    Problems with Export fileformat
    extensions
    16 Posts 5 Posters 2.7k Views 5 Watching
    • GaieusG
      Thanks Regis,
      This was exactly the piece of info I wasn't aware of. Good to know - although obviously not good news to Vrecors.
      • V
        Vercors
        So, here: http://www.3d-software.ch/fileadmin/pdf/SketchUp_Maxwell_Tutorial/tutorial_sketchUp_maxwellrender.pdf
        They say "With our Demoversions of SketchUp and MaxwellRender and this tutorial..." it should work.
        Don't stop the progress Bar!
        50%
        ██████████________________________________|
          REGIS
          Yes it should work with SU pro demo version but not with google sketchup free.
          The plugin toolbar appears in the free version but I think he's disabled, it doesn't export nothing.
          I've tried it last year and now I'm with Kerkythea, Indigo works fine too with google sketchup free.
          Regards
          • V
            Vercors
            First of all, thank you for the help, but before I download it, 2 questions:
            Is it possible to transfer a Model from the free Google SketchUp to the SketchUp Pro demo?
            And can the Demo be used endless or just a certain time?
            50%
              REGIS
              Yes, the demo read a file made with the free.
              Only 8 hours of use, when you close the demo, the counter stop.
              When you've used it 8 hours, it becomes a free version with no way to use maxwell render plugin exporter anymore.
              Really, I don't understand why Maxwell doesn't let the plugin run with the free version.
              Good luck with Maxwell render.
              Regards
              • V
                Vercors
                Seems to work.
                Thank you for the help everyone.
                I think I'll keep modelling in the free SketchUp version and use the demo just for exporting.
                50%
                  REGIS
                  Sure maxwell exporter run fine with SUpro
                  Great idea 😄
                  Regards
                  • jolranJ
                    jolran
                    I think it is bad marketing not supporting the free version with their plugins 😡 Fryrender appears to be the same.
                    Probably the plugins have use of SU pro exporters as well 😄
                    Well theres a cheaper alternative for importing skp and exporting (At least) 3ds.
                    http://www.3dpaintbrush.com/learnmore/default.aspx
                    I consider buying it just to be able to export 3ds with ease.
                    Havent tried it long enough to see if its consistent though.
                    It imports skp files. 😉 99 euro.
                    • GaieusG
                      Unfortunately that won't work. You cannot run SU Free and Pro at the same time. What now you installed has probably overridden your free app OR if you installed it to a different place, while modeling in the "free" version will also eat up your 8 hours.
                      What you can/could do however is to install SU 6 Pro, work in SU 7 (now trial - later free eval), svae back in SU 6 format and use the SU 6 Pro version only for exporting.
                      • V
                        Vercors
                        So, I also own a laptop because of my job.
                        I will install MaxwellRender and SketchUp Pro Demo on the laptop or the compter, don't know for sure. I can continue modelling with the free SketchUp, transfer the file to the other computer, then export it and transfer it back, because I already have Maxwell on one computer. Then I can continue working. 😉
                        50%
                        • GaieusG
                          That's another alternative - wise thinking! 😉
                          • honoluludesktopH
                            honoluludesktop
                            I once read a post on this forum that points to a plugin that fools SU into believing that SU free is SU pro in a limited range of situations. If however this is a Boo Hoo, please forget I mentioned it.
