    [Req] Similar groups to Components
    28 Posts 9 Posters 3.4k Views 9 Watching
    • free agentF Offline
      free agent
      haha thanx Rick i understand i have a similar 2 year old project at home πŸ˜†
      • FletchF Offline
        Fletch
        the applyto command sounds interesting, but if you have several similar groups that you have just turned into components and need to replace them with the 'good' component, you don't need another tool... when you have the other "bad" components selected, just right-click the 'good' component thumbnail in the components>in model dialog , and choose 'replace'... no need to place them by hand one at a time... they orient correctly this way too... in my experience.
        I almost never make groups and can't see why one would make a group instead of a component.
        I use groups to group things like 'hi poly furniture' and drop the entire group on a layer to shut off that stuff quickly. I would never make a component of that group! πŸ˜†
        I use this technique all the time to group phases of a project, put the phases on layers, and control display of phases for clients using Scenes and layer visibility... I wouldn't make components of those phases either... your model size would skyrocket.
        Fletch
          RickW
          That's true, but if things are on-screen already, IMO it's easier to have ApplyTo installed rather than try to find the component in the browser (which can be quite a challenge if you have a lot of components and several similar ones at that.
          RickW
          [www.smustard.com](http://www.smustard.com)
            free agent
            how to replace the components is irrelevant really because u need to turn those similar groups into components first πŸ˜›
              matt77
              Hi all
              What we need ideally is something similar to TIG's explode to groups, which works like a dream. So you'd make one group. Run the script explode to components. All that was within the main group would be converted to a component that then could be instantly replaced.
              I suppose the whole point of a specific component is that its uniform..
              and doing it this way things more than likely wont start like that.
              just a thought..
              it would be very handy, could be used for instancing trees etc..
              many thanks
              Matt
                sorgesu
                SketchUp does do much of this for you. If you have a group and decide that you want to make it a component instead, all you need to do is select the group and "make component". The dialogue will not appear because all of the properties are already in place. However, if you go to the in model tab of your component browser, you will find that you have a component called "group#1" and you can edit and change its name and other properties.
                If the group had been nested inside another component then all instances of the group would automatically be replaced. However, if a group is nested inside of a component, editing the group will change it in all of the nested components anyway.
                Susan Sorger
                Former Seller Hand Rendered Entourage
                Former Canadian Authorized Training Centre, SketchUp
                  free agent
                  thanx for that... please read my first post
                    sorgesu
                    I read your post then and now. I gave you what I've got. If the information doesn't prove helpful in any way now or in the future, you won't have to use it.
                    Susan Sorger
                      free agent
                      we all know the accrobatics we can do with groups or components or apple pie when its inside a component in the first place, or that we can make one of those groups a singular (all those similar groups will not become components of the same instance), my request was for a way to make similar groups into separate components of the same instance...
                        free agent
                        bump
                        • Chris FullmerC Offline
                          You should note that it was bumbed because the plugin was developed and posted in this thread:
                          301 Moved Permanently
                          (www.sketchucation.com)
                          So if anyone finds this thread, they will also know where to go to get the answer πŸ˜„
                            free agent
                            your right 😳
                              camilo_caicedo
                              See http://sketchucation.com/forums/viewtopic.php?t=17590
                              • 2 / 2
