    Car (W.I.P.)
    36 Posts 13 Posters 4.1k Views 13 Watching
    • marked001M
      marked001
      @earthmover said:
      Maybe you should start by modeling the garage that the car is going to go in. Then move up to the car itself.
      or at least individual components of the car, if architecture isnt your thing.. i'd say the simplest thing to start with would be a wheel/tire.... start out with that maybe.
      http://www.revision21vis.com
      instagram: revi21on
        dolphus
        just do your thing don,t take any notice of the "wise guys" comments whatever floats your boat and gives you a charge 👍
          Aernoud
          Yeah, just try it, you only have to know how to handle with polygons. But I should make the car with lesser poly's. Now you use too many polygons. The best is to do your best on this car. And a lot of practice is very helpfull! Then in the final you can make cars in sketchup ! (maybe its better to draw your own blueprints, and make completely your own car. Then you can make it a bit diffrent than the blueprint...)
          Currently SU project:
          • Metroid Prime large leviathan (own design)
          • Metroid prime plasma turret (own design)
          • Metroid prime Armour clubber (own design)
          • The Minas Tirith project
          • Mobile phone (own design)
          • K
            KDSDESIGN
            Well i while Back i said,
            @kdsdesign said:
            mike, if you read some posts (soon to be deleted)
            "before getting a $2000 CAD program" so im just using sketchup until then lol
            (I NEED TO STOP LOLing!)
            Also I made a quick car tutorial. but thats about it
            Regards,
            █Kevin█
            (about 20% done)
            • P
              pav_3j
              hows this car getting on then KD? sunk any more time into it? i'd quite like to see the finished article.
              Pav
              Just won the 'Who is Least Competitive Championships' where trying to win will make you lose. Trying to lose makes you win which makes you lose. Not trying at all makes you lose which makes you win which makes you lose.
              • G
                guzman tierno
                Hi Kevin,
                Hope you dont mind,
                I've seen your new cars, and your tutorial in the 3DWH,
                car
                car tutorial
                you're really getting better !
                About the tutorial:
                • you still need to align the blueprints: wheels in the side, front and rear view should be at the same height, but the idea is correct and the result is not bad
                • you could use scenes to make it easier to use
                • K
                  KDSDESIGN
                  thats the simple way
                  Regards,
                  █Kevin█
                  (about 20% done)
                  • P
                    pav_3j
                    what is?
                    Pav
                    • K
                      KDSDESIGN
                      the tutorial ☀
                      Regards,
                      █Kevin█
                      (about 20% done)
                      • P
                        pav_3j
                        ah yeah i see. just like solo's video.
                        Pav
                        • K
                          KDSDESIGN
                          not many use this site, so i had too
                          Regards,
                          █Kevin█
                          (about 20% done)
                          • P
                            pav_3j
                            awfully sorry, you've lost me again. who is it that doesn't use this site so you had to do what?
                            Pav
                            • K
                              KDSDESIGN
                              PEOPLE WHO USE SKETCHUP.
                              sorry bout the caps >_>
                              Regards,
                              █Kevin█
                              (about 20% done)
                              • P
                                pav_3j
                                So you made a tutorial for people who use SU but aren't on this site but can download it from 3d warehouse.
                                It all becomes so much clearer now.
                                time for bed.
                                Pav
                                • marked001M
                                  marked001
                                  i get what he's saying.... just like other people's models that he 'mods' and paints a different color..... he is doing the same now with someone else's tutorial..tweaking it slightly and spreading it to 3d warehouse.
                                  instagram: revi21on
                                  • K
                                    KDSDESIGN
                                    solo also used some random tool (that wasnt intersect)
                                    Regards,
                                    █Kevin█
                                    (about 20% done)
                                    • K
                                      KDSDESIGN
                                      I dont recolor, Fool.
                                      Regards,
                                      █Kevin█
                                      (about 20% done)
                                      • K
                                        KDSDESIGN
                                        Found A New Way of making cars. (using the tutorial)
                                        Regards,
                                        █Kevin█
                                        (about 20% done)
                                        • EarthMoverE
                                          EarthMover
                                          Kevin, why don't you find a new hobby? Maybe if you spent more time modeling and less time posting asinine and uninterpretable half sentences, you would be able to produce something that almost resembles a model. You have been nothing but rude and combative, and not to mention ungrateful. It's gotten to the point that every time I see a post of yours, I literally cringe. I hate to say this, but IMO, you should be banned from this site. 👎 👎 👎
                                          I feel bad for all the people who are genuinely posting quality models and looking for constructive feedback, but yet, they get pushed off of the page with less than a few hundred views. Meanwhile, you clutter this forum with page after page of bumping your own threads to post your incoherent, rambling, one liners. 🤢
                                          Content Creator at Skapeup
                                          • K
                                            KDSDESIGN
                                            HaHaHaHa LMFAO 🤣 Yeah BUMPING. Its Fine Till we get those 2 year olds. Yeah.... i still have to check here everyday just for boerdom.. now unless you want to join my foe club,(very popular btw...) i would sugest comments. now because of these posts saying no W.I.P. Photos (?) there arent any 😄
                                            Hopfully you people wont mess this: http://www.sketchucation.com/forums/scf/viewtopic.php?t=12931 up with
                                            Pav
                                            Regards,
                                            █Kevin█
                                            (about 20% done)
                                            • 2 / 2
