    Windows and Mac...are the Ruby the same for both?
    8 Posts 5 Posters 682 Views 5 Watching
      Click Draw
      Hi there,
      I'm wondering if I can copy my plugins folder off my PC and copy it into a Mac Plugins folder?
      Thanks,
      Jeff
      Have I mentioned how much of a laugh I get out of some of the Signatures on here!
        remus
        Yep, should work fine.
          Click Draw
          Thanks Remus! Appreciate the speedy reply.
          Jeff
            BTM
            Normally, yes. Unfortunately, That's not the case for many of the rubys/extensions I've downloaded. The latest skin.rb, for instance, doesn't seem to run on macs. (although, the feature to clean up unnecessary lines still works)
            • CadFatherC Offline
              CadFather
              confirm - tried once on a mac (my plugins folder) and got quite a few errors - cleaned those, yet some scripts were still not working anyway.
              i think you will have to go the long 'try one by one' way - or else hope for more mac pros replies..
                remus
                seems i'll have to revise my statement to 'yep, should work fine for some things, although you might have problems with some plugins.'
                I suppose the first thing to do is to just copy the whole lot across and see what errors you get, from there you might be able to work out which plugins arent working and then remove them.
                • EdsonE Offline
                  Edson
                  i would say about 90% of the plugins around work fine on mac.
                  http://www.mahfuz.arq.br
                    Click Draw
                    Thanks for everyones input. I'll pass it on to my friend.
