    Problem rendering out in V-Ray, PLEASE HELP!!
    renderpluginsextensions
    4 Posts 3 Posters 1.4k Views 3 Watching
    • N Offline
      n8s07ss
      I am having problems rendering an interior scene. The problem I'm having is that after I hit the render button, V-Ray processes the scene for about 5 minutes, then cancels the render. There is no error message, it just stops processing the scene. I tried rendering smaller scenes on the same machine with the same session of S.U. & V-Ray open and it works fine. This leads me to believe that it is a problem with this particular file. Other things I have tried is to turn off all of the furniture, make the entire model a component (cutting it's size by 70%), try numerous vispot files, but nothing has worked so far. Is it possible that the file is corrupted?
      The model I'm working with is 30.9 MB, and has lots of furniture & lighting components which I fear may be too complex for my machine to handle when rendering. The machine I'm running it on has an Intel duo core 2.83 Ghz processor and 3.5 GB of RAM, so I can't believe that I'm overloading the machine, but my experience with V-Ray is limited. Thanks for any help or advice.
      • EarthMoverE Offline
        EarthMover
        I've had this happen before, but I don't remember exactly the culprit. Are you using the newest version? Try purging your model and pasting all the geometry into a new SU file. Make sure all your materials are applied only to base geometry and try again. If that doesn't work, I would try exploding everything.
        Content Creator at Skapeup
        • dcauldwellD Offline
          dcauldwell
          Well, at 30Mb, your model isn't very large. Problems can occur especially with nested components. If you have a lot of these then vray may just be giving up on them. So I don't think that making the whole model a group is going to help. The other issue is large textures. Sometimes if these are very big then it can cause crashes.
          Saving the model and re-opening it just before rendering is worth a try - gives a clean model.
          It is worth checking the 'render progress' in the seperate window which opens, to see if it crashes at a particular point, which may help you to diagnose the problem.
          I would make a copy of the model and explode any nested components. then save it and re-open it and then try rendering it.
          Hope this helps
          David
          Sketchup 2017
          (vray 2.00)
          • N Offline
            n8s07ss
            Thanks for the advice, but I traced the problem to an outdated version of v-ray. Apparently a new release was recently made available that fixes such bugs. Still great advice for future problems.
