    Face selection problems
    5 Posts 4 Posters 671 Views 4 Watching
      tcofran
      Is there ANY cure for the face selection problem in SU. I got a new PC at work and it is nearly impossible to work on SU.
      Fran
        Hi Fran,
        If you mean that not the faces ou want are seleted, try to go to Window > Preferences > OpenGL settings and (un)check "corrct reverse picking driver bug".
        If this does not help, you can also turn off "fast feedback".
        If this does not help either, uncheck hardware aceleration and se if it sems to fix the problem. If yes, most probably you should update your video driver.
          tcofran
          thanks for the reply ......
          i have tried all the above, no luck. I suppose the best would be to fork out some of my own money and buy a graphics card.
          Fran
            krash88
            I had the same problem with a brand new Dell system that came with an ATI card (I forget the model). I bought a GeForce 7600 GS and everything's been perfect since.
              Levethian
              Fran,
              The problem of face selection seems to spawn from earlier ATI Catalyst drivers - simply update to current version (8.11) and the problem is fixed.
              Without any hardware acceleration this problem shouldn't occur (which indicates, Fran, that you already have a graphics card?)
