki Thank you Thank you ๐Ÿ˜
      WOW this is the real missing link in SU fixed at last.
      This worked perfect right out of the box.
      For Architects developing roadways on non level topography this is a must have tool and for the handrail up sweeping stairs this will be a life saver.
      I have begged, offered bribes, and even bathed every day to hopefully have someone put this together with no luck until the Wizard of Code delivered.
      An icon would be a helpful addition if not too troubling to add.
      Just brilliant and generous.
      Thanks more than I can properly express.
      dtr Architect
      PERFECT.png[/attachment]
      • W
        wikii
        You can add a hori line at the end of curve to avoid it.
        So we must make that ๐Ÿ˜‰
        Works but curious method ๐Ÿ’š
        0.02 provide perfect ending and autosmooth.
        • E
          Ecuadorian
          This should have been a tool in SU from the very beginning, thank you wikii!
          -Miguel Lescano
            So we must make that ๐Ÿ˜‰ (a vertical is more easy to draw in the space)
            (bending effect on the right on the smooth view is just perspective !)
            Another thing : measure of lengh of the "rectangle facet" must be less than the radius of the curve else auto intersections become! ๐Ÿ˜‰
              0.02 is the version, I had believed that was a parameter ๐Ÿ˜„
              But sorry seems you have uploaded a false version! I have always the same result and not your result !
              • W
                wikii
                ๐Ÿ˜ณ
                I have uploaded a wrong package.
                Sorry for that,please download v0.02 again.
                • X
                  xrok1
                  an option for the sweep to start at the beginning of the line no matter where the profile is drawn would make this perfect. maybe a checkbox for start at path or start at profile. then maybe a normal(size of path) or distance from(size*distance from path) instead of the construction point. it seems a pain to make a construction point?
                  โ€œThere are three classes of people: those who see. Those who see when they are shown. Those who do not see.โ€
                  • X
                    xrok1
                    hey ๐Ÿ˜ฎ , i just noticed the
                    follow me rotate
                    script is written by wikii too! any chance the two will be combined ๐Ÿ˜„
                      Now it's perfect! ๐Ÿ˜Ž
                      Can you make a version where the plug is in the Draw menu, because I have no more place on the Plugins menu! ๐Ÿ˜ž
                      (Click on image if scroll bars exist)
                      • G
                        gata
                        I have some paths where both versions of the script failed. On the bright side, they will be good for future testing.
                        Edit: More fun things to play with (done on the figure 8 path):
                        1. different results if the path is welded verses non-welded.
                        2. if the edges of the extruding face are also selected, the extrusion face is reversed and the extrusion location changes.
                        Follow Me boo-boo.skp
                        • B
                          bianhai
                          Thanks Wikii!
                          ๐Ÿ‘
                          FAK.skp
                          • gillesG
                            gilles
                            I've been waiting for this tool for a while.
                            Thanks.
                            But there is something wrong:
                            It does not really follow the path, see attached files.
                            And sometimes SU quite.
                            OSX 10.4 SU6
                            FAK.skp
                            • Jean-FrancoJ
                              Jean-Franco
                              Hi, that was also my remark from yesterday. Have a look at the beginning of this thread.
                              You have to place a construction point at the origin of your curved path. Then it works.
                              This is equivalent to scene 2 in the WiKi's file FAK.skp
                              Jean-Franco
                              • B
                                boilingsnow
                                Thanks.
                                OSX 10.4 SU6
                                I think it will be no problem if you make the path in the middle of the profile instead at one side of it.
                                • W
                                  wikii
                                  download v0.03
                                  all problems in your skp is solved.
                                  • W
                                    wikii
                                    Thanks.
                                    OSX 10.4 SU6
                                    Add a construciont point at the start piont of path and select it before running.
                                    • B
                                      bellwells
                                      I think this would be a great improvement. Regardless, this is a tremendous script, wikii. Thank you so very much!!
                                      Ron
                                      • G
                                        gata
                                        Good job. There was a big improvement in just a few hours.
                                        Using the same SKP file with the face position in the same locations, some of the face profiles extruded on the wrong side and one relocated.
                                        In all cases the path, construction point, face+edges were selected to run the plugin.
                                        Paths that intersect will most likely need to be done in sections. Plugins have limited mind-reading abilities, but version .03 at least was able to do extrude something along the entire complex path in one step.
                                        (These two paths upset the last plugin attempt to correct the follow me twist.)
                                          Is there a conceptual difference with the Profile Builder by Whaat ?
                                            PB uses the FollowMe tool to create the profiles and therefore suffers from twisting. This one if a custom implmentation that prevents twisting.
                                            • 11
                                            • 12
                                            • 2 / 12
