    A Welcome Message to New SketchUcation Members
    1.4k Posts 667 Posters 617.0k Views 667 Watching
      mateo soletic
      Iwan,
      Welcome to the Community πŸ˜„
      [Concept Illustrations](http://concept-illustrations.com/)
        Hi Iwan and welcome!
        • N Offline
          neurone
          Hello friends,
          I have joined this forum today and just wanted to say Hi to all
          you noobs and pros out there.I am new Sketchup user,so I guess I will just sit and watch! πŸ‘
            Hi Neurone and welcome!
            I think you joined the best time πŸ˜‰
            • jolranJ Offline
              jolran
              Hi fine people in here! Just wanted to say hi! πŸ˜„
              I joined this forum some weeks ago. have some or maybe little (hard to say) experience in XSI, Zbrush and Carrara. Im was initialy only gonna use some fastlearing program to do a drawing/rendering of my upcoming home renovation. Tried everything you could download. Wanted to do 2d drawings so mainly went
              for those options. Then did some doodeling in SU and stuck I got and here I am.
              Fantastic program and easy to learn. .Especially if you compare it to XSI monster.
              So now I will realise my model in 3D
              I have a maybe hard to answer question:
              Im probably going to render in Carrara and use the 3ds import.
              So question is should I upgrade to pro or get Okina converter. The money is
              about the same but the converter seems to to be more extensive:
              http://www.okino.com/conv/imp_sketchup.htm
              An comparison of SUnative exporter and okina would be very helpful.
              Best regards/ Joel
                Hi Joel and welcome!
                Your story about getting stuck with SU is somewhat similar to mine so I can fully understand.
                Anyway, I don't know this Okina converter so I could only suggest to try out the SU trial version of Pro which will let you work a full 8 hours in active mode.
                The main difficulty with SU is that when exporting textures, it can eitherpreserve UV co-ordinates orweld vertices - not both.
                • jolranJ Offline
                  jolran
                  Hello Gaieus! Thank you for your answer!
                  Im acctually trying the pro version right now and 3ds export to Carrara seems to be working. Having some grouping problems, Su model gets imported as 1 mesh although full hierarchy checked, but maybe its fixable. 3ds triangulation is annyoing. Particulary if I going to make som adjustments in Carrara 5
                  after import.
                  I will investigate. Maybe its interessting for someone else. Maybe the workflow
                  SU - Carrara could be of interrest to someone else. Good rendering options and it got sliders πŸ˜„
                  Thank you! Helpful forum!
                  • AnssiA Offline
                    Anssi
                    There was a free version of Carrara 5 on the PC Pro DVD a couple of issues back. I used to play with an older version (2 or 3) and SU. Rendering architectural models in the older versions was a bit difficult, as it seems to me that Carrara was somehow designed for smaller objects. Also, radiosity renders were not so easy to set out, especially with emissive materials. I have to check if the newer version has improved on things.
                    Anssi
                    • jolranJ Offline
                      jolran
                      Hi Anssi!:-)
                      Im also using version 5 although I recceived ver 7 beta couple days ago.
                      Daz is the owner now and updates are somewhat contedrelated πŸ˜‰
                      AAh! Yes radiosity setting. I agree. Scene get overexposed? Did you use HDRI?
                      Did some testrenders yesterday, and sure a lot of testing but with low antialaising and few photons renders go fairly quick. I like it that you get
                      a good overwiew over all the settings. hate Xsi where you have to go in different
                      windows and remember exactly what you have done. Im not that good.
                      Bare in mind I have very little experience in those other internal renderingprograms like podium etc, and if Im not wrong updated versions are on the way, so they may be more suitable for SU.
                      However if Lightup will export FBX wich Carrara can import things might start
                      getting fun.
                      Thank you for responding.
                      • W Offline
                        woodstock
                        Hi all, just joined today having followed some links for the plugins available on here...really excellent stuff!! so useful.
                        im a 2nd year architecture student and have started using sketch up in a much more thorough way and more advanced way recently, modelling much more complex buildings and landscapes rather than just using it as more of a drafting tool in the early stages of the design process like i was previously.
                        been really inspired by what i have seen here, you guys have really opened my eyes to what can be achieved with sketch up.
                        one area i am really using sketch up in which is proving very succesful is as a basis for hand drawings, using the sketch up renders and models as a basis to draw over to gain more accuracy in the drawings but retaining a more artistic and conceptual presentation to the images, and with some basic photoshoping im getting some nice results.
                        if anyone here has been doing similar things would really appreciate any helpful advice on how to further progress using this technique or be able to see some examples of work from more profesional sources.
                        cheers, and looking forward to continuing to be inspired by the stuff im seeing here.
                        ps hope this is in the right place
                        • soloS Offline
                          Welcome to GSCF woodstock (I guess that's not your real name, or if indeed it is you were conceived in 1969 during the party of the century πŸ˜‰ )
                          Glad you could make it here, make yourself at home.
                          • N Offline
                            neng83
                            Hi, My name is Neng, I just join a week ago, I knew about SketchUp because I was working on a design and I need program to help me modeling my design I dig and dig and dig and dig some more till I SketchUp I love it, please forgive me if I ask any stupid question in here
                            Real Newby πŸ˜„
                              Hi Neneg and welcome!
                              There are no stupid questions at all, so just ask whatever you are not clear about! πŸ‘
                                Patrick.H
                                Hello, My name is Patrick. I have been using sketchup for some time now, mainly to make ships and putting them onto Virtual sailor. I joined to see if i can learn anything new and have a look at what can be achieved with SU.
                                Regards, Patrick.
                                • boofredlayB Offline
                                  boofredlay
                                  Welcome Patrick.
                                    paul smith
                                    Hello all, registered a few days ago but didn't announce myself to the wider world. I have been digging about the forums and found lots of really useful stuff already and also been humbled with the quality and generosity of the SU community. Its script heaven here. Been using Sketchup since those @last days mostly to work out tricky design junctions in building construction. More recently I have been using it with Piranesi and V-ray for visualisations. Lots of questions shall be asked on lighting and shadow..tbc. Well that's my life story. Thank's in advance for the future help, and I will do what I can.
                                    All the best,
                                    Paul
                                      Hello Patrick and Paul and welcome!
                                      Patrick; I am a ship fan myself - looking forward to see some of your work!
                                      Paul; if you have been using SU since the @Last days, you are not really a "newbie" but of course everyone has a lot to learn and I also wonder many times how much there is out there.
                                      There are some folks here using both Piranesi and V-ray
                                        JCDESIGN
                                        %(#000080)[Hi there! Im a sketchup user since 07 but i never knew that SU could do so much more..ive been using the basic SU for a year now.. and i was indeed happy with it before..but knowing that plug ins can be added is way better!! although i need help with it.. Can you please POST a complete List of plug-ins that are Available??? there are so many and i dont know if i missed any important ones i could use haha please! if its ok πŸ˜„ because i need to master it come january because i would be defending my thesis and hopefully graduate and become an Industrial Designer come march.
                                        And since SU is so user friendly i would use it for my thesis. i hope that you could help me out all you PRO's of skecth up! CHEERS! -
                                        JCDEZIGN from the philippines πŸ˜„ -> Yezzur! Represent! πŸ˜›][/color]
                                          Hi JC and welcome to GSCF!
                                          As for a complete list of rubies? You must be kidding 8or rather not know too much about the abundance of the plugins...) There are literally hundreds and thousands of plugins starting from very simple ones to really complex ones.
                                          Have a look at the "Resources" page in the Ruby forum - scroll down to the bottom to see general and special collections of plugins. I doubt that there is anyone who would have tried all of them.
                                          • F Offline
                                            Fatolbaldguy
                                            Hi my name is Ron. I am a Webcomic artist and I am always trying to expand my horizons a bit. My comic Magical_Misfits is a Fantasy comic with a twist in that it happens in the future. Anyway my main character the dwarf Wheels Ironkeel has a star ship named Starworth I would really like to Model the Starworth (and eventually all the ships in the story). A fellow artist turned me onto this program and I must say I am floored. I just started watching the videos and I have managed the basic shape of the old space truck but I have so much to learn!. I have way more questions than I can even begin to ask today and I will refrain until I have watched more of the videos. Anyway Hello
                                            http://i49.photobucket.com/albums/f262/magicalmisfits/Starworthstudy.jpg
                                            Due to financial constraints the light at the end of the tunnel will be extinguished until further notice.
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 72
                                            • 73
                                            • 22 / 73
