    [Plugin]SketchyPhysics3 alpha.
    83 Posts 20 Posters 21.6k Views 20 Watching
      l.frisken
      I've just thought of a great feature that i reckon would be great to include in an update or at least sketchy physics four, having some kind of interactivity with the water plane, like being able to make a paddle steamer, with the paddles actually being able to provide propulsion or propellers being able to provide propulsion. i'm sure that accurately reproducing the propeller effect in sketchyphysics would be hard, but maybe something like starting off making paddles?
      oh yeah and another feature that would be great along side that would be sliders to control boyancy or something so you could make a submarine... wouldn't that be great?
        CPhillips
        Working paddles are probably not possible even in sp4. But I think you could do a sub using buoyancy and magnets.
        • N Offline
          notareal
          Great news. Hope you could keep SU6 support with final version.
          Welcome to try [Thea Render](http://www.thearender.com/), Thea support | [kerkythea.net](http://www.kerkythea.net/) -team member
            Click Draw
            Hi Chris,
            Looks very cool. Thanks! I just installed and wondering how to activate magnets and new features? It's probably right in front of me 😞
            Cheers,
            Jeff
            Have I mentioned how much of a laugh I get out of some of the Signatures on here!
              Some tests in perspective! πŸ˜’ 😎 β˜€
                CPhillips
                @click draw said:
                Hi Chris,
                Cheers,
                Jeff
                Open up the UI and select an object and you should see the magnet settings.
                  Click Draw
                  Thanks Chris,
                  I downloaded the SKP file in the magnet thread and played with the settings. Very very cool! You script writers really don't get enough credit for your work. I guess it won't be long before you all band together and write your own Modelling program...eh? πŸ˜„
                  This forum is the best!!!
                  Jeff
                    CPhillips
                    I created new topics for Gears, Joystick and Buoyancy and updated the feature list with pointers to the new topics.
                    I still have to do Controllers and a Misc topic. Controllers is going to be a really long one and I probably wont get it done until tomorrow.
                      Platypus5
                      You are a hero. And by the way, the video music was EPIC
                      • W Offline
                        Wacov
                        Brilliant!
                        I'm excited about the possibilities with the joystick emulation... but are the physics components in this release? I can't find the option. Keep up the good work
                          t.larcombe
                          i have come across some interesting bugs and have no idea why they are happening. Using this in sketchup 7, i can't seem to use some of the prebuilt components. when using hinges etc the component does not travel in the same orientation as the hinge slider etc.
                          Any ideas on where i might be going wrong?
                            Bryden
                            Very nice Chris
                            I really like the new features πŸ˜‰
                            I made a slider controled truster out of 2 boxes held together with ball joints
                            and a slider controled magnet πŸ˜„
                            Magnet Truster
                              CPhillips
                              Post a model that shows the problem and I'll take a look.
                                Platypus5
                                I have found a bug: In this model, the thing is supposed to "explode" like a bomb. It works in sketchyphysics 2, but in the SP3 Alpha, not only does it fail to detonate, but a blank control bar appears. If you touch the control bar, you get an error message.
                                Link to model: http://sketchup.google.com/3dwarehouse/details?mid=920ecad0ac545b53266076a1a3bfa166
                                Also, could you give us instructions on how to use the rubyscript duplicate objects?
                                  CPhillips
                                  As I said in the Magnets thread, the Sp2 style magnets dont work in this version. The dup option is broken at the moment.
                                    Platypus5
                                    It does not use magnets. It uses spazzed out hinges.
                                      Platypus5
                                      Sometimes, if you don't fill in the inspector values exactly right, an error message will pop up every time you try to access the joint in question. This effect can occur both before, during, and after a simulation.
                                        CPhillips
                                        @platypus5 said:
                                        It does not use magnets. It uses spazzed out hinges.[/quote]
                                        Ah, I see the problem. It will fixed in next version.
                                          CPhillips
                                          Yeah, there is a lot that can go wrong there. I'll see if I can fix it.
                                            CPhillips
                                            @bryden said:
                                            Very nice Chris
                                            [attachment=0:1pt9feos]<!-- ia0 -->truster_test.skp<!-- ia0 -->[/attachment:1pt9feos]
                                            Thats cool! I discovered the same thing last night by connecting two spheres with a slider. πŸ˜„ I am working on a hover car powered by magnet thrusters.
                                            • 1 / 5
