    Car (W.I.P.)
    36 Posts 13 Posters 4.1k Views 13 Watching
    • EarthMoverE
      EarthMover
      It's already apparent that your geometry is a mess. Try to keep your polygons cleaner and more evenly spaced. This will help make it easier to add details down the road. Also, as mentioned, you need to align your blueprints better.
      Maybe you should start by modeling the garage that the car is going to go in. Then move up to the car itself. The gallery is already over saturated with "look at my car WIP" threads.....why not do something original?
      Content Creator at Skapeup
      • B
        BTM
        earthmover... I couldn't agree more.
        • G
          guzman tierno
          Even with a "$2000 CAD program" you need to be highly skilled to draw a realistic car.
          Mike is right. Start with something more simple, this will help you improve your skills.
          If instead you keep on trying with the car, try to answer our posts.
          guzman.
          • marked001M
            marked001
            or at least individual components of the car, if architecture isnt your thing.. i'd say the simplest thing to start with would be a wheel/tire.... start out with that maybe.
            http://www.revision21vis.com
            instagram: revi21on
              dolphus
              just do your thing don,t take any notice of the "wise guys" comments whatever floats your boat and gives you a charge 👍
                Aernoud
                Yeah, just try it, you only have to know how to handle with polygons. But I should make the car with lesser poly's. Now you use too many polygons. The best is to do your best on this car. And a lot of practice is very helpfull! Then in the final you can make cars in sketchup ! (maybe its better to draw your own blueprints, and make completely your own car. Then you can make it a bit diffrent than the blueprint...)
                Currently SU project:
                • Metroid Prime large leviathan (own design)
                • Metroid prime plasma turret (own design)
                • Metroid prime Armour clubber (own design)
                • The Minas Tirith project
                • Mobile phone (own design)
                • K
                  KDSDESIGN
                  Well i while Back i said,
                  @kdsdesign said:
                  mike, if you read some posts (soon to be deleted)
                  "before getting a $2000 CAD program" so im just using sketchup until then lol
                  (I NEED TO STOP LOLing!)
                  Also I made a quick car tutorial. but thats about it
                  Regards,
                  █Kevin█
                  (about 20% done)
                  • P
                    pav_3j
                    hows this car getting on then KD? sunk any more time into it? i'd quite like to see the finished article.
                    Pav
                    Just won the 'Who is Least Competitive Championships' where trying to win will make you lose. Trying to lose makes you win which makes you lose. Not trying at all makes you lose which makes you win which makes you lose.
                    • G
                      guzman tierno
                      Hi Kevin,
                      Hope you dont mind,
                      I've seen your new cars, and your tutorial in the 3DWH,
                      car
                      car tutorial
                      you're really getting better !
                      About the tutorial:
                      • you still need to align the blueprints: wheels in the side, front and rear view should be at the same height, but the idea is correct and the result is not bad
                      • you could use scenes to make it easier to use
                      • K
                        KDSDESIGN
                        thats the simple way
                        Regards,
                        █Kevin█
                        (about 20% done)
                        • P
                          pav_3j
                          what is?
                          Pav
                          • K
                            KDSDESIGN
                            the tutorial ☀
                            Regards,
                            █Kevin█
                            (about 20% done)
                            • P
                              pav_3j
                              ah yeah i see. just like solo's video.
                              Pav
                              • K
                                KDSDESIGN
                                not many use this site, so i had too
                                Regards,
                                █Kevin█
                                (about 20% done)
                                • P
                                  pav_3j
                                  awfully sorry, you've lost me again. who is it that doesn't use this site so you had to do what?
                                  Pav
                                  • K
                                    KDSDESIGN
                                    PEOPLE WHO USE SKETCHUP.
                                    sorry bout the caps >_>
                                    Regards,
                                    █Kevin█
                                    (about 20% done)
                                    • P
                                      pav_3j
                                      So you made a tutorial for people who use SU but aren't on this site but can download it from 3d warehouse.
                                      It all becomes so much clearer now.
                                      time for bed.
                                      Pav
                                      • marked001M
                                        marked001
                                        i get what he's saying.... just like other people's models that he 'mods' and paints a different color..... he is doing the same now with someone else's tutorial..tweaking it slightly and spreading it to 3d warehouse.
                                        instagram: revi21on
                                        • K
                                          KDSDESIGN
                                          solo also used some random tool (that wasnt intersect)
                                          Regards,
                                          █Kevin█
                                          (about 20% done)
                                          • K
                                            KDSDESIGN
                                            I dont recolor, Fool.
                                            Regards,
                                            █Kevin█
                                            (about 20% done)
