    [Plugin] follow me rotate
    211 Posts 79 Posters 274.1k Views 79 Watching
      @cad addict said:
      It doesn't seem to work with straight paths. If the path I use is a curve it works, if it is a straight line it doesn't do anything. Is that how it is supposed to work?
      Yes.
      @wikii said:
      The path must be a curve which is constructed with several segments!
        boilingsnow
        @cad addict said:
        you can divide a line into many segments and then weld them again.
        It works!
          Jim57
          I love what this does!
          While it worked fine for me at first, now I'm having troubles. If anyone has fixes, let me know, I need this script!
          -sometimes the script reverses the follow line. It starts from one side, but when I select the script it flips to the other.
          -sometimes the script does not work, even after welding my follow lines religiously
          -sometimes all the script does is place a 2" long construction line on the underside of the face, one segment's length away from the face.
          -I just tried again. The first time, it didn't work. The second try, it placed the 2" construction line on the underside and reversed the path. The third try, it worked great, with the path coming from an offcenter construction point. The following five times, it shifted the path from the construction line to the center of the face and, other than that, worked.
          -not a bug, but a feature request: as I posted earlier, scaling and rotation are per segment of the follow path, not over the whole length. It might be more intuitive and controllable if they were measured over the whole path.
          Again I will repeat, I always weld my follow lines or use unexploded curves. I'm using FAR on a Mac and some posters feel it is Win only— Is this the issue? SU seems buggier as I use FAR, though this may be coincidence, or confusing the cause and effect.
          Thanks for any assistance,
          Jim
            Jim57
            I checked the Ruby Console at some point during my last experiments, and here's what I was getting:
            fError: #<ArgumentError: Cannot create unit vector from zero length vector>
            (eval):340:in intersect_line_plane' (eval):340:in wikii_push_pull'
            (eval):339:in collect' (eval):339:in wikii_push_pull'
            (eval):319:in each_index' (eval):319:in wikii_push_pull'
            (eval):141
            (eval):340:in `call'
            (eval):340
            Error: #<TypeError: can't convert Symbol into String>
            I don't seem to be able to reset the Console without quitting and restarting Sketchup, so it's hard to tell at what stage things were going wrong.
              sepo
              This video does not work for me. I have only black screen.
                Click Draw
                Hi Miguel,
                Great tutorial. I noticed some quick shots of your tools which don't look familiar. Would you mind posting a screen shot of your tools so I can see what ones you have that I don't?
                Thanks,
                Jeff
                Have I mentioned how much of a laugh I get out of some of the Signatures on here!
                  "...in response to this tutorial found on the web:"
                  I wish I could see your video. I've tried the plugin but it doesn't yield the same thing I showed in the tutorial. I did the tutorial without the plugin because of that and because I was asked to demonstrate a manual way of drawing that.
                  • Jean-FrancoJ Offline
                    Jean-Franco
                    +1 with Sepo !
                    Jean-Franco
                    • E Offline
                      Ecuadorian
                      Hello, Dave. I'm sorry, I'll be more careful with the wording in the future.
                      I liked your tutorial because it is actually the best way to do it in SketchUp without having to install any additional scripts.
                      It's just that I really think that Follow Me Rotate is an extremely cool script thas not everybody is aware of, so I wanted to share with your readers an even faster way to do the same balaustre.
                      Here's the Youtube link for those who can't see it embedded: http://www.youtube.com/watch?v=0eBIQC2Cgps
                      (Weird, it's working fine in Google Chrome...)
                      And sorry for my bad English, I learned it through Pink Floyd songs...
                      -------------------UPDATE--------------
                      Video does not work in Internet Explorer 6, but works fine in Firefox 2 and Google Chrome.
                      -Miguel Lescano
                      • E Offline
                        Ecuadorian
                        Thank you, very much, wikii. This tool is extremely useful and solves one of my main gripes about SketchUp.
                        I created a video tutorial for twisted balaustres/legs...
                        [flash=425,344:10ax4kg1]http://www.youtube.com/v/0eBIQC2Cgps&hl=en&fs=1file=http://www.youtube.com/watch?v=0eBIQC2Cgps[/flash:10ax4kg1]
                        http://finewoodworking.taunton.com/item/6095/doin-the-twist
                        I hope you see the BIG difference your script makes. Without Follow Me Rotate, it is like being in the stone age!
                        By the way, I discovered that if I don't deselect the line after dividing it and make sure it has been properly divided, sometimes Follow Me Rotate will extrude in the opposite direction.
                        Thank you again.
                        And thanks to Simon Bonnet for the tip on posting Youtube videos here.
                        ---------------------18:08 31/01/2009 UPDATE--------------
                        I've just discovered that the video shows only a black screen in Internet Explorer 6, but works fine in Firefox 2 and Google Chrome.
                        -Miguel Lescano
                          I appreciate you wanting to show the readers a faster way but you need to provide the links for the plugins or they're not in any better position.
                          • E Offline
                            Ecuadorian
                            Sure, I posted the links in the Youtube video description. click on "(more info)" to show it. I'll copy the description here:
                            Today I read this tutorial for doing a "twisted leg": http://finewoodworking.taunton.com/item/6095/doin-the-twist
                            But I remembered that in the SketchUp Community Forums there are free tools that can do the same thing in a snap. So I decided to record a video tutorial.
                            You'll need the SCF Power Toolbar, which includes the "Join edges" tool by Rick Wilson:
                            http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=14770&st=0&sk=t&sd=a&hilit=powertoolbar
                            And the "Follow me rotate" script, by wikii:
                            http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=13014&st=0&sk=t&sd=a
                            In this video I did a counter-clockwise twist. To do it clockwise, simple input a negative value in the "Rotate" field of the Follow And Rotate script.
                            Remember to check that the line was properly divided before using the "Join Edges" tool; if you don't, the Follow And Rotate tool might not work properly.
                            Tutorial created with Camstudio, a free and open-source excellent little piece of software, and subtitles added in Windows Movie Maker.
                            -Miguel Lescano
                              Now I see. It's all hidden normally.
                              Thanks.
                                sorgesu
                                I thought this plug-in would be useful in finally solving the missing "sweep" tool, so I tried it. More specifically, I showed this one before, trying to make a squared handrail on a spiral staircase. Using follow me doesn't work because it curves the form so that the top isn't parallel with the ground. For this spiral stair case the steps are rotated 30 degrees so I tried the ruby with a 30 degree input. Totally didn't work. I tried various different inputs and I finally found one that visually, was "good enough". The input was -3 degrees.
                                Can you take a look and let me know if there is a better number and if I there should be some relationship that can always be used to figure out what angle to use?
                                Even if not, this saves just a ton of time as is and it is quite adequate for this job too! Thank so much.
                                SpiralStairRail.skp
                                Susan Sorger
                                Former Seller Hand Rendered Entourage
                                Former Canadian Authorized Training Centre, SketchUp
                                • W Offline
                                  wikii
                                  Another script still in development can do followme and keep the profile from rolling.
                                  Left part of the first image is followme ,right part is follow_me_and_keep .
                                  In the second image ,the Long Corridor (exclude columns) is built by follow_me_and_keep after one time running.
                                    sorgesu
                                    Fantastic! Can't wait.
                                    Susan Sorger
                                      Sounds fantastic! That would be something needed so long!
                                      • E Offline
                                        Ecuadorian
                                        Follow_me_and_keep should be a big hit among fans of the Great Wall, and will certainly help a lot when modeling roads. Keep up the excellent work, wikii!
                                        Mrs. Susan, for your specific case, the screw1_5.rb script works well, too. Unlike FollowMeRotate, with screw1_5.rb you have to select both the face and its borders, and it only works around the blue axis, so before using it you have to center your stair in the origin. You can find it here:
                                        http://www.crai.archi.fr/RubyLibraryDepot/Ruby/EM/screw1_5.rb
                                        The "first end" and "second end" that you are required to enter are just required to determine a differential in height, so, irrespective of where you click, the shape will always be created around the blue axis.
                                        -Miguel Lescano
                                        • N Offline
                                          notareal
                                          A must have tool!
                                          • boofredlayB Offline
                                            boofredlay
                                            I am looking forward to it.
                                            • 11
                                            • 4 / 11
