    Line union
    4 Posts 2 Posters 431 Views 2 Watching
      jukkoo
      hi, I need some help. Is there a way to tape together 2 lines.
      example: a made an arc which for some reason I needed to break into 2 arcs. how can I reverse this action so that i can select the entire arc with one click, so that it doesnt show a line on the curved extruded plane of that arc. Have to soften edges every action I make is frustrating. Also it becomes annoying to have to select all the pieces of a broken arc if I want offset it.
      Thanx for the help
      • ToboboT Offline
        Tobobo
        jukkoo,
        What you need is a ruby script called 'Weld'.
        (www.smustard.com)
        This is your best bet.
        Toby
        Philippians 4:13
          jukkoo
          tnx, works like a charm
          • ToboboT Offline
            Tobobo
            Hakuna Matata
            Toby
            Philippians 4:13
