    My Favorite Power Tool
    42 Posts 25 Posters 4.4k Views 25 Watching
      Click Draw
      Really nice work Adam. I am constantly inspired on this forum when I see models and renders like yours and many others here.
      Cheers,
      Jeff
      Have I mentioned how much of a laugh I get out of some of the Signatures on here!
      • soloS Offline
        Adam
        I ran it through Vue 7 using standard settings, I used an HDRI for illumination and reflection only, then added soft focus for a smooth effect.
        Rendered using Broadcast (there are artifacts), took just a few seconds over 7 minutes.
        http://img114.imageshack.us/img114/5735/chopsawxa8.jpg
        I will give it another go soon.
        • EarthMoverE Offline
          EarthMover
          Wow Pete.....7 minutes! Thanks man, that looks awesome. So I guess E-on really improved their render engine. I would never even think to try to render a product shot with Vue 6.
          One thing with the render....the blade would never get dirty like that. That hose running up the side is a water line.....couple that with the fact that it is cutting through concrete and stone and you have a self cleaning blade that stays pretty shiny......no mater how beat to hell the saw gets. 😆
          Content Creator at Skapeup
            seabass84
            What about this dirty? 😄
            http://www.reelingreviews.com/hightensionpic.jpg
              cheffey
              Is that Lindsay Lohan's girlfriend after one of their fights?
              BROS RŌMAN BRÄUN
                EarthMover
                🤣 🤣 🤣 Classic!
                • plot-parisP Offline
                  plot-paris
                  outstanding model, EarthMover. the detail is really breathtaking.
                  I think thats no dirt but a reflection of the HDRI image. a bit confusing, cause we don't see the background. nevertheless - fantastic Vue Render, Solo
                    EarthMover
                    Pete,
                    How do you get an HDRI into Vue? Is that only something you can do in 7? Also, do you still have to convert the file to .3ds with Vue 7, or do you just open the .skp file directly? I have a pretty large project in the works, and may be able to justify an upgrade.
                    EDIT: Found the HDRI slot. It's in the Environment Mapping, under the effects tab. I've been using Vue for some time now, and never knew that was there!
                    • soloS Offline
                      Adam
                      Great that you found that, I also hunted for it initially.
                      Vue 7 imports .skp directly, however it only imports SU 6 files, there is an update due this month that will include SU 7 files.
                      Here is a very fast 4 minute render of an animated blade, converted to .gif so quality dropped big time.
                      The above blade had a dirt map, I removed it for this one.
                      http://img258.imageshack.us/img258/5347/chopsaw1lx6.gif
                      LOL, just noticed I animated it running the wrong direction.
                      • pbacotP Offline
                        I once cut some windows in plaster with one of those, holding it up in front of me. NOT my favorite machine that day, but it did the job.
                          EarthMover
                          Pete,
                          I've been trying to imitate your Vue animation. I've figured out how to center the pivot point and get the blade spinning with keyframes. How did you get it to render in 4 minutes? What format did you output to? What did you use to convert to a .gif? BTW - I had a project go through and I was able to upgrade to Vue 7. So far, I love it. Way more stable on my 64-bit system. Only issue is that I installed the 64-bit, but only the 32-bit version supports SU import. Do you think I would loose render speed going down to the 32-bit version? Is Vue's SU importer good enough to justify a downgrade? Sorry for all the questions...
                          • soloS Offline
                            Adam
                            The reason i was able to do it quick is because I only animated four frames (all that was needed) and I lowered the render quality to final and reduced the output size.
                            I had a 64 bit installation last year but changed back to 32 bit due to too many issues of campatability, Since then many apps have begun supporting 64 bit, I plan to upgrade to a new I7 dual quad soon which will be a 64 bit rig. So in answering you I would say yes 32 bit rendering will be slightly slower, however I use 5 rigs on a render cow configuration which makes the difference un-noticable.
                            The .skp importer works okay (not great) I still prefer using .3ds export, but that's more because I am stuck in a tested workflow.
                            Please ask me anything, I will do my best to help.
                            • 2 / 3
