    Film & Stage plugin
    23 Posts 16 Posters 4.6k Views 16 Watching
    • AdamBA Offline
      AdamB
      Ahh. Thanks guys, you learn something every day.
      Is this a well used feature? It seems to have drifted off into the long grass.
      Adam
        CubicPnoOut.rb (for an export to QT Panorama) also creates thes bars (but at leat you can create image output with your cutom ratio and not confined to the SU window ratio)
        • RichardR Offline
          Richard
          Adam for me I use it every day!! I find it helps to set a border to the likely size I want for output. So yes for some!
          [BUILTBRAND.COM.AU](http://builtbrand.com.au/)
            Where do you download the latest for this plugin? I can only find one for SU5: http://sketchup.google.com/download/previousplugins.html
            Searching for it only takes me to lots of video tutorial on it which doesn't help as long as I can't get hold of it... 😞
              Dik Harrison
              thomthom,
              I ran into the same thing, as far as I know that is it, there is not a new version. Although it makes sense to me that with the functionality of DCs, a new version would be great.
              Have fun...
              Dik
              • Chris FullmerC Offline
                Yes, that is the current version and it works with v7. But there are a lot of small bugs with the way it dollies and pans (or something like that). If I recall they were attempting to fix it and found more problems than they were ready to deal with at the time and now it still has not been updated. Its a great plugin.
                  Yes,I remember a testing period about a year ago but then haven't heard of it being released.
                    I see. Well it did install all right on SU7. And I was mostly interested in prodding and poking the ruby codes. πŸ˜„
                    • JClementsJ Offline
                      JClements
                      Regarding FILM & STAGE.
                      I have heard that it had been re-evaluated for update/improving/fixing. It seemed that there was a consensus that it either really needed to be totally reworked or rewritten. Evidently, there were other things of higher priority for the Boulder folks to tackle.
                      IT IS MY OPINION that SOMETHING should be done to give PRO-licensees a good, intuitive, thorough, and precision set of camera tools inwhich the camera could be controlled via user input values and/or cursor keys and/or shortcut keys and to store preset screen aspect ratios. Getting good transistion between scenes relying upon the mouse and steady hand and replicating output to match previous project output quickly and easily is not adequate for "professional" presentations.
                      Perhaps, if SketchUcation forum members make a conserted and "loud" plea, Boulder will reprioritize a replacement for Film and Stage and other needed camera tools. And do it soon.
                      Regards,
                      John
                      • scottliningerS Offline
                        scottlininger
                        Wow, when it's in bold red how could we not respond. πŸ˜‰
                        The Film & Stage plugin has been on our target list for updating for some time, but as you say we have limited resources and it didn't make the cut for SU7.
                        So in the list above, what is missing from Film & Stage? I'm happy to dive back into that discussion.
                        Cheers,
                        • Scott Lininger
                          SketchUp Software Engineer
                          Have you visited the Ruby API Docs?
                          I was thinking that part of what was broken was all the pan and dolly commands. To me those are less important than the aspect ratio control and physical camera creation. It can be very useful to have a physical camera at times, to really understand whats going on in walkthroughs.
                            Pan an dolly could be ideal for creating images that can be assembled as 3D images - you know the ones that you watch with those fancy red and green glasses.
                            • FletchF Offline
                              Fletch
                              well, Scott, if you're taking requests,
                              I would like a 'physical camera' mode that at least lets me interactively in a sketch-up-like-manner chose the focal point so that all render engines could grab the data automatically thru their respective plugins. The other phys. cam. properties wouldn't be a bad idea. While these can't be 'seen' in SU, they would be utilized by other plugins I think.
                              (I've never used the film & stage plugin, so don't know if this is already in there.)
                              Fletch
                                rdwilkins
                                "The Film & Stage plugin has been on our target list for updating for some time, but as you say we have limited resources and it didn't make the cut for SU7.
                                Scott,
                                I was exchanging e-mails with Bryce Stout during the beta-testing period and told him that this is something that those of us in the film industry really need to have addressed. The Film and Stage plug-in was great for locking the aspect ratio but we need a way of inputting accurate lens data as well.
                                i could never understand why the angle of view was so different until I figured out Sketchup uses the vertical rather than horizontal field of view, whereas we normally use the horizontal number, for instance in Super 35 format all the ratios (1.78, 1.85 and 2.40) have the same horizontal angle of view. Only the vertical angle is different.
                                I've developed a series of wireframes for each format that I insert into my models to calibrate the window for the aspect ratio. Once that is done I can input the lens data from my conversion sheets to show a specific lens, both film or HD lenses. As far as I know no one has their software configured to allow for digital lenses yet.
                                I'd be happy to send you all my lens data. I've been writing an article for the Art Directors Guild magazine on my method of calibrating the program for specific lenses but hopefully you can make that method unnecesssary.
                                If you could work this into the program you'd have legions of grateful fans here in Hollywood. I use Sketchup on every film and it just gets better all the time.
                                Randall Wilkins
                                  Jim
                                  Hello Randall,
                                  Who can say when the Film and Stage plugin will be updated; and although I don't know exactly what you mean about calibrating the window, it sounds as if automating your work-around is possible using an interim plugin.
                                  Maybe if you posted a request in the Ruby Forum, someone will be able to help.
                                    I just ran into this myself when I wanted to illustrate on a plan drawing where the view I had created was taken from. I drew a triangle where the angle between two of the lines matched the AOF su reported only to find out that the lines would not match what was seen in the scenes.
                                    I think that an ruby is in order here to rectify this. I'll see what I can do when I get some spare time.
                                    • cmeedC Offline
                                      cmeed
                                      Working as a visualiser for a set designer I really would like to see an update to this feature.
                                      Please
                                      Pretty please
                                        Just found this thread: http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=9321&p=145393
                                        If you open the Ruby Console and type in Sketchup.send_action 10624 it opens a window which allows you to change SU's behaviour so it sets the AOV horizontally instead of vertically.
