    Offset Limited
    4 Posts 3 Posters 6.7k Views 3 Watching
    • B
      blair
      I am working with SKpro v7 trying to use push/pull behind a line of objects. Along the wall line I can raise the wall height to whatever height needed at some locations, if I break it down into segments. But if I try to do the entire wall I get the following message “Offset limited to 9”. Previously I have had this happen and could stop at the limited dimension and then start a 2nd push/pull ,from the limited location, and raise the wall to the desired height but sometimes I cannot. Anyone have any suggestions? I have tried removing stray lines etc., which does not solve the problem, but cannot find a solution.
        remus
        Could you post the model? hard to say what your specific problem is otherwise, for my limited brain anyway.
        • GaieusG
          Definitely the model would help. A lot of things can cause this. Sometimes grouping what you want to extrude - then exploding and intersecting with the model - helps but we should se what's going on.
          • B
            blair
            Gaieus and remus,
            Thanks for responding! I found the problem to be my newbie failure to recognize the importance of Groups and Componets and to use them.
