    A Welcome Message to New SketchUcation Members
    1.4k Posts 667 Posters 1.2m Views 667 Watching
    • W
      wheay
      hi im wheay,(forum name) 😍
      im new in this forum. i hope ill get a lot of information. i know i will..
      not a beginner in sketchup.. but i think there are lot of things i still need to know in sketchup. so pls. be kind to me. thanks.
      "i try to learn everyday"
      http://designerslandmark.blogspot.com/
      • GaieusG
        Hi Wheay and welcome πŸ‘
        Be assured that we are kicking kind! πŸ˜„
        • boofredlayB
          boofredlay
          Welcome Wheay ❗
          • I
            iwanwidjaja
            Hi, i'm iwan
            new user here, greets to the other's
            expect for a lot of advise using sketchup and KT πŸ˜ƒ
              mateo soletic
              Iwan,
              Welcome to the Community πŸ˜„
              Concept Illustrations
              • GaieusG
                Hi Iwan and welcome!
                • N
                  neurone
                  Hello friends,
                  I have joined this forum today and just wanted to say Hi to all
                  you noobs and pros out there.I am new Sketchup user,so I guess I will just sit and watch! πŸ‘
                  • GaieusG
                    Hi Neurone and welcome!
                    I think you joined the best time πŸ˜‰
                    • jolranJ
                      jolran
                      Hi fine people in here! Just wanted to say hi! πŸ˜„
                      I joined this forum some weeks ago. have some or maybe little (hard to say) experience in XSI, Zbrush and Carrara. Im was initialy only gonna use some fastlearing program to do a drawing/rendering of my upcoming home renovation. Tried everything you could download. Wanted to do 2d drawings so mainly went
                      for those options. Then did some doodeling in SU and stuck I got and here I am.
                      Fantastic program and easy to learn. .Especially if you compare it to XSI monster.
                      So now I will realise my model in 3D
                      I have a maybe hard to answer question:
                      Im probably going to render in Carrara and use the 3ds import.
                      So question is should I upgrade to pro or get Okina converter. The money is
                      about the same but the converter seems to to be more extensive:
                      http://www.okino.com/conv/imp_sketchup.htm
                      An comparison of SUnative exporter and okina would be very helpful.
                      Best regards/ Joel
                      • GaieusG
                        Hi Joel and welcome!
                        Your story about getting stuck with SU is somewhat similar to mine so I can fully understand.
                        Anyway, I don't know this Okina converter so I could only suggest to try out the SU trial version of Pro which will let you work a full 8 hours in active mode.
                        The main difficulty with SU is that when exporting textures, it can eitherpreserve UV co-ordinates orweld vertices - not both.
                        • jolranJ
                          jolran
                          Hello Gaieus! Thank you for your answer!
                          Im acctually trying the pro version right now and 3ds export to Carrara seems to be working. Having some grouping problems, Su model gets imported as 1 mesh although full hierarchy checked, but maybe its fixable. 3ds triangulation is annyoing. Particulary if I going to make som adjustments in Carrara 5
                          after import.
                          I will investigate. Maybe its interessting for someone else. Maybe the workflow
                          SU - Carrara could be of interrest to someone else. Good rendering options and it got sliders πŸ˜„
                          Thank you! Helpful forum!
                          • AnssiA
                            Anssi
                            There was a free version of Carrara 5 on the PC Pro DVD a couple of issues back. I used to play with an older version (2 or 3) and SU. Rendering architectural models in the older versions was a bit difficult, as it seems to me that Carrara was somehow designed for smaller objects. Also, radiosity renders were not so easy to set out, especially with emissive materials. I have to check if the newer version has improved on things.
                            Anssi
                            • jolranJ
                              jolran
                              Hi Anssi!:-)
                              Im also using version 5 although I recceived ver 7 beta couple days ago.
                              Daz is the owner now and updates are somewhat contedrelated πŸ˜‰
                              AAh! Yes radiosity setting. I agree. Scene get overexposed? Did you use HDRI?
                              Did some testrenders yesterday, and sure a lot of testing but with low antialaising and few photons renders go fairly quick. I like it that you get
                              a good overwiew over all the settings. hate Xsi where you have to go in different
                              windows and remember exactly what you have done. Im not that good.
                              Bare in mind I have very little experience in those other internal renderingprograms like podium etc, and if Im not wrong updated versions are on the way, so they may be more suitable for SU.
                              However if Lightup will export FBX wich Carrara can import things might start
                              getting fun.
                              Thank you for responding.
                              • W
                                woodstock
                                Hi all, just joined today having followed some links for the plugins available on here...really excellent stuff!! so useful.
                                im a 2nd year architecture student and have started using sketch up in a much more thorough way and more advanced way recently, modelling much more complex buildings and landscapes rather than just using it as more of a drafting tool in the early stages of the design process like i was previously.
                                been really inspired by what i have seen here, you guys have really opened my eyes to what can be achieved with sketch up.
                                one area i am really using sketch up in which is proving very succesful is as a basis for hand drawings, using the sketch up renders and models as a basis to draw over to gain more accuracy in the drawings but retaining a more artistic and conceptual presentation to the images, and with some basic photoshoping im getting some nice results.
                                if anyone here has been doing similar things would really appreciate any helpful advice on how to further progress using this technique or be able to see some examples of work from more profesional sources.
                                cheers, and looking forward to continuing to be inspired by the stuff im seeing here.
                                ps hope this is in the right place
                                • soloS
                                  Welcome to GSCF woodstock (I guess that's not your real name, or if indeed it is you were conceived in 1969 during the party of the century πŸ˜‰ )
                                  Glad you could make it here, make yourself at home.
                                  • N
                                    neng83
                                    Hi, My name is Neng, I just join a week ago, I knew about SketchUp because I was working on a design and I need program to help me modeling my design I dig and dig and dig and dig some more till I SketchUp I love it, please forgive me if I ask any stupid question in here
                                    Real Newby πŸ˜„
                                    • GaieusG
                                      Hi Neneg and welcome!
                                      There are no stupid questions at all, so just ask whatever you are not clear about! πŸ‘
                                      • P
                                        Patrick.H
                                        Hello, My name is Patrick. I have been using sketchup for some time now, mainly to make ships and putting them onto Virtual sailor. I joined to see if i can learn anything new and have a look at what can be achieved with SU.
                                        Regards, Patrick.
                                        • boofredlayB
                                          boofredlay
                                          Welcome Patrick.
                                          • P
                                            paul smith
                                            Hello all, registered a few days ago but didn't announce myself to the wider world. I have been digging about the forums and found lots of really useful stuff already and also been humbled with the quality and generosity of the SU community. Its script heaven here. Been using Sketchup since those @last days mostly to work out tricky design junctions in building construction. More recently I have been using it with Piranesi and V-ray for visualisations. Lots of questions shall be asked on lighting and shadow..tbc. Well that's my life story. Thank's in advance for the future help, and I will do what I can.
                                            All the best,
                                            Paul
                                            • 11
                                            • 72
                                            • 73
                                            • 9 / 73
