    1962 Fender Stratocaster Body
    27 Posts 11 Posters 16.5k Views 11 Watching
    • Gus RG Offline
      Gus R
      Thank you Mike, Ross and David. Ross, I do some graphics on the side but it's rarely utilized.
      David, cute little guitar ornamanet. I have played on and off over the years now but more recently I've been in off mode since having to sell my PRS. A cheap little "classical" guitar just doesn't seem to cut it. I guess my style was towards jazz-blues or some kind of rock fusion.
      Speaking of kazoos maybe you remember the kazoo craze of the late 60s and 70s? Perhaps you read it in a history book but it was an offshot from "Laugh In" if I remember correctly. They even had us making "kazoos" using wax paper and a comb. The kazoo goes well with a saw and a washboard. ๐Ÿ˜„
      Started the neck but haven't got anything to show yet.
      Cheers,
      Gus
      www.instagram.com/gusrobatto/
      www.facebook.com/gusrobatto
      • F Offline
        fella77
        Wow....that tremolo bridge is amazing! Looks like a very accurate model and the render is pretty nice for a "quick". This model is going to be ridiculous once you put all the pieces together.
        Really amazing work!
        Progress (about ยผ% done)
        • david_hD Offline
          david_h
          Well, I am an acoustic man myself--Folkie. I should model my Taylor 1500.
          D
          • Gus RG Offline
            Gus R
            Thanks David (fella77). David H, I used to listen to folk for a time. Mostly of the Bob Dylan variety on acoustic.
            So, got the neck almost done and let me tell you, this was almost tougher than the body. Most of it was done using SDS (about 90%) with a lot of trial and error runs. Have to add groves to the nut and add a small sweep from the head stock to the nut itself. The drill holes won't be visible of course but thought it would look nice for a rendering of the neck itself.
            All work done in SU free once again. Finally figured out how to tweak the material mapping in KT by changing it to cubic mapping for this particular model. 22 jumbo frets and everything is to scale.
            ๐Ÿค“
            • Gus RG Offline
              Gus R
              Well, those were the neck renderings. Ironically I'm still putzing with the neck.
              Rounding the corner with this and finishing up the tuning heads. These are Kluson Pro Tuners which aren't exactly vintage tuning heads for a '62 Stratocaster.
              Last one is an x-ray view in SU using a Japanese Style (sesshu.style) by U4K.
              Tuning head knobs were done with SDS.
              Might make some Schaller and Grover machines as well.
              • Gus RG Offline
                Gus R
                Guess I must be talking to myself.
                • EarthMoverE Offline
                  EarthMover
                  Flippin amazing Gus! ๐Ÿ˜ This may be the best Sketchup work I've ever seen. I may be a little partial to the subject...... That's what I call photoreal. I think it deserves a spot in the next Catchup Newsletter.
                  Content Creator at Skapeup
                    Ross Macintosh
                    No -- we're just blown away! Gobsmacked is an appropriate word. The last line drawing suggests you've now got it all together. (Have you done the little post thingies for attaching a strap?) I'm looking forward to seeing your photorealistic renders of the completed model.
                    Regards, Ross
                    • N Offline
                      notareal
                      Do not worry too much about that. I think people are speechless in awe. Great work. ๐Ÿ‘
                      • david_hD Offline
                        david_h
                        ๐Ÿ˜ฎ lots of awe here
                        **in fact. . .I am thinkin' of Jimi right now playing the Star Spangled Banner. . .nyeer nyeer nyeer nyeer nyeer nyeeeeeeer
                        of course he had his upside down and restrung for a leftie! ๐Ÿ˜Ž**
                          EarthMover
                          Gus,
                          I'm curious about how you managed to work the transitions on the neck. You've achieved such great flow from the tuning head into the neck. Did you do this with one solid mesh, or was there a lot of stitching involved?
                          • Gus RG Offline
                            Gus R
                            Thanks guys! Adam, Notreal, David, Ross. I was probably reading too much into things what with the lack of work, winter and perhaps a touch of cabin fever and all. ๐Ÿ˜„
                            David, yesterday I couldn't get "Little Wing" out of my mind.
                            Adam, the neck transitions is basically a squared of proxy for SDS. I generally start with one profile and then use the same profile scaled accordingly. Took some tweaking and nudging to get it right from the neck to the headstock. What I do is try to visualize what the neck would look like reduced to the flat planes that would make up the curves.
                            I'll try and post either some images or skp of that.
                            • Gus RG Gus R referenced this topic on
                            • 2 / 2
