Syncro 4d
extensions
5 Posts 4 Posters 2.6k Views 4 Watching
    aadbuild
    HI all I was wondering if any one has tried or is using Scncro 4d?
    Basically syncro 4d is an add on that uses a 3d model and syncronises it with Microsoft project style gant chart etc.
    I downloaded it and installed it. It is suposed to have plug in that auto loads into SU6. but for some reason it didnt. I was able to import the SU6 model with several components but I could not assign them to resources. Basically I need the Ruby.
    Q has any one given it a try?
    Q does any one have the ruby?
    Q is it worth a crack?
    Every building designed can be affordable & buildable, to help we built PlusSpec; VDC & BIM for Sketchup
    https://www.plusspec.com
      cmd
      I havent tried it out but I think you can find the plugin for SketchUp here - http://www.synchroltd.com/news/NA-20081218220733
      Which version of Synchro did you download? Professional or Constructor?
      CMD
      • CMD
        linea
        Aadbuild
        If you have time, a review of synchro would be useful.
          aadbuild
          Hi all I downloaded the professional version. I imported the model and a Microsoft project sheet. I can see some real potential in the program and I am looking forward to the latest version which comes out in 2 weeks. The current versions don't appear to take all the components in individually from SU 7 but the update is rectifying this. When I get it up and going I will post my results. If anyone else is using Synchro and has some quick start tips they would be much appreciated. A tip for any one who does download Synchro before the update. when you install push on custom install and you will find the SU install details there. Good luck I look forward to hearing from fellow users
            Sekta
            Thought I wouild bump this one, I am interetsed to hear if anyone is using Synchro. I had a play with it about a year ago and am keen to have another look as I am finding clients starting to talk about 4D potential. I have sent a number of emails to Synchro over in the UK but have had no response, I hope they are not a recession victim 😲 😲
            Sek
