    Car (W.I.P.)
    36 Posts 13 Posters 3.8k Views 13 Watching
      guzman tierno
      Hi Kevin,
      **First.**You should align the blueprints. It seems to me that they're not aligned.
      For instance the blueprint of the rear of the car should be lowered.
      Second. In order for someone to help you (if there's someone still available) it might be useful attaching the skp file.
      Third. When drawing a line in space you should always use at least two blueprints to detect the endpoints of the line. It seems to me that you only use one sometimes, like in the side windows of the car. This is very important. That's the role of having three blueprints.
      Fourth. It would probably be easier starting by using the method that Pete clearly illustrated in the other thread (video). That method, also helps to undertand how blueprints work.
      You make contours of the three blueprints, you pull them, you intersect everything and you erase the extra parts.
      Finally. Think twice before posting one-line comments and one-word comments, they usually aren't that useful.
      Hope this helps.
      (Try to reply to this post after facing these issues)
      • Mike LuceyM Offline
        Mike Lucey
        Kevin,
        Using SketchUp to build a car is NOT a good idea unless you are highly skilled. I suggest you think about a new model and we will work with you on it 👍
        Mike
          KDSDESIGN
          mike, if you read some posts (soon to be deleted)
          "before getting a $2000 CAD program" so im just using sketchup until then lol
          (I NEED TO STOP LOLing!)
          Regards,
          █Kevin█
          (about 20% done)
          • StinkieS Offline
            Stinkie
            It might be a good idea, by the way, to try the demo of Moment of Inspiration. That app may be somewhat more useful for obtaining the sort of shapes you're after.
            MoI, 3D modeling for designers and artists
            MoI is a new 3D Modeling/CAD application for designers and artists. Offering a blend of precision and freeform NURBS drawing tools, it sports a unique user interface that operates seamlessly with a pen tablet.
            (moi3d.com)
            • EarthMoverE Offline
              EarthMover
              It's already apparent that your geometry is a mess. Try to keep your polygons cleaner and more evenly spaced. This will help make it easier to add details down the road. Also, as mentioned, you need to align your blueprints better.
              Maybe you should start by modeling the garage that the car is going to go in. Then move up to the car itself. The gallery is already over saturated with "look at my car WIP" threads.....why not do something original?
              Content Creator at Skapeup
                BTM
                earthmover... I couldn't agree more.
                  guzman tierno
                  Even with a "$2000 CAD program" you need to be highly skilled to draw a realistic car.
                  Mike is right. Start with something more simple, this will help you improve your skills.
                  If instead you keep on trying with the car, try to answer our posts.
                  guzman.
                  • marked001M Offline
                    marked001
                    or at least individual components of the car, if architecture isnt your thing.. i'd say the simplest thing to start with would be a wheel/tire.... start out with that maybe.
                    http://www.revision21vis.com
                    instagram: revi21on
                      dolphus
                      just do your thing don,t take any notice of the "wise guys" comments whatever floats your boat and gives you a charge 👍
                        Aernoud
                        Yeah, just try it, you only have to know how to handle with polygons. But I should make the car with lesser poly's. Now you use too many polygons. The best is to do your best on this car. And a lot of practice is very helpfull! Then in the final you can make cars in sketchup ! (maybe its better to draw your own blueprints, and make completely your own car. Then you can make it a bit diffrent than the blueprint...)
                        Currently SU project:
                        • Metroid Prime large leviathan (own design)
                        • Metroid prime plasma turret (own design)
                        • Metroid prime Armour clubber (own design)
                        • The Minas Tirith project
                        • Mobile phone (own design)
                          KDSDESIGN
                          Well i while Back i said,
                          Also I made a quick car tutorial. but thats about it
                          Regards,
                          █Kevin█
                          (about 20% done)
                            pav_3j
                            hows this car getting on then KD? sunk any more time into it? i'd quite like to see the finished article.
                            Pav
                            Just won the 'Who is Least Competitive Championships' where trying to win will make you lose. Trying to lose makes you win which makes you lose. Not trying at all makes you lose which makes you win which makes you lose.
                              guzman tierno
                              Hi Kevin,
                              Hope you dont mind,
                              I've seen your new cars, and your tutorial in the 3DWH,
                              car
                              car tutorial
                              you're really getting better !
                              About the tutorial:
                              • you still need to align the blueprints: wheels in the side, front and rear view should be at the same height, but the idea is correct and the result is not bad
                              • you could use scenes to make it easier to use
                                KDSDESIGN
                                thats the simple way
                                Regards,
                                █Kevin█
                                (about 20% done)
                                  pav_3j
                                  what is?
                                  Pav
                                    KDSDESIGN
                                    the tutorial ☀
                                    Regards,
                                    █Kevin█
                                    (about 20% done)
                                      pav_3j
                                      ah yeah i see. just like solo's video.
                                      Pav
                                        KDSDESIGN
                                        not many use this site, so i had too
                                        Regards,
                                        █Kevin█
                                        (about 20% done)
                                          pav_3j
                                          awfully sorry, you've lost me again. who is it that doesn't use this site so you had to do what?
                                          Pav
                                            KDSDESIGN
                                            PEOPLE WHO USE SKETCHUP.
                                            sorry bout the caps >_>
                                            Regards,
                                            █Kevin█
                                            (about 20% done)
