    Preferences>Image Editor for MAC
    27 Posts 12 Posters 4.6k Views 12 Watching
      sorgesu
      There is now a direct function from within SketchUp that allows you to select an applied texture on a face and that snippet gets transferred to the assigned image editor. ( its a right click for the textures context menu and it is a sub menu item under that. When you finish with it in your image editor it gets returned to the same spot in SketchUp and you can actually merge it with the rest of the texture.
      So MAC people don't get the equivalent of "paint" you say? Really?
      Susan Sorger
      Former Seller Hand Rendered Entourage
      Former Canadian Authorized Training Centre, SketchUp
      • K
        Kazai
        Not sure about Iphoto will do the task. If you want to see if there's any Mac freewares that can do image editings, you can try looking up the Pure Mac web site ( http://www.pure-mac.com/ ) and go to Graphics under Multimedia. Mac version's GIMP is listed there. Also, you can try the free version of ArtRage at http://www.ambientdesign.com/artrage.html.
        Hope this will help.
        vince
        • pbacotP
          Poor Susan, no one quite understands. To confirm.
          Nope, iPhoto is not an image editor of the sort one would use.
          Nope, Apple does not ship a default pixel editing tool with the OS.
          (From what I hear, Paint is not that useful either? I know you just need it for an example.)
            sorgesu
            Thank you. That is a direct answer. Everyone, you were all so very kind to answer and I really do apperciate it that you all tried so hard to help me. But yes, you weren't quite understanding.
            No paint doesn't do anything much and we'll problably do no more than some silly scribble on the image.
            I suppose even iphoto would do even if it does nothing just to show that we can exit and re-enter.
            If you could just confirm the path????? Thanks much.
            Susan Sorger
            • pbacotP
              /Applications/iPhoto
              • O
                otb designworks
                Susan, the path to iphoto is:
                Macintosh HD/Applications/iphoto
                As was mentioned before, though, iphoto is basically useless and you may be doing your students a disservice in steering them that direction. Perhaps better to suggest GraphicConverter, Photoshop, Gimp, etc.
                The path to those would be identical to the one I have above, though with some (photoshop, for sure) has an additional folder you need to bore through to get to the actual program.
                Macintosh HD/Applications/Adobe Photoshop CS3/Adobe Photoshop CS3 for example
                Cheers, Chuck
                OTB Designworks is on Youtube
                • Chris FullmerC
                  This really is a remarkably painful thread Susan..... Good luck,
                  • EdsonE
                    Edson
                    iphoto is more of a picture organizer. macs do not ship with any app for photo editing.
                    http://www.mahfuz.arq.br
                      sorgesu
                      Funny, you guys are so good at reading and understanding very complicated instructions on using software applications.
                      If I could ask just one more thing, and please if you don't mind, no more kind suggestions of any other program to use, Iphoto will do for the demonstration: wouldn't the correct path end with iphoto.app as in the visual example from sketchUP way above with gimp which is gimp.app?
                      Thanks much. Thanks Chris.
                      Susan Sorger
                      • O
                        otb designworks
                        yes.
                        /applications/iphoto.app
                        Cheers, Chuck
                          sorgesu
                          Thank you!!
                          Susan Sorger
                          • P
                            Peter Gunn
                            Susan:
                            Preview is built-in to the Mac OS and has basic editing abilities. Check it out and see if it does what you need. I discovered this when I was needing to resize and touch up some images.
                            • nickN
                              nick
                              @sorgesu said:
                              Thank you!!
                              If I can just add my two bob's worth hopefully answering your question about mac image editors - if you set your Sketchup preferences (Applications - applications for editing image files - /Applications/iPhoto.app), as mentioned; and then set your iPhoto preferences (General - edit photo - full screen) you end up in the iPhoto editor.
                              This is an image editor for photos more than anything else (and not a bad one) but at least it will show the functioning of the in-Sketchup edit texture image process.
                              Cheers
                              Nick
                              • 2 / 2
