    Wall, Door and Window schedules
    36 Posts 14 Posters 6.5k Views 14 Watching
    • P
      peweuk
      Another trick we have used in the past is to create short "stub walls" for temporary display, and place the stub walls in one layer, and the real walls in another layer, then you can turn on the short stub walls while placing furniture and use the real walls for interior renderings, etc.
      What about a wall tool that creates 2 walls at the same time based on the input of the user.
      The first is one on a layer called 'transparent walls' which is 'on' by default - this is the single thin wall like in RPtools which is transparent and is in the same position as the inside face of the 'Real Wall'.
      The second is the real wall (or two walls for cavity type construction) set to the users required dimensions and placed on a layer 'Walls' which is turned off by default.
      At any time, the state of the 2 layers could be changed at the same time using the layers dialogue, or two 'scenes' could be created for quick viewing, each with the opposite layers turned on/off. When the job is finished if it is not needed anymore the 'transparent' layer and its contents could be deleted.
      Just a thought 😉
      • Al HartA
        Al Hart
        Just a thought 😉
        The "new walls" will probably put each wall in a group, so we can place two faces in one layer and one face in the other, as you suggest, and store bot in the same wall "group".
        The phrase "inside face" is one of our problems - because we aren't sure what is the inside of an interior wall. we may have to place the single face in the center, which will sometimes be confusing.
        The single face wall would be nice for placing openings though - because it would be easy to align the opening to the center of the wall, and cut the hole through all three faces.
        Al Hart
        IRender nXt from Render Plus
        • P
          peweuk
          I take your point AL. The problem with putting it in the center is that it would not make the placing of items on the real 'wall' very easy.
          What about creating two single transparent faces - one on each side of the 'wall' - or is this not do-able?
            SAB
            I work for a firm that does design and working drawings for small and large residential projects. We use Sketchup for preliminary design, visualization and some early cost analysis and use revit for working drawings. Sketchup allows us to model and revise very quickly. There are some tools available in sketchup (area etc.)that can give us information to check against current building costs in our area. The attribute tools in Su7 are allowing us to include more intelligence in our models to make feasibility studies easier. Automating this process with your proposed tools would be useful in our work flow if they can be implemented without weighing down the sketchup files and slowing the performance of the program. Creating 2d detailing of a large project for on site use by contractors would be nearly impossible in Sketchup. A combination of Sketchup and Layout could possibly be used for this on small projects. Concept, presentation and early design development are sketchup's current strong points and BIM software's weak points. This seems like a reasonable division of labour.
            If we run into issues with complex shapes in revit we use sketchup to make mass models and import them into revit. Complex roof design seems to be a recurring use for Sketchup in Revit. Interaction with sketchup is a little crudely but still effectively built-in to Revit already.
            We use Revit for structural, MEP and architectural working drawings. The accuracy of and speed with which we create the drawings has improved drastically since moving from Autocad to Revit. Every object in a Revit model is packed with information and has the option of having custom attributes added. The level of information stored in a Revit file allows great flexibility and fine grained information presentation. Getting enough information into a sketchup model to do this seems improbable.
            • C
              cgraham
              In my opinion, Sketchup has a long way to go to be a viable construction documentation tool. There are many other products out there that do the job much better that are (nearly) as cheap.
              I use the product for conceptual design and easy, quick renderings. So, instead of tweaking the minutae, I would rather see the product perform faster, with smaller file sizes. It is common for file sizes to quickly reach the 55MB range, and all manipulations within the file become a waiting contest, even with shadows off and faces set to monochrome.
              It would also be an enormous benefit if files could be "cross referenced" into the current model, instead of importing as dead files. With this feature, the cross referenced file could be modified separately, and then all the references would automatically update.
              So, it's like filling a container with multiple-sized balls. Get the big balls in first, and then the smaller balls can easily fit.
              • P
                peweuk
                Chalk and Cheese springs to mind when I follow this thread.
                High end construction/architectural programmes such as Revit seem to have been mentioned a few times in this thread now, comparing Sketchup to them from an Arhitetural point of view.
                I, personally, am not really concerned with taking models to that level - as I am sure is the case with a large number existing and potential Sketchup users.
                I have no experience of Revit and can only compare Sketchup with other 3D programs that I have looked at in an effort to establish what is best suited to the market I operate in - interior design.
                The main criteria in identifying a suitable program for the mass market of interior design that I have experience in (specifically the area of Kitchen, Bedroom, Bathroom design) are ;
                Ease of use
                Speed of design
                Cost
                Information output
                Quality of presentation
                (not necessarily in that order)
                There are a number of programs aimed specifically at this market and, having had experience of most of them, IMHO Sketchup comes near (if not at) the top.
                Having said that, Sketchup has a number of shortcomings which could be overcome with the development of additional tools, either as part of the program or the availability of external extensions, plug-ins or tools such as the one that Al started this thread to discuss.
                When I first looked at Sketchup it took me very little time to get to grips with it due to its simplicity of operation. Within a very short space of time I was able to understand it well enough to pass on what I had learnt and teach someone who had no Design software experience how to design a Kitchen in Sketchup spending no more than half an hour doing so. There is no way I could have done that with other interior design programs I have experienced - apart from one which I shall not mention. And Sketchup is far more flexible than all of them for a number of reasons.
                Having access to tools such as RPTools make the job even easier and access to additional tools, such as the Wall Tool Al is considering, would simply make the job even easier.
                The introduction of Dynamic Components in SU7 also now enables us to produce not only cutting lists, but cost reports and other information to suit our market that previously were missing in Sketchup.
                So ignoring full blown Construction/Architectural drawings (in the nicest possible way) I think that potentially Sketchup is more than capable of satisfying the needs of a vast market which could benefit from Sketchup in it's current form, and even more so with further development of both the program and external applications, extensions and plug-ins.
                So keep up the good work AL.
                • Al HartA
                  Al Hart
                  I did have to look up that phrase:
                  The earliest citation of the phrase, in John Gower's Confessio Amantis, 1390 does suggest some dodgy dealing, in which cheese is replaced with chalk:
                  Lo, how they feignen chalk for chese.
                  and
                  And thus ful ofte chalk for chese
                  He changeth with ful litel cost,
                  Wherof an other hath the lost
                  And he the profit schal receive.
                  By the sixteenth century, the phrase had become a fixed expression. Hugh Latimer wrote rather sarcastically around 1555: “As though I could not discern cheese from chalk.”
                  I appreciate your comments. Although one of my life-long dreams would be fulfilled if I could edge out both AutoCAD and Revit, a smaller dream will come closer if I am able to do something useful for SketchUp.
                  Al Hart
                  • P
                    peweuk
                    "From Small Acorns ....." 😉
                      ashleyjoyce
                      I appreciate both SAB & CGRAHAM's professional feedback and I agree 100% with there take on the role of both SketchUp and Revit in the area of building design.
                      My advice to anyone starting out in architecture... is learn Revit for Construction details and onging management of the building. SketchUp should only be used for concept designs, presentation drawings & mass modelling complex components for use in Revit.
                        richcat
                        @al hart said:
                        Another item we have on the back burner - perhaps as part of the Wall project - is second display window for SketchUp which would add 2D CAD items to the SketchUp drawing - but only display them in the 2D CAD window.
                        This second window sounds very interesting, can you tell us more, is this run inside sketchup, or can it run as a separate instance but connected, like a preview window. Can you control what you view in it etc.
                        In terms of 2d cad what I would really like to see a set of rubies to go together with RPTools. The polyline is great as it does not auto infill faces, the Richtext input if it had alpha transparent background would be great.I know that I can now draw consistently in one plane, using set camera settings and views, but I would like a dimension tool that did not change text size as you zoomed in a out. An extend arc tool would be great, the extend ruby altered so that there was more control. An offset tool that worked on lines not just faces would be great. A copy properties tool would be very useful with printed line thickness by colour table would make my day, and lots of dashed/dotted lines and last but not least hatches (I suppose these could be materials with alpha backgrounds)
                        Basically a simple 2d cad package inside sketchup that could then be developed further.
                        • Al HartA
                          Al Hart
                          It would run as a sub-task of SketchUp (much like IRender does when not in Batch mode).
                          It would display the SketchUp database, but would have its own display for special items. For instance we put an attribute on edges to set their display width. We cannot display this in SketchUp, but we could in our own OpenGL window. (We apply the width when creating a PDF of SketchUp)
                          We could create certain custom entities this way - which would have a default display (or no display) in SketchUp but would display in the separate window.
                          However, this is a somewhat far fetched concept - until we find something which actually needs it.
                          Dimensioning, Text and Cross-Hatch seem to be the most likely suspects as we move on with them.
                          Also, we are working on some software for the ARRIS CAD system to embed PDF, Word and Excel documents into a drawing. We could embed documents as low-res Images in SketchUp - but use the original document for PDF printing or a separate display window.
                          Al Hart
                            redinhawaii
                            Any further work on this subject?
                            • Al HartA
                              Al Hart
                              Did anything come of this concept,
                              as I am doing working drawings in SU/LO and to have an embedded pdf for schedules and lists seems a winner towards making this more productive.
                              thanks
                              RpWallMaker Free creates walls - each a s group, and lets you cut holes in them. It still has a long way to go as we are waiting for more user response before creating a "Pro" version. Which will allow for inside and outside justification and reports.
                              SpaceDesign Pro (also not released yet), would create reports from the walls, and windows, and create an embedded PDF report:
                              RpReports creates these PDF reports now. But it is too complicated (and expensive) for simple wall, door and window schedules. RpWalls Pro or SpaceDesign Pro will be better tools when they are completed.
                              http://wiki.renderplus.com/images/thumb/4/44/Pdf-report.jpg/350px-Pdf-report.jpg
                              Al Hart
                              • T
                                tomot
                                I arrived a little late to this thread: I notice the discussion has meandered, which is normal, in forums.
                                For those reading this thread, I have already donated 2 Ruby scripts to this forum which I wrote:
                                I didn't claim copyright nor did I obfuscate the code so others could not read it, and anyone is free to use the code and alter it.
                                Window Tools:
                                http://forums.sketchucation.com/viewtopic.php?f=323&t=14394&p=109705&hilit=window+tools#p108868
                                Door Tool:
                                http://forums.sketchucation.com/viewtopic.php?f=323&t=14008&p=105538&hilit=doortools#p105538
                                My investigation into Ruby coding lead me to believe that it was impossible to cut an opening into a wall, because a SketchUp wall is not actually a wall, its only to planes separated by a given distance, with 4 more planes defining the thickness, unlike a real 3d object which would require a Boolean operation to cut holes into it, or Nurb objects. However my 2 ruby scripts will cut openings into walls as long as the user enters the wall thickness into the dialog box prior to cutting the holes. SketchUp is a surface modeling program NOT a solid modeling program like ArchiCad, Maya, XIS, Max, C4D, or Rhino. Its also one of the main problems facing developers trying to produce workable export plugins from SketchUp to other 3d platforms.
                                I found schedules the 3rd item on the list, to which not much attention has been paid.
                                When I was creating AutoCad window and Door schedules many years ago, I could get them to print out via an Excel spreadsheet. So they could be incorporated in 8.5x 11 format into the back of a specification manual(s) I had to create a Dialog box consisting of some 15 attribute tags that needed to by filled out before a door could be inserted onto a AutoCad drawing file. So whats wrong with that!
                                Nothing except AutoCad would change its menu structure each year. And with each newer version, it became impossible to keep up making changes to the menu structure, and to incorporate those Attribute and Lisp coded functions. And it got even harder, for the Firm, after I left. I heard later that they were making schedules the old fashioned way, which was much faster in the long run.
                                I've been there just like Atl-Arch describing his attempt to build a stone cap parapet. I recall Working with a $3000.00 program from AutoDesk called Architectural Desktop, which was supposed to be used to draw repetitive floor plans, except they forgot to include an actual floor in the program that you could insert and which had actual thickness.
                                I hope Revit users wont go through the same dilemma, now that AutoDesk bought them.
                                Regardless, I'm looking forward to the schedule, good luck, Al
                                my plugins
                                tomot
                                • 2 / 2
