    Drawing a hedge!
    13 Posts 9 Posters 9.8k Views 9 Watching
      Stewy
      Hi Guys,
      I now need to draw a neat hedge for a plan and want it to look good, doesn't need to have every leaf! and ideas on a good way to model it?
      Thinking about it, being able to model trees would also be good
      Thanks,
      Stew
        Masta Squidge
        @stewy said:
        Hi Guys,
        Thanks,
        Stew
        You could make a simple box in the shape of said hedge then apply a realistic, leafy repeating texture to it. You can of course add smaller details, like rounded/beveled edges and such. If you have photoshop skills they are easy to create, otherwise a search online should help. That I think is the simplest way of doing it. If i recall someone around here makes really REALLY nice foliage in SU...
        Although I suspect you have already though of that idea and want something better. I seriously lack the skills to compromise between accuracy and easy modeling and have it look good. Its a fine line between a boxed hedge and one with branches and leaves.
        • ToboboT Offline
          Tobobo
          Its something I struggle with when I model schemes, the powers that be want realism and speed. I've done both the box shape and repeating 3D components and both work in different situations.
          How realistic does the model have to be?
          Toby
          Philippians 4:13
          • jim smithJ Offline
            jim smith
            Try this link. It is in the components and materials forum. Very simple hedge
            404 Not Found
            (www.sketchucation.com)
            "Out of clutter find simplicity,
            from discord find harmony,
            In the middle of difficulty lies opportunity"
            Albert Einstein
            • soloS Offline
              Stewy, are you needing this as a 3d component or are you planning to use it as a top/plan view in layout?
              • W Offline
                watkins
                I found this in my folder of useful garden components. I cannot remember from where I got the model, and so cannot acknowledge the source. The technique of using a texture with a transparent background seems to work quite nicely. I image it could be made smaller in size by using components rather than groups.
                Hope this helps.
                Regards,
                Bob
                Hedge.skp
                  Stewy
                  Thank you guys for your replies, I have played around with 3D boxes and colours (haven't figured out how to add leaf patterns yet!) and I may just use a sort of opaque green rectangle as a hedge.
                  I do love this program - can't stop playing with it. Great forum, thanks fellas
                  Stew
                  • soloS Offline
                    I made a .png of a hedge for you, attached is the alpha embedded image as well as a seperate alpha map for those who want to use it with vray.
                      Stewy
                      Thanks Solo,
                      So I now save the png and use it as a sort of texture/colour to apply to my hedge box sides? or am I being a spanner?
                      Stew
                        You can also import it as a simple image and just place it side by side. These 2D images can work fairly well from a distance. Of course, for a foreground object, you can combine them with a certain boxy shape, too.
                        • soloS Offline
                          Hope this helps.
                          http://img403.imageshack.us/img403/9164/lowpolyhedgezu3.jpg
                          lowpoly hedge.skp
                          • pietervP Offline
                            pieterv
                            Thanks for that! I find it usefull.
                            This is my website:
                            Citypixels - 3d Visualisatie Architectuur
                            • pbacotP Offline
                              Thanks Pete !
