    [Plugin] 1001bit Tools - Architectural tools for SketchUp
    245 Posts 66 Posters 272.8k Views 66 Watching
      markitekt
      Thanks Bep van Malde!
      That got it working properly, however I still am unable to activate the license.
      It may be a Vista 64 user account issue or something.
      I'm going to try to activate logged in as administrator.
      Mark
        morri
        Many thanks to Goh for this. Parametrable stairs and escalators
          gohch
          Mark
          hi Mark,
          If you're still having problem with activation, feel free to drop me a mail,
          i'll send the activation key to you directly.
          Cheers
            gohch
            hi everyone,
            I've updated the FAQs on setting up and also updated the 1001bit.zip files to version 1.1.1
            The updates are really minor;
            1. there was a bug in the activation -- fixed.
            2. added a few files -- 1001bit_path_win_su7.rb, 1001bit_path_mac_su7.rb
              which contains the correct path for the 1001bit folder for Windows an Mac so that users could just copy it to the plugins folder instead of creating it.
            yep, following some good advise here, placing the 1001bit folder in SU Plugins folder. πŸ˜„
            If you've already placed the folder in c:\1001bit, no need to change anything really it all works fine.
            Thanks and regards
              mehdiettouile
              Hi everybody,( exuse my english) and special thanks to "GOHCH", great pack an very usefull ,i think it would be better and more handy if the tools were orgnized in toolbars. anyway it's a great job
                chango70
                Great job! Lots of useful scripts in there. Thx.
                  rufy
                  Great !!!
                  Many Thanks for the Ruby, i think will be more nice and usefull ruby like : make foundation, hyperbolic parabolic shape maybe πŸ˜† , tile of roof (roof tile) πŸ˜†
                    gohch
                    Now I managed to install the latest version on SU7 mac, opened SU7 and entered my registration code.
                    Tried to creat a stair, window, and no luck.
                    The default values changed all to 0 after the first attempt, then just a big rectangle was created as a component.
                    Exited SU7 and opened again, this time, the 1001bit pluggin wont open at all!
                    Any ideas?
                    hi, got this bug report on Mac, anyone experience similar issue?
                    Truly sorry, my knowledge on Mac environment is really limited; appreciate if someone can assist in this.
                    Also, i heard that the staircase tools are not working properly on Mac as well, i'm working on catching the Mac BUG.
                      gohch
                      my sincere apology Mac users;
                      I was testing this primarily on Windows and i believe the those working on windows do not have much problem.
                      Don't understand why it behave differently in SU Mac; however, i'm working on sorting out the difference soon, and looks like will have to produce a separate Mac version.
                      I'll keep everyone informed when the Mac version is ready.
                        archworks
                        Downloaded install and tried out a couple of the items - this is the right way for architects - thanks
                          gohch
                          hi everyone,
                          Sharing something that is unique to Vista; which might explain some setting up issues and ruby issues on Vista;
                          In part of Vista's security control; sometimes Vista automatically creates a new separate 'mirror' folder in the following location:
                          "C:\Users*username*\AppData\Local*VirtualStore*\Program Files\Google\Google SketchUp 7\Plugins\1001bit"
                          because of this, you now have 2 sets of 1001bit folder; one in the above while the other in
                          "C:\Program Files\Google\Google SketchUp 7\Plugins\1001bit"
                          The folder in the VirtualStore takes precedence over the one in c:\Program Files....
                          If windows find a duplicate file in VirtualStore and the other location, it runs the one in VirtualStore and ignore the other copy.
                          This explains why sometimes when you've editted something in the plugin folder but nothings seems to change.
                          There are 2 ways to work around this
                          1. Find this VirtualStore and work directly in it.
                          2. Remove the 1001bit folder or any file inside the VirtualStore that is a duplicate of the file you want to modify or replace. For example, if you've editted the 1001bit_path_win_su7.rb file, you should have only one copy of this file. I suggest remove the duplicate copy in the VirtualStore.
                          Anyone having problem setting up in Vista, please double check this folder. Any issues feel free to write to me. Thanks
                            gohch
                            Note for installation on Vista 64bit (and on XP 64 too I guess):
                            Modify the path in 1001bit_path_win_su7.rb to
                            $GH1001bit_path="C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/1001bit" in order to get the path to work, otherwise the ruby looks in the 64bit program files path (with 64bit OS, the 32bit programs are placed in the "program files (x86)" folder).
                            Thanks for the good work!
                            Ryo
                            hi, above is another feedback on installation for windows 64bit, from a registered beta tester, Ryo
                            Thanks Ryo
                            • utilerU Offline
                              utiler
                              GOHCH, I am experiencing Bugsplats when I 'Ctrl Copy and divide' in SU. Not sure it if there is a bug with yor offset or array tools that are effecting the standard SU functions.....
                              Also, I have noticed a slight delay with my screen graphics; when I pushpull it is most noticed.... Not sure if you or others using this toolset are experiencing this.
                              Just Curious...
                                gohch
                                hi Andrew, does that happens in new model? or is it something that is accumulative?
                                Does it occur if you exit Sketchup and start Sketchup again?
                                Is anybody experiencing similar problem?
                                • utilerU Offline
                                  utiler
                                  thanks GOHCH, only experienced it in a new model...
                                  Have closed the file and opened it and still occurs. I purged the file and is only about 3Mb...
                                  Just Curious...
                                  • F Offline
                                    fakircho
                                    Thank you for the great plugins. They have this ArchiCAD feel to them, love it. I am glad to see someone
                                    focusing on architectural tools and doing it well.
                                    Have been playing around with it on Windows and all looks quite promising. One thing i have
                                    noticed is that when you use the build wall tool you can not follow the axis. Ideally you should be able to inference
                                    the normal way and use shift to lock on one axis or another. Same goes for the other plugins.
                                    Waiting for the working MAC version and the Tool bar πŸ˜„
                                      gohch
                                      hi Fakircho,
                                      Thanks for the feedback, Yes, I should have the inference added in the next upgrade soon.
                                      As for the Mac, ordered a Macbook but the earliest they can deliver is 2 weeks later; seems like Apple is pushing out a new model. I'm eagerly waiting for my Macbook to start working on the mac version. πŸŽ‰
                                        gohch
                                        hi guys,
                                        i've added some inference to the Vertical Wall tool;
                                        pressing the down button will cycle through the following inference modes
                                        1 - lock current direction, next if the cursor is on an edge, projects to intersection point, else project to point nearest to the cursor position on the current direction.
                                        2 - lock current direction, project to point on the x axis of cursor
                                        3 - lock current direction, project to point on the y axis of cursor
                                        4 - release
                                        upwards button release the lock
                                        right button - locks in x axis
                                        left button - locks in y axis
                                        Note that you can enter exact distance anytime.
                                        Anyone want to try out please replace the attached vx_wall.rbs file with the one you have. (not sure whether i can attach rbs file here, zipped it just in case)
                                        cheers!
                                        updated vx_wall.rbs
                                          dizain
                                          Error:
                                          No such file to load -- C:/Program Files/Google/Google SketchUp 7/Plugins/1001bit/1001bit_loader.rb
                                          • F Offline
                                            fakircho
                                            Thanks for the inference addition to the wall tool.
                                            I hate to be difficult but can it work the same way as the rest of the Sketchup tools. That is
                                            when you pint with your mouse it should pick up the red or green axis and then you lock it with the shift key? That would be perfect
                                            • 12
                                            • 13
                                            • 2 / 13
