    A Welcome Message to New SketchUcation Members
    1.4k Posts 667 Posters 1.2m Views 667 Watching
      remus
      Looks like an opengl problem to me.
      Make sure youve got the latest drivers for your graphics card. If that doesnt fix it, go in to SU window->preferences->openGL then turn of hardware acceleration.
      • G
        gertjanakerboom
        thanks for that!, turning off the hardware acceleration seems to work, im not sure what i actually did there though. will turning that off effect anything else in the program?
        gj
          remus
          It will slow SU down a lot with bigger models.
          Might i ask what graphics card youve got? if any.
          • G
            gertjanakerboom
            yes you may and i have to say that im not sure if i even have one, just looked at "about this mac" and it didn't show a graphic card. it did say this at the graphic/display button.
            Chipset Model: GMA 950
            Type: Display
            Bus: Built-In
            VRAM (Total): 64 MB of shared system memory
            Vendor: Intel (0x8086)
            Device ID: 0x27a2
            Revision ID: 0x0003
            Displays:
            Color LCD:
            Display Type: LCD
            Resolution: 1280 x 800
            Depth: 32-bit Color
            Built-In: Yes
            Core Image: Hardware Accelerated
            Main Display: Yes
            Mirror: Off
            Online: Yes
            Quartz Extreme: Supported
            Display Connector:
            Status: No display connected
              remus
              Sounds like integrated intel graphics, which unfortunately arent particularly good for running SU as their openGL support is pretty bad (when you turned of hardware acceleration you wre pretty much tell SU not to use the graphics card to render the model, this is what causes SU to slow down.)
              • G
                gertjanakerboom
                alright thanks for that, i just have to live with that then i guess.
                i think ill be alright because i was only going to use it as a tool to help me get the perspective right for my drawings on paper (sounds a little weird eh? http://www.gertjanakerboom.com/1pages/bigpoppage.html )
                for instance i did that one on the paper and it took forever! now i can just use su to build a structure, take a picture of it and then use it for my drawings!
                anyway thanks again!
                gj
                  remus
                  You might be interested in some of the stuff andyc does: http://www.sketchucation.com/forums/scf/search.php?author_id=229&sr=posts
                  I think it might be similar to what your doing, although he does a lot of it in photoshop.
                  • GaieusG
                    Hi GJ and welcome,
                    Now as your video driver issue is "solved", back to your drawings; a pretty good idea.
                    I used to teach art history to fine art students and lately some of them started to use SU as a basic tool for their perspective studies as well. What they actually do is that they project the basic image onto the paper/canvas they are working on. You can even use guide lines to project perspective lines to the infinity.
                      DesignerGay
                      i'm Christian from Canada. I'm trying SketchUp for the first time. A friend from Germany told me about this forum, i hope we have a good time together.
                      Christian
                      • GaieusG
                        Hi Christian and welcome! There are a couple standard members here from Canada,I hope you'll ind your companion.
                        • U
                          Username
                          Hello, I just began using SketchUp a few weeks ago and thought that I could learn quite a bit by joining the forum here.
                          • GaieusG
                            Welcome Username (nice username BTW 😄 )
                            As our "slogan" for this subforum is: "Ask and get answered"
                            • G
                              gertjanakerboom
                              Hello everybody, thanks for the fast reply's on my last Question!
                              Now i have another one, i've been trying to make a little fence that i can use in my works. Its a pretty simple one (see sketch i made) but i can't seem to do it. i know how to make tubes etc but have a hard time making the round pieces of tube for the corners. does anyone know a tutorial that tells me how to do that? or can anyone explane?
                              THANKS!
                              gj
                              • U
                                Username
                                THANKS!
                                gj
                                The way I would do it, would be to make the shape with just lines, and for the corners I would use the arc tool so that you have the basic shape but it is 2D. Then where one of the vertical pieces ends, I would make a circle so that the vertical segment continued would go through the center of the circle. Then select the entire line but not the circle and then select the "follow me tool" and then click on the circle. That should do what you want, if I understand you correctly.
                                • G
                                  gertjanakerboom
                                  thank you "username" i'm going to try right away!
                                  gj
                                  • arquitectomaracuchoA
                                    arquitectomaracucho
                                    Hi to all users of Sketchup. I am in the area of Architecture and sketchup user since version 5, new to the forum, and tried a lot of great new tools and seem especially good for architecture. There is a plugin that interests me "House metric" but I would like to have an adaptive structure of concrete, steel and other building systems to adapt, where you can get metric computations and cost estimates. Besides combining with Sketchy Physics simulations to support structural properties other than giving each material "would be great, in fact my greetings and congratulations to all developers and users" Sketchupcation "for his work, is so special! 👍
                                    Excuse my English. 😛
                                      rgcrockett
                                      Hey all,
                                      I do have a question, but I thought I'd first just say thanks for all the great tips I've learned just from searching and browsing. In my googling, I kept ending up at this forum and finding the very best answers to my questions. Excellent.
                                      Second, I downloaded the free version because I was exploring a means of generating backgrounds in full perspective for a comic book. I mainly work in Adobe Illustrator from scans of pencils, but drawing the same backgrounds from different angles over and over (and over and over...) as my characters move around and through the same scene was just not working for me. Sketchup is THE solution. I love it. I've gotten all wrapped up in learning the program for its own sake, and to challenge myself, I've started modeling some complex shapes-- like right now I'm working on a mock up of a Fender Jazz bass. (I own one, actually.)
                                      The problem I have right now is that I have a couple of holes in my model that just won't fill! One is a quadrilateral, the other a triangle. Both are so tiny that they only show up as little black dots when edges are not displayed, but they are there.
                                      Other searches indicated that I probably had some lines not quite touching. Check. Managed to find a few of those and fix 'em. The process taught me a lot. Basically I worked at as extreme magnification as the program allowed and just deleted and redrew until the offending line revealed itself. When that failed, I isolated the problem by sort of triangulating in, you know, making ever smaller triangles until I isolated to point that was causing the problem, but these last two holes just won't yield to these approaches.
                                      I could definitely use a tip here!
                                      Cheers,
                                      Rick
                                        remus
                                        If the holes are very small (less than 1mm) then you will need to scale your model up 100x, fill them and scale your model back. this is because the way SU displays your model on the screen doesnt like really small stuff, so by working at 100x scale you sort it out.
                                          rgcrockett
                                          Thank you Remus. That was EXACTLY the problem. Worked like a charm, and thanks for the fast answer!
                                          • E
                                            Ecuadorian
                                            Hello, everyone. I'm kinda new to SketchUp, too... Well, I'm actually not a "new" SketchUp user.
                                            I first discovered it in 2004 after graduating as an architect, played around with it, drew random shapes, push/pull'd them, and then got bored when I couldn't even do a simple house, while I was already proficient in ArchiCAD. So I just let my little nephew play with it while I worked in ArchiCAD.
                                            Years passed, I hoped ArchiCAD would finally integrate a decent modeler, but it didn't happen. I wasted lots of time creating ArchiCAD objects from slabs and walls for even simple shapes. And since most of my clients want custom-shaped doors, windows, and furniture, ArchiCAD libraries are next to useless to me in this regard.
                                            And then, last week (Monday 5) I received a call from the local branch of the Jehovah's Witnesses (as I am one, too) asking me to design a few small things for our convention hall: A structure for an information board, a place to wash mops, etc. Since these are small things and this would not be paid work (And thus not require photorealistic renderings) I decided to give SketchUp a try for this project. (At the time, I had no idea that there were good rendering plug-ins for SketchUp). So I downloaded GSU7, and watched all the introductory videos within 24 hours between Wednesday night and Thursday night. On Friday morning I visited them with my first proposal for the info board, which they liked. I made a couple more proposals, feeling confident of my newly acquired basic skills.
                                            Watching the videos and then coming to forums like this one made all the difference for me. SketchUp has tons of features, but they're hidden and unless someone points you in the right direction, you would have never notice them unless you're extremely curious. The manual is boring and lifeless compared to the video tutorials. I hope most software companies follow Google's steps in creating such a good learning experience. I once tried to learn to use Form-Z, but finally got tired of trying to come to terms with the convoluted interface. Perhaps if Autodesys posted tutorial videos on Youtube...
                                            Now I feel the urge to tell all those who graduated with me to use SketchUp. The sad part is, most of them are not very fluent in English, and both GSU7 and the videos are currently English-only. I once taught design principles to a class of Freshmen. I guess it's time to become a teacher again...
                                            BTW, Where do I find the old issues of Catch Up?
                                            -Miguel Lescano
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 72
                                            • 73
                                            • 12 / 73
