    Is it possible to model this material in sketchup?
    24 Posts 8 Posters 5.7k Views 8 Watching
      skaught
      It is pretty meandering lol, but I think I can do it right next time. Thanks for helping me. My next giant hurdle will be to make a box out of this stuff and have all of the grooves line up. It sort of makes my head hurt when i think about it.
        skaught
        btw...your sketchup file wasn't there before...I just opened it and it's awesome....although i still can't figure out exactly how you did it.
        Thanks again.
        • Wo3DanW Offline
          Wo3Dan
          If you are still looking, here is my attempt in attached model.
          I think I can do better now after this first one, adding a few steps to it, getting closer to the real thing.
          Wo3Dan
          sanddunes.skp
            skaught
            looks damn good! There are a few different variations of this material and your model looks pretty much exact to a # of them. If you scroll down this link you can see some of the ones that match.
            http://www.interlam-design.com/Art_Product_Search.cfm
            It's a pretty bada$$ product.
            How did you do it?
              skaught
              How do you slice geometry? and what is the purpose of doing that....outside of this particular situation?
                remus
                The easiest way to 'slice' geometry is to get a load of planes that intersect th surface, select the whole lot->right click-> intersect with selected. Youll then need to delete any unwanted geometry.
                The purpose of this is to create more control points for FFD to work with, as it can only distort corners and not lines, so by intersecting the model with lots of planes you are creating lots more corners for the plugin to work on.
                  skaught
                  ah ha! knowing that helps a lot! especially when using FFD to distort flat shapes smoothly and accurately. Great to know that, thanks!
                  • Wo3DanW Offline
                    Wo3Dan
                    How did you do it?
                    skaught,
                    (sorry for the delay.)
                    Here is a model explaining how it can be done with only SU + sandbox tool.
                    The technique is simple but laborious.
                    One note. With the smoove tool you can input an offset. But unlike with other tools you type the value first and then release the mouse button.
                    See this model in 3DW:
                    http://sketchup.google.com/3dwarehouse/details?mid=68b60c0a964174c5b2dd3120ca5e0662
                    Wo3Dan
                      guzman tierno
                      Your material may be approximated as the sum of two types of waves, the big ones and the tiny ones.
                      The big ones are a sin function, while the small ones have some cusps.
                      I wrote a formula for your material:
                      z = ( ((x-floor(x))*2 - 1)^2 - 1 )/3 + 1 * sin(x/2 - y/6)
                      it reproduces the dunes of your material,
                      you can have a look at the result in the image or by going to
                      http://www.archimy.com/ and pasting the code
                      tmin = -12
                      tmax = 12
                      tgrid = 2000
                      x = t
                      z = ( ((t-floor(t))*2-1)^2 - 1 )/3 + 1 * sin(t/2 - y/6)
                      ["Floor" stands for the "bigger integer number less than"]
                      You can change the numbers to tune the result:
                      z = ( ((t-floor(t))*2-1)^2 - 1)/3 + sin(x/2 - y/6) * 1
                      y/6 -> change the 6 to change the angle between waves
                      ( ((t-floor(t))*2-1)^2 - 1)/3 -> change the 3 to change small waves height
                      1 * sin(x/2 - y/6) -> change the 1 to change big waves height
                      x/2 -> change the 2 to change the ratio between small and big waves
                      You're allowed to use decimal numbers.
                      I dont know how to draw a graph in SU.
                      Hope this helps.
                        guzman tierno
                        I can imagine some improvements to the function but
                        I didnt want to make things too involved.
                          skaught
                          holy crap I have a lot to learn...
                          will be back!
                          edit: I seems a little ridiculous to just keep saying thank you again and again...but damn, thank you again. I guess I can't really say I'm teaching myself this program anymore.
                            skaught
                            too late. lol
                              guzman tierno
                              @skaught said:
                              too late. lol
                                jzer7
                                This might not be exactly what you are looking for, but Jim Foltz wrote a plugin that allows you to generate 2-D graphs in SU. It is called "eq_grapher.rb", and you can get it from the Ruby Library Depot (http://www.crai.archi.fr/RubyLibraryDepot/Ruby/em_edi_page.htm). The script iterates in x only, but it can be extended to sweep both x and y coordinates or even a parametric variable (look at method self.graph), thus accomplishing what you want.
                                I took the liberty to modify the script to do this in 3D in case you guys are curious. And here is a sample output.
                                A sample output of the script.
                                The script can certainly be improved, but then this might be a subject for the scripting forum 😉
                                Juan
                                Ruby Script to produce a crude 3D plot.
                                  kwistenbiebel
                                  Wow, that is a very cool script you made there Juan.
                                  I don't know if there are a lot of Rhino users here, but if Ruby can do 2d/3d graph curves, maybe a graphical algorythm plugin could be made for SU, much like the Grasshopper plugin for Rhino, which is an amazing tool in the right hands and a wonderful solution to do parametric organic architecture.
                                  The cool thing about Grasshopper is that you are doing 'non destructive' modeling, meaning that your organic skyscraper can be controlled by changing parameters (for instance a 2D vector image to control openings in your facades etc...)
                                  Link:http://grasshopper.rhino3d.com/
                                    guzman tierno
                                    Wow jzer7, that's actually a very cool script, thanks.
                                      jzer7
                                      Thanks.
                                      I forgot to mention, I put a better version of it in the Scripting forum (Plugin - Surface Plotter). Among other things it fills in the surfaces bounded by the lines. I am also working on a plugin that can do parametric surfaces (like spheres, spirals, etc.)
