    [Plugin] follow me rotate
    211 Posts 79 Posters 263.7k Views 79 Watching
      kilgo
      Trying to get this plug in to work for me. I am on a mac 10.4.11, Sketchup Pro. Works well if I push/pull a face where the path is connected to it. It will not follow for a path that is not curved though. However, what I am trying to accomplish is a coil that follows a circular path (winds around the path). I have removed all of the plug-ins and restated with no results, trashed the .plist, but no joy yet.
      This example is on the thread[url]viewtopic.php?f=180&t=13014&start=0&st=0&sk=t&sd=a[/url]
      what exactly is a "construction point" cause this is just what I needed to do.
      Screen grab of thread
        Maybe this can help you πŸ˜‰
        For weld a curve used the plug linked πŸ˜‰
        The Plug Weld 3.0 by RickW (free) at Smustard.com β˜€
        • W Offline
          wikii
          look the pic
          .jpg
            kilgo
            Wiki, Thanks for the reply.
            I made an observation using the supplied SKP file that you included with the .rb file called "far.skp"
            Opening the file and looking at the last model I notice that the vertical line segmented. When I apply the FFR ruby to this line and its shape the ruby functions well as in your examples. But if I draw a line that has no segments it does not behave the same way. The plug in fails to activate, it acually doesnt do anything after selecting it.
            segments
            successful
            Unsegmented Line
            unsuccessful
            • W Offline
              wikii
              The path must be a curve which is constructed with several segments!
                maxosmedia
                not for macintosh again πŸ‘Ž 😞
                  Matt666
                  A simple Push-Pull can do that πŸ˜•
                  Frenglish at its best !
                  My scripts
                    kilgo
                    Matt,
                    Wiki's ruby is designed to "Twist" the shape as it follows the path. Do you mean the push pull tool will rotate a shape as well as extrude it?
                    • F Offline
                      Frank0503
                      Thank you so much, so your plugin you share that truly the key of "follow me rotate"
                        AthidhiTM
                        thanks dude
                          CAD Addict
                          It doesn't seem to work with straight paths. If the path I use is a curve it works, if it is a straight line it doesn't do anything. Is that how it is supposed to work?
                          http://www.cad-addict.com
                            Jim57
                            It works on Macintosh running 10.5.6. Get the .zip file if you have trouble with the .rar.
                            Wow, this is a great pluginβ€” thanks!!!!
                            It blows up on me if I scale up more than about 1.1. Looks like it scales once for every segment on the lineβ€” I was expecting it to scale over the whole length. This makes for a very sensitive scaling feature.
                              @cad addict said:
                              Yes.
                                boilingsnow
                                @cad addict said:
                                you can divide a line into many segments and then weld them again.
                                It works!
                                  Jim57
                                  I love what this does!
                                  While it worked fine for me at first, now I'm having troubles. If anyone has fixes, let me know, I need this script!
                                  -sometimes the script reverses the follow line. It starts from one side, but when I select the script it flips to the other.
                                  -sometimes the script does not work, even after welding my follow lines religiously
                                  -sometimes all the script does is place a 2" long construction line on the underside of the face, one segment's length away from the face.
                                  -I just tried again. The first time, it didn't work. The second try, it placed the 2" construction line on the underside and reversed the path. The third try, it worked great, with the path coming from an offcenter construction point. The following five times, it shifted the path from the construction line to the center of the face and, other than that, worked.
                                  -not a bug, but a feature request: as I posted earlier, scaling and rotation are per segment of the follow path, not over the whole length. It might be more intuitive and controllable if they were measured over the whole path.
                                  Again I will repeat, I always weld my follow lines or use unexploded curves. I'm using FAR on a Mac and some posters feel it is Win onlyβ€” Is this the issue? SU seems buggier as I use FAR, though this may be coincidence, or confusing the cause and effect.
                                  Thanks for any assistance,
                                  Jim
                                    Jim57
                                    I checked the Ruby Console at some point during my last experiments, and here's what I was getting:
                                    fError: #<ArgumentError: Cannot create unit vector from zero length vector>
                                    (eval):340:in intersect_line_plane' (eval):340:in wikii_push_pull'
                                    (eval):339:in collect' (eval):339:in wikii_push_pull'
                                    (eval):319:in each_index' (eval):319:in wikii_push_pull'
                                    (eval):141
                                    (eval):340:in `call'
                                    (eval):340
                                    Error: #<TypeError: can't convert Symbol into String>
                                    I don't seem to be able to reset the Console without quitting and restarting Sketchup, so it's hard to tell at what stage things were going wrong.
                                      sepo
                                      This video does not work for me. I have only black screen.
                                        Click Draw
                                        Hi Miguel,
                                        Great tutorial. I noticed some quick shots of your tools which don't look familiar. Would you mind posting a screen shot of your tools so I can see what ones you have that I don't?
                                        Thanks,
                                        Jeff
                                        Have I mentioned how much of a laugh I get out of some of the Signatures on here!
                                          "...in response to this tutorial found on the web:"
                                          I wish I could see your video. I've tried the plugin but it doesn't yield the same thing I showed in the tutorial. I did the tutorial without the plugin because of that and because I was asked to demonstrate a manual way of drawing that.
                                          • Jean-FrancoJ Offline
                                            Jean-Franco
                                            +1 with Sepo !
                                            Jean-Franco
                                            • 11
                                            • 4 / 11
