    Wall, Door and Window schedules
    36 Posts 14 Posters 6.7k Views 14 Watching
    • pbacotP
      Oddly there is a similar discussion right now in the forum for my favorite 2d CAD application. People like the straightforward and accessible application, but wonder if it will grow into BIM. I am certain it will not happen in that application, and I doubt it would happen with SU. I don't even see SU as close to obtaining the tools I use for production CAD. But each application has it's own use. I think if aids are added in modeling in SU, which relate directly to how buildings are conceived, it will be a great thing. I don't think it will put SU on a path to BIM, nor need it be so; even though SU can already be used in some building analysis. Sometimes you have a continuous workflow. Sometimes you just use the right tool for a part of the project. I like to see SU become a bit "smarter" in modeling buildings, and be closer integrated with rendering, so I can flow towards that goal easier.
        Atl-Arch
        I am an architect using both Revit and SketchUP. In response to the Australian, everybody is not as fortunate as we are by having access to an expensive but powerful program as Revit. So as an introductory program into the wonderful world of 3D, wall tools for SU would be helpful to those just beginning. I had the opportunity last week to show Revit and SU to a new student majoring in interior design. I only had an hour so I spent 15-20 minutes in Revit and most of the time in SU, downloading furniture and whole rooms from 3D Warehouse. That really got her attention. The thing that she needed was wall thicknesses. We could build surfaces and offset them, then cut holes through both surfaces, but the tools Al is proposing would be a tremendous time saver new users like her.
        I started using CAD 25 years ago and think that Revit is the best and most intuitive ever for architects. SU is the best for mass modeling. Last week I needed to build a stone cap parapet for a sloped wall in Revit. After trying for half hour, I gave up and exported the wall out of Revit to DWG, imported it into SU. Built the parapet using "follow me" in 1 minute. Saved it, then imported it back into Revit. All the exporting and importing took longer than the creation of the object!
        How about a plugin for Revit that will let us do quick SU modeling inside Revit?
          jbpomy
          I use a hybrid system. I generate plans in a CAD software. Import that into SU for model generation and development of the buildings fenestration and roof lines. I then export the elevations back to my Cad software for CD completion. Idea 1 would be very useful for me. As would 3. I really don't do much as far as take-offs so 2 wouldn't be helpful for my uses.
          • Al HartA
            Al Hart
            These functions are currently only available on parametric BIM (Archicad/Revit) or pseudo-BIM (AutoDesk AutoCAD Archtictural, Nemetschek Vectorworks, Bentley Microstation Architecture) type software costing a lot of money. If you can get a simple functional (logical!) version into Sketchup, I for one, would buy it. I’m pretty sure there are a lot of people (including Google) trying to implement this given the new parametric capabilities of V7. But if you have access to any of the ‘big boys’ software, you can see how to do it wrong. Someone needs to do it right, and Sketchup with it’s tradition of simple and logical is a great place to start.
            Keep these replies coming.
            Frankly, when we discussed walls last week internally, we didn't think we could do much useful.
            Now we think that a routine which made individual 3D walls from the 2D wall polygon in SketchUp, and assigned attributes to the walls, and created a quick report would have some value.
            In this example, all 4 faces of the 2D wall layout would be converted to walls - each individual wall as a group, like the highlighted one. The we could assign attributes to each "wall", and report on lineal feet, square foot of wall, volume, etc. And the wall group would let us cut openings into both sides at once.
            Al Hart
            IRender nXt from Render Plus
            • pbacotP
              An interesting response from another CAD forum regarding BIM and where SU may fit in. In the post the term "PC" means "PowerCADD" a 2D drafting application.
              Interesting discussion. As a structural engineer, I work with a number of different architects who range from doing hand drafting to designing in Sketchup then having a drafter use the Sketchup model to create 2D cadd working drawings. I also see this move toward BIM as similar to the move to Cadd from hand drawings. In both cases, I see early adopters getting hurt-In the move to Cadd there were several large architectural firms in my area literally destroyed by their early move to Cadd-after a huge expenditure on workstations and training staff, when it came time to create the prints, they ran into major problems requiring yet more expense-and then a year later the equipment, software and staff training was all obsolete, requiring yet more major expense to stay current, but they were still paying for the initial expense and in some cases went under. I see the same thing with BIM-there are a number of products which are expensive to obtain and train staff to use. As a design office, the benefit to use is questionable, and at the same time the contractors mostly want the same 2D drawings which they know how to use.
              Last summer I decided to look more closely at using a BIM solution. My oldest son being a 3rd year Architectural student was able to obtain student versions of various programs for very low cost. I had a very complex large residential project, so I had him model (architectural only) the projects in Sketchup, Archicad, and Vectorworks. He had to learn to use each program. I felt this gave us a good feel for the learning curve and the abilities of the programs.
              Sketchup had a fast learning curve, and while he was frustrated at some reactions of the program to what he was trying to do, he was able to create very good models of roofs which had compound curvatures which helped me understand what the architect was trying to do and create framing that worked. Sketchup will cut line sections in dwg which I was able to import into PC as a starting point for my drawings.
              Archicad started off looking good, as it supposedly can create complete plan and section views from the 3D model. Very high learning curve, required some programing ability to do some things, and was not able to do some of the compound curvature that sketchup was able to do. We gave up on it after about 3 weeks.
              Vectorworks we did not stay with long-in comparison to the Sketchup/PC mode it was, in our opinion, 'jack of all trades, export at none'.
              Our conclusion was that it's going to be a long time before contractors want a BIM model in place of 2D drawings. On the projects where the architect did his design in Sketchup and then created 2D models, the contractors did use the models to supplement the drawings-but looked at this as a nice thing and in the end, still want paper 2D drawings.
              As a design office, the effort to create a BIM model and 2D drawings at least increased the effort 50%, which is not going to be paid for by the client. So we decided in the end, as an engineer, there was no benefit to me to move to a BIM software at this time. As an architect, he could see that a software solution which had the ease of use of Sketchup for creating a model and which would then easily extract basic plan and sections, which would then go into a PC type 2D mode to finish up as working drawings, would be ideal. None of the software that we tried does this well enough. Perhaps Google will add on a good 2D back end to sketchup-I think then this would go somewhere. Until then, I think it's a trap which will eat up the early adopters.
              • C
                cosmo99
                Hi Al and others.
                I think Atl-Arch has some interesting thoughts. I have taken a basic class in Revit and it definitely has some wonderful things going on for it. It is geared to those who are creating buildings on plots of land. I don't know if SU will ever do all what Revit can do. However, for my interests, mostly furniture and interior design, it seems like SU is just a lot easier to use. I feel like I struggle to create things in Revit, where as SU seems to "know" what I'm trying to do. I'm not sure if it's just my lack of practice in Revit or what? But for me, anything to make SU work better in a building design world would be great. On the other hand, if I were designing buildings for a living, I think I would use Revit and possibly import objects created in SU. However,I have tried this with mixed results. It would be great to hear from others who have worked with SU and Revit or SU and other programs.
                • C
                  cosmo99
                  Atl-Arch
                  I can relate to this. This is the type of thing that is hard to do in Revit and so easy in SU. There is a "follow me" type tool in Revit, but you have to remember so many steps to ever get to it. I think Atl-Arch is right, a plugin for SU in Revit would be interesting.
                  • Al HartA
                    Al Hart
                    Only rarely do we get any hints of what Google is planning - and then we can't tell anyone what we know.
                    In general, we believe (and/or hope) that they are more interested in making tools for things - e.g. Dynamic Components - and leaving to ruby programmers like us the task of implementing specific applications for them.
                    Another item we have on the back burner - perhaps as part of the Wall project - is second display window for SketchUp which would add 2D CAD items to the SketchUp drawing - but only display them in the 2D CAD window. (With SketchUp we can add anything we want to the model, but we can't change the way SketchUp displays things)
                    Al Hart
                    • C
                      cosmo99
                      Al Hart wrote talking about Google:
                      Al, I'm using your Irender nXt for Sketchup along with RpTools and RpEdits. I'm new at this stuff, but from the results I have gotten so far, I'm really impressed. And I hope they do leave you the job of implementing specific applications. The fact that you do so much to support those of us that use your products is worth a lot.
                        ashleyjoyce
                        Just following on from my comments before. SketchUp is great for doing presentation drawings in Architecture. Say for example you needed to do a perspective drawing of a commercial building around a city block. To Mass model a scene like that in sketchup is very easy and effective. You can add entourage, trees cars and create a wonderful scene extrememly quickly. You can then output the perspective line drawing as a jpeg and bring it into a software package like photoshop to add colour and more details. Architects may print out the line drawing add colour and details by hand and embellish even more details than scan the drawing into a package like photoshop for more processing. There is a great book called "Color Drawing" by Michael E. Doyle that demonstrates this process throughout his book to great effect. Now a BIM tool like Revit would be much more difficult in doing something like this quickly. SketchUp's free flowing nature is certainly an advantage here.
                        So SketchUp definitely has its own advantages over more expensive packages like Revit for jobs in the design process. I also agree with other earlier comments... "that SketchUp is a great tool for someone starting out and trying to learn the basics of architecture and design". Its a great educational tool!
                        However, over the years I've seen many Ruby developers attempt to add BIM like tools to SketchUp. Since discovering Revit, I now see its almost a pointless exercise because you don't want SketchUp to act in this way. Its much better to keep SketchUp the way it is, simple and effective for what it was primarily design for mass modelling and sketching.
                        For construction schedules, Revit is ideally suited. If an architect was modelling a commerical building they you just wouldn't attempt all the construction schedules using a package like SketchUp. It would be either Autocad or Revit.
                        The great thing about Revit is it is specifically designed to make this task even easier than Autocad if you know what your doing (the software can be difficult to learn). Because of the parametric nature Revit is much more powerful than Autocad for ongoing changes in the construction details. It also has very powerful rendering capabilities built in.
                        In saying all this, I don't work as a professional Architect. I'm still learning the profession. So therefore others might have a much better understanding than me in the professional arena.
                          ashleyjoyce
                          I found this good explanation on the difference between CAD, Revit & SketchUp in the book "Introducing Revit Architecture 2009".....
                          In 2D drafting CAD, you draw two lines (objects) to represent a wall.
                          In Revit, the task of creating a wall is presented in the form of an interactive tool name "Create Wall". This wall has properties like width, height, bearing or nonbearing, demolished or new, interior or exterior, fire rating, and materials (such as boards or brick). The wall interacts with other walls to automatically join geometries and clean up connections, showing how the walls will be built. Simiarly, if you add a door, its more than four lines and an arc, it's a door in plan and elevation. Adding it to the wall automatically creates an opening in the wall in all views where the door is visible. The tools available for walls are specific to walls, allowing you to attach walls to roof and floors, punch openings, and change layered construction of the wall. Again, all of these interactions are not just properties; they are focused on specific tasks associated with architectural walls.
                          BIM is more than a modeler. Other software packages, like SketchUp, Rhinoceros, and 3ds Max, are excellent modelling applications. However, these modelling applications don't have the ability to document your design for construction or leveraged downstream. This is not to say these tools don't play a part in a BIM workflow. Many architects use these tools to generate concept models, which can then be brought into a BIM application and progress through design, analysis and documentation.
                          • Al HartA
                            Al Hart
                            I use Sketchup routinely for Construction Documents. I work for a designer and we do a layout in AutoCAD and then I use Sketchup to flush it out and show the clients what it will look like before it's built. The things that you are talking about adding would help me in my work very much!! The way I work is I import the plan from AutoCAD and trace it out in Sketchup. I then use the "push" command to "raise" the walls to whatever height they need to be. Where this leaves me now is manually cutting out all window and door openings, and this is the most time consuming part of the build.
                            Another idea for a new "tool" would be something where I can take my standard "group" or "component" of a door or window and place it in a wall (which would be nice if the wall was one entity), and then if there was a way to "cut" the wall around the component at the click of a button. In other words, if I lay my door group into the wall where it goes and click this button the wall where the door is is cut out. Then if I hide the door there would be an opening there between rooms.
                            The other things that you mentioned in this email would all be great additions! Thanks for all you do.
                            Al Hart
                            • P
                              peweuk
                              I think that this is what the 'rectangle_hole.rb' at the Ruby Library Depot already does?
                              • Al HartA
                                Al Hart
                                it's great that you will enhance working with walls! Personally I mostly use
                                SketchUp for designing custom furniture into rooms, to find out how much
                                space they will take, how the room will look like after putting in the
                                furniture.
                                My biggest concern is that I didn't find a way to make walls transparent
                                from one side. Although I am not a computer graphics specialist, it seems to
                                me that in OpenGL surfaces are visible only from one side, and are
                                transparent from the other side by default. Is that so?
                                Imagine, that you have to design something in a rather small room. You put
                                up the walls (of just that room, not the entire flat), and put in the
                                object. If you also want to put in some lighting on the ceiling, you have to
                                close now the whole room, making a box. Navigating around in that box only
                                with the scroll wheel and the shift/ctrl buttons is a major annoyance. It
                                would be great if it was possible to create walls (and the ceiling!) with a
                                property, that they are transparent from one side. So it would not be
                                necessary to get into the room through a door, and try to look around, but
                                we could also look at the room from further away, looking through the wall
                                which would be behind us if we would be looking from within the room, and
                                seeing the other walls and the edges of the disappeared walls (and the
                                furniture of course) from further away.
                                Do you think this would make sense?
                                We did find a way to make transparent walls.
                                The make room command in RpTools makes rooms with transparent walls from the outside. Basically, if you place a transparent material on one side of a face, and a solid material on the other side, it will be transparent from one side, and opaque from the other. we haven't tried it with "thick" walls yet.
                                However, this is only going to work for you with a single room, since with two adjacent rooms, you would still have an opaque wall on the inside of the closest room.
                                I have attached a .SKP with a room with transparent walls.
                                SKP model with a transparent one-sided walls for a room
                                Another trick we have used in the past is to create short "stub walls" for temporary display, and place the stub walls in one layer, and the real walls in another layer, then you can turn on the short stub walls while placing furniture and use the real walls for interior renderings, etc.
                                Al Hart
                                • P
                                  peweuk
                                  What about a wall tool that creates 2 walls at the same time based on the input of the user.
                                  The first is one on a layer called 'transparent walls' which is 'on' by default - this is the single thin wall like in RPtools which is transparent and is in the same position as the inside face of the 'Real Wall'.
                                  The second is the real wall (or two walls for cavity type construction) set to the users required dimensions and placed on a layer 'Walls' which is turned off by default.
                                  At any time, the state of the 2 layers could be changed at the same time using the layers dialogue, or two 'scenes' could be created for quick viewing, each with the opposite layers turned on/off. When the job is finished if it is not needed anymore the 'transparent' layer and its contents could be deleted.
                                  Just a thought 😉
                                  • Al HartA
                                    Al Hart
                                    Just a thought 😉
                                    The "new walls" will probably put each wall in a group, so we can place two faces in one layer and one face in the other, as you suggest, and store bot in the same wall "group".
                                    The phrase "inside face" is one of our problems - because we aren't sure what is the inside of an interior wall. we may have to place the single face in the center, which will sometimes be confusing.
                                    The single face wall would be nice for placing openings though - because it would be easy to align the opening to the center of the wall, and cut the hole through all three faces.
                                    Al Hart
                                    • P
                                      peweuk
                                      I take your point AL. The problem with putting it in the center is that it would not make the placing of items on the real 'wall' very easy.
                                      What about creating two single transparent faces - one on each side of the 'wall' - or is this not do-able?
                                        SAB
                                        I work for a firm that does design and working drawings for small and large residential projects. We use Sketchup for preliminary design, visualization and some early cost analysis and use revit for working drawings. Sketchup allows us to model and revise very quickly. There are some tools available in sketchup (area etc.)that can give us information to check against current building costs in our area. The attribute tools in Su7 are allowing us to include more intelligence in our models to make feasibility studies easier. Automating this process with your proposed tools would be useful in our work flow if they can be implemented without weighing down the sketchup files and slowing the performance of the program. Creating 2d detailing of a large project for on site use by contractors would be nearly impossible in Sketchup. A combination of Sketchup and Layout could possibly be used for this on small projects. Concept, presentation and early design development are sketchup's current strong points and BIM software's weak points. This seems like a reasonable division of labour.
                                        If we run into issues with complex shapes in revit we use sketchup to make mass models and import them into revit. Complex roof design seems to be a recurring use for Sketchup in Revit. Interaction with sketchup is a little crudely but still effectively built-in to Revit already.
                                        We use Revit for structural, MEP and architectural working drawings. The accuracy of and speed with which we create the drawings has improved drastically since moving from Autocad to Revit. Every object in a Revit model is packed with information and has the option of having custom attributes added. The level of information stored in a Revit file allows great flexibility and fine grained information presentation. Getting enough information into a sketchup model to do this seems improbable.
                                        • C
                                          cgraham
                                          In my opinion, Sketchup has a long way to go to be a viable construction documentation tool. There are many other products out there that do the job much better that are (nearly) as cheap.
                                          I use the product for conceptual design and easy, quick renderings. So, instead of tweaking the minutae, I would rather see the product perform faster, with smaller file sizes. It is common for file sizes to quickly reach the 55MB range, and all manipulations within the file become a waiting contest, even with shadows off and faces set to monochrome.
                                          It would also be an enormous benefit if files could be "cross referenced" into the current model, instead of importing as dead files. With this feature, the cross referenced file could be modified separately, and then all the references would automatically update.
                                          So, it's like filling a container with multiple-sized balls. Get the big balls in first, and then the smaller balls can easily fit.
                                          • P
                                            peweuk
                                            Chalk and Cheese springs to mind when I follow this thread.
                                            High end construction/architectural programmes such as Revit seem to have been mentioned a few times in this thread now, comparing Sketchup to them from an Arhitetural point of view.
                                            I, personally, am not really concerned with taking models to that level - as I am sure is the case with a large number existing and potential Sketchup users.
                                            I have no experience of Revit and can only compare Sketchup with other 3D programs that I have looked at in an effort to establish what is best suited to the market I operate in - interior design.
                                            The main criteria in identifying a suitable program for the mass market of interior design that I have experience in (specifically the area of Kitchen, Bedroom, Bathroom design) are ;
                                            Ease of use
                                            Speed of design
                                            Cost
                                            Information output
                                            Quality of presentation
                                            (not necessarily in that order)
                                            There are a number of programs aimed specifically at this market and, having had experience of most of them, IMHO Sketchup comes near (if not at) the top.
                                            Having said that, Sketchup has a number of shortcomings which could be overcome with the development of additional tools, either as part of the program or the availability of external extensions, plug-ins or tools such as the one that Al started this thread to discuss.
                                            When I first looked at Sketchup it took me very little time to get to grips with it due to its simplicity of operation. Within a very short space of time I was able to understand it well enough to pass on what I had learnt and teach someone who had no Design software experience how to design a Kitchen in Sketchup spending no more than half an hour doing so. There is no way I could have done that with other interior design programs I have experienced - apart from one which I shall not mention. And Sketchup is far more flexible than all of them for a number of reasons.
                                            Having access to tools such as RPTools make the job even easier and access to additional tools, such as the Wall Tool Al is considering, would simply make the job even easier.
                                            The introduction of Dynamic Components in SU7 also now enables us to produce not only cutting lists, but cost reports and other information to suit our market that previously were missing in Sketchup.
                                            So ignoring full blown Construction/Architectural drawings (in the nicest possible way) I think that potentially Sketchup is more than capable of satisfying the needs of a vast market which could benefit from Sketchup in it's current form, and even more so with further development of both the program and external applications, extensions and plug-ins.
                                            So keep up the good work AL.
