    Indigo for dummies
    28 Posts 14 Posters 4.0k Views 14 Watching
    • soloS Offline
      Maybe a new thread would be better as the title to this suggests folks can learn Indigo with me.
      Start a new one with a heading like 'lets play in a warehouse' or something.
      I wanna try that warehouse using Brazil (my new toy)
        chango70
        Beautiful! Care to talk us through the settings?
        • soloS Offline
          Thanks Chango70.
          I used the 'sun/sky' setting in environment, with shadows set as per model. Actually come think about it the model should have my indigo setting on it.
          If not, I added bump from texture (no seperate map), used the simple UI to reduce roughness and reflection (even though in hindsight it should be lower)
          um, that's about it, unbiased engines do not take much to render well, why they intimidated me in the past is beyond me.
          • EarthMoverE Offline
            EarthMover
            Pete, Brazil, eh? Are you using it with max? I've heard good things about 2.0. It's supposed to be as fast as vray. It's almost funny mentioning Brazil in an Indigo thread. hehe
            Content Creator at Skapeup
            • soloS Offline
              Adam, I'm also learning Rhino, so I am learniang brazil for Rhino. I never knew there was a Brazil for max....hmmm, now you got me distracted. ๐Ÿ˜•
                EarthMover
                Sorry bout that. Seems you're a lot like me. Always learning 10 new things at once....stuck in an endless revolving obsession. ๐Ÿ˜’
                • N Offline
                  nomeradona
                  i must say from what you have posted indigo is also good ah... hows the rendering speed comparing with other rendering engines? like vraysu, podium, vue?? i have not tried it yet, but as what you said is fairly easy to catch up.. i will try it pete.
                  • soloS Offline
                    Adam, we must be brothers as I'm just like you, I was a landscape designer and always learning new things,trying to learn too many things at once and ending up knowing a little about everything but not enough to do anything.(not saying you cannot do anything)
                    Nomeradona, I am not sure if you have used an unbiased engine yet, I have only seen your Podium and Vray renders. anyway unbiased engines are very forgiving and if it was not for it's horrendous render speeds they would be king. You can model poop and blindly adjust your settings to Hellen keller values and end up with a great render, as long as you are willing to wait 9 months for it to render.
                    So as far as speed goes, Podium is king (but lacks some elementary features like displacement and refraction), Vue a second on exteriors but sadly a third for interiors (but then again Vue is the landscape champ)
                    But this is January, imagine what will be available this time next year?
                      dacad
                      Hi Solo
                      Very nice first try ๐Ÿ˜„ But i think that 1 hour is too much time for a render that size with that geometry and just the sunlight. Did you turn off the low cpu priority in the advanced settings?
                      I really like unbiased renders (be carefull they can be addictive) because, as you said, they the're very easy to set up. The only problem it's most of the times you'll always have to do some post work, and probably allways too clean the noise (plugins like Ninja Noise and alikes can really do miracles)
                      But if you're trying unbiased renders now you should try the progressive path tracing method, i don't know how it works but it's like the best of the biased and unbiased renders, unbiased quality with the biased speed, i don't remember if indigo has it, but kerkythea does. But i think it's best when you only use the sun as light.
                      Keep them coming, and when you have time show us something render with brazil if it's not too much trouble
                      David
                      • soloS Offline
                        Low CPU priority? please elaborate, sounds like a trick we can all use.
                        'Ninja noise' as far as I know is only a Photoshop plugin, I'm unfortunately a Corel Paintshop pro guy.
                        I will check out the progressive path thing, I am sure Indigo has it, at least I hope so, cannot check right now as I'm rendering (a phrase never used using an unbiased engine)
                          dacad
                          In sketchup go to plugins - skindigo - advanced. There you'll see a check in the Low cpu priority (it's checked by default). Uncheck it and it will use all your cpu power to render much faster, but you probably won't be able to work in your pc as long as indigo it's rendering.
                          In indigo advanced settings you'll also see the render method availables. I don't really remember all the details about everyone, so the best it's to read about them and try them all in diferent conditions (just sunlight, many lights, naby glass, caustics etc)
                          One great feature you'll probably like it's turning any component into instances so you can render like 100 cars in the same scene but with a very fast export (it just exports one car model and all the others are instaces and copys of that car, and the instances can be components like rectangles to keep the SU model light and they will be still rendered as cars)
                          Ninja noise can be used as a plugin or stand alone, and you can try it before buying it (comes with a watermark)
                          I started my unbised adventures with indigo but sometimes it can be very unstable, that in conjuction with sketchup poly limitations and you'll find impossible to even start rendering very heavy models (my bridge project, that i posted just before the forum went down, couldn't render in indigo). But beeing able to do everything inside skethcup it's indigo best feature.
                          I switched for kerkythea because until now it never let me down and can render biased and unbiased (so i can easyly adapt to every deadline i have) and has a lot of other options. But i miss doing everything inside sketchup so i'll probably give it another try when the new version is released.
                          David
                          • EdsonE Offline
                            Edson
                            guys,
                            stop playing with brazil. we have a whole government team dedicated to it. let them spoil it by themselves. do not get involved.
                            edson mahfuz, architect| porto alegre โ€ข brasil
                            http://www.mahfuz.arq.br
                              remus
                              Good stuff solo, and welcome to the indigo club ๐Ÿ˜„
                              With regards to increasing the speed, you can also set the number of threads you want indigo to run on (aka how many cores you have), you can find it in the same place as the 'low cpu priority' checkbox.
                              Indigo can also do network renders, although i havent tried it before.
                              • FrederikF Offline
                                Frederik
                                Really nice render, Pete...!! ๐Ÿ‘
                                And great idea to make it a public effort... ๐Ÿ˜„
                                I switched for kerkythea because until now it never let me down and can render biased and unbiased (so i can easyly adapt to every deadline i have) and has a lot of other options. But i miss doing everything inside sketchup...
                                Let's see how things will develop in the future... ๐Ÿ˜‰
                                Cheers
                                Kim Frederik
                                  pibuz
                                  @solo said:
                                  Here is the model for us all to play (I believe someone actually posted this one once, but to the life of me I cannot remember)
                                  IT WAS ME! IT WAS ME! IT WAS ME! IT WAS ME! IT WAS ME!
                                  THE YOUNG PIBUZ AT WORK!!!!!!!! ๐Ÿ˜† ๐Ÿ˜† ๐Ÿ˜†
                                  It was filled with metallic storages that time... ๐Ÿ˜‰
                                  Ok guys, let's give it a go once again then!!!!
                                  Now I'm a little busy planning my next sharing work, when i have some clearer idea i'll surely give this a go! looks really promising, and industrial themes always...poke me! ๐Ÿ˜„
                                  WEB (ita) - https://filipposcarso.wixsite.com/ordinentropico
                                    kwistenbiebel
                                    I am currently looking into Rhino as well.
                                    It is a complete modeling suite , plugin based as well(Bongo for animation, Grasshopper for parametrics etc...) and it has all the major render engines.
                                    When things would go bad for Sketchup in the future, Rhino is a good backup.
                                    It has a built-in 'Layout' and its suited for printing 2D drawings.
                                    Not a bad option...
                                      @Solo
                                      Take also a look to Moment of Inspiration (same one fathers of Rhino)
                                      More and more people use it as "pre modeler" to Rhino ๐Ÿ˜„
                                      Same easy ergonomic than SU โ˜€
                                      Fully compatible (you can drag and drop between them)
                                      And for artists primary created for use it with a pen graphic!!! ๐Ÿ˜ฒ
                                      (you can use mouse also of course) ๐Ÿ’š
                                      And with the next version you will have a "revolutionary" system of object! ๐Ÿ˜Ž
                                      PS SKP file export is direct! ๐Ÿ˜‰
                                      PPS Cool render as usual ๐Ÿ˜Ž
                                      • EdsonE Offline
                                        Edson
                                        hmmmm, a very subtle hint to the effect that something is in the air for the future of KT. i am excited about that!
                                        • N Offline
                                          nomeradona
                                          Not a bad option...
                                          and if you are use too with vray sketchup.. vray rhino is almost the same.
                                          • soloS Offline
                                            Thanks guys, and Pibuz I now remember... thanks mate.
                                            Here is another old model of mine that I ran through Indigo, this time I wanted to see it's 'Clay' render abilities.
                                            http://img264.imageshack.us/img264/7238/im1233376970kj9.jpg
