    [Plugin] V-Ray Tools
    238 Posts 80 Posters 290.1k Views 80 Watching
      bianhai
      This looks very useful. πŸ‘
        mimnbazhq
        Thank you! πŸ˜„
          @hfm said:
          Don't seem to get it working correctly [using SU 6 and V-Ray 1.5]
          Looks like the render is zoomed in too much [the dialog show 1,919 and nothing else 😞 ]
          Can you post screenshots of the result? One of the SU window and one of the V-Ray output? (and also your V-Ray Camera and Output flyout?)
          • PixeroP Offline
            Pixero
            Wow!
            This will be sooo good. πŸ‘ πŸ‘ πŸ‘ πŸ‘ πŸ‘
            And yes, I am toying around with a light manager. But I heard rumours that ASGVis is working on this them self with VfSU 2 so I'm not sure how much work I'll bother to put into that.
            About the lightmanager, with ASGVis's current speed of updates that will at least take two more years, so go for it!!!
            Would it be possible to add a render region tool? I really want that.
              I'd really like that too. But that's not something that can be achieved with a ruby I'm afraid. Has to be implemented in the V-Ray plugin itself.
                could i suggest taking out the file location slot for the export location, rather have just the export button, once you hit it a window will pop up like with sketchup's export 2d image option? i tried the existing one but everytime i put in a location it says failed to save, or overwrite existing file?
                Good news! Turns out that I've been a complete numpty and completely missed two API methods that allow you to use the file dialog windows. I'll update the plugin as soon as I get time.
                • H Offline
                  HFM
                  I would but the export of your plugin doesn't work on my PC. It asks if I want to overwrite the existing file [there is none πŸ˜• ] And then gives a fail error.
                  I'll think I'll just wait for the next release πŸ˜„
                  • 4 Offline
                    40Th
                    Thanks Thom! Really appreciated. I'll try the plugin (on SU7 VrfSUv1.00) any time soon and post back.
                      Thanks. πŸ˜„
                      Though I don't have high hopes that the VfSU output will match the viewport. I think things where changed between the original and SR1.0 in the way VfSU matched the SU view. Also, I think that the zoom works opposite in SR1.x. In the original you had to use numbers less than 1 to zoom out, while in SR1.x you have to use numbers larger than 1 to zoom out. ...if I'm not completely mistaken, which is a distinct possibility... πŸ˜‰
                      • 4 Offline
                        40Th
                        I tried your 1.0.1 on SU7 VrfSUv1.00 and i get an error message πŸ˜’
                          What kind of error message did you get?
                          • Y Offline
                            Yanman
                            Thaks You thomthom wrote For Plugin V-Ray Toys. 😍 😍 😍
                            I love SU.
                            • N Offline
                              nomeradona
                              cool toy indeed... thanks thom
                                Added "Load V-Ray on Demand"
                                • free agentF Offline
                                  free agent
                                  handy thom thanx... wheres "Render Region"? 😎
                                  http://i167.photobucket.com/albums/u143/FreeAgent84/bug.gif
                                    me3mar
                                    hallo everyone,
                                    i am having a problem with vray rendering a part of the view only(in two point perspective ) , while getting the right sketchup view by exporting 2d jpeg.
                                    the vray keeps rendering another view nomatter what i do, it renders somtimes above, and sometimes beneath the sketchup view.
                                    the output pic in vray is my monitor = sketchup view
                                    do these tools help with my problem ?
                                    thanks in advance πŸ˜„
                                      @me3mar said:
                                      hallo everyone,
                                      Don't think so. This plugin required the physical camera to sync the views.
                                      I think that you have to disable the physical camera in order to render 2 point perspectives. I've never done 2 point perspectives, but there's some threads on the topic over at ASGvis's forums.
                                        free agent
                                        nope its a vray bug, they cant read any changes you make to the viewport after enableling 2point perspective mode, so when u enable 2 point thats what is going to render, if u pan up to see the building it will only render ur initial view 😞 my fix is too zoom out and render at a high resolution so u can crop ur render or just correct it in photoshop.
                                          me3mar
                                          Thanks so much to Free Agent and to Thomthom,
                                          i'll give it a try at the ASGvis's forums.
                                          greetings
                                          • EarthMoverE Offline
                                            EarthMover
                                            Thomas, I had a chance you use your plugin today and it worked flawlessly. Thanks again. The render I did is at the bottom of this page - http://www.sketchucation.com/forums/scf/viewtopic.php?f=81&t=16231&start=45
                                            Content Creator at Skapeup
                                            • 11
                                            • 12
                                            • 1 / 12
