    Barn WIP
    56 Posts 5 Posters 3.4k Views 5 Watching
      Mannie
      Thanks will try that. However i needed a break from this started ti miss vue hehe, so i did a render of what i had now to see how it would look in vue and i must say that i am quite pleased with the result even though it isn't finnished yet.
      http://www.mannie-things.eu/barn-wip/test.jpg
        Now that's superb! Even of a half ready model that's already a nice render, congrats! πŸ‘
        • soloS Offline
          Mannie that looks great, if I may make one observation, the wall panels seem to bump out at the seams, try reversing the bump in the material editor in Vue. (negative value)
            Mannie
            Good tip Solo, thanks. These textures where the free low res ones from arroway, i'm looking at my budget and maybe buy that disc cause good textures will do alot to the model. πŸ‘
              Mannie
              I'm getting all kinds of weird shapes but nothing like a barrel lol
              • soloS Offline
                try this quick tut.
                basic barrel.skp
                  Mannie
                  Thanks, i'll try that tomorow. Tonight i'm not doing anything on the pc
                    Mannie
                    Ok , im halfway thru the tut, now i am stuck at the step where you copy it 24 times around the rim. How does that work do i have to copy it manually 24x and rotate each or is there a fast way to do this ?
                      Hi Mannie,
                      That's done with the Rotate tool and the Ctrl button. This way you don't only copy the thng but by typing the number of copies and hitting enter you can make multiple copies.
                      Rad more srolling down to "Radial arrays" here:
                      http://download.sketchup.com/sketchuphelp/gsu6_win/Content/D-Modification_Tools/ModTool-Rotate.htm
                        Mannie
                        That's what i was trying but what i be getting each time is weird stuff like this πŸŽ‰
                          Because you are rotating those pieces around a corner of them. You should select the one you make first then get the centerpoint of the circle and rotate them around the centre of the circle. Right click on the circle line and select Centerpoint to get a guide point in the centre.
                            Mannie
                            Well i just don't get it, call me stupid lol πŸ˜‰
                              No, I don't want to call you stupid.
                              Now you have one piece of that barrel nicely aligned along one segment of the circle, right?
                              1. select the piece with the Select tool (the piece is highlighted)
                              2. Place the Rotate tool onto the centerpoint of the circle
                              3. Press Ctrl (to make copies)
                              4. click onto one endpoint of the piece to start the rotation
                              5. click on the other side of it to finish the rotation (now you have made one copy)
                              6. now type 23 (don't click into the box to type just type) and hit enter (no need to type 24 since the original piece is the one to which we aded 23 now)
                                So just try it again! πŸ‘
                                Mannie
                                Thanks, will try that, made a ladder instead just now in the meantime πŸ˜‰
                                • soloS Offline
                                  Csaba, I normally type x23.
                                  Anyway, mannie I hope this helps:
                                  http://img399.imageshack.us/img399/5838/circlearrayvl3.gif
                                    Mannie
                                    Ah, that is easier to follow thanks Solo, gonna give this a try in a few mins πŸ˜‰
                                    just finnished the ladder πŸ˜‰
                                      @solo said:
                                      Csaba, I normally type x23...
                                      😳 Yes, exactly. Sorry Mannie for misleading you! 😳
                                        Mannie
                                        Almmost i guess, except for the openings betweeen the planks that is. πŸ˜‰
                                          Mannie
                                          with straight planks i can do it now πŸ˜‰
                                            I think an easier way is to use the follow me tool.
                                            Attached is a file. When you open it,
                                            1. click on the surface of the circle with the Select tool (note that I exploded the circle to get the pieces to be faceded instead of softened but it could have been done by lowering the softening angle as well)
                                            2. then click on the face of the piece with the Follow me tool
                                              If you still want to assemble it from pieces, now turn one of them into a component, delete the rest and do the radial array with this component (they will obviously fit nicely).
                                            Barrel.skp
                                            • 2 / 3
