    Fractal Tree Maker for SketchUp - Free add-on
    extensions
    158 Posts 44 Posters 57.5k Views 44 Watching
    • Al HartA Offline
      Al Hart
      @solo said:
      Heads up for the Podium users, when you create your tree you must explode it then regroup/compnent for it to be recognised in render.
      Did you have to explode the image into a face (hopefully not - because then it would cast a rectangular shadow). If it is a simple fix in the component structure, we can probably make the component that way in the first place.
      So let me know precisely what you did to make the tree work.
      Al Hart
      IRender nXt from Render Plus
        Stu
        Hey Al, this is just great!! Thanks heaps!
        I can see an explosion of vegetation in SU models!
        And it will cast a shadow in Podium [after I exploded and grouped the tree]
        http://www.landesign.com.au
        • Chris FullmerC Offline
          Simply amazing Al! Thanks for this,
            remus
            I look forward to giving this a go, looks like tis really good.
              at3D
              I have loaded the link but once back in SketchUp 6(Pro) and selecting the plugin nothing is happening...any suggestions?
                at3D
                Stu, I have installed and located within SU but when pressed to, what I hope will activate, nothing happens in SU.
                My machine is running Vista, could this be an issue?
                • BurkhardB Offline
                  Burkhard
                  Thanks Al, very useful. And continue your great work at Renderplus. πŸ‘
                  http://www.ia-plus.de
                    Stu
                    Nup, Im running it with Vista and XP
                    • Alan FraserA Offline
                      Alan Fraser
                      Excellent Plugin Al. It's good to hear that it's technically possible to load new bark textures also. Regarding resolution, I've found in manually doing this stuff for FF that a resolution of about 800 pixels high for an average tree was a reasonable compromise between detail and file size, so the 900 setting ought to be about right for most uses. Pngs can get pretty big above that, as you say. On the other hand I've never found the graphics processing to be much of a problem with a decent card....not as much of a bottleneck as the geometry, anyway.
                      Who knows? It might be possible to combine different resolutions in a DC, giving differing LOD at various distances.
                      Is there any way to adjust the angle of view in a future release? I'm sure Stu and others would find it very useful to produce maybe 45 degree down versions as well as plan views for layouts.
                      3D Figures
                        Hi Al,
                        This looks fantastic! A long time needed and superb tool for those with inferior talents/expertise in PS work and such (not to speak about time needed even for experts to create something like this).
                        And all this for free! πŸ‘
                        That was my first thought as well. And instancing these trees with Component spray tool makes really easy to create various background treelines of lower resolution samples.
                        If I may... I will immediately share this topic with my home mates down in the FL forums! β˜€
                          Stu
                          at3D.....it should be in your plugin folder...?
                          And some autumn shades
                          EDIT:
                          Apart from anything else this is a lot of fun and the range of shapes is pretty limitless. I dont think smaller shrubs will be too much of a problem.
                          And about a 20 minute learning curve πŸ˜„
                            Okay, my little "contribution"; a hazelnut like tree (at least that's what I indended to create):
                            http://sketchup.google.com/3dwarehouse/details?mid=439c4d6359efd9e3ffe3705437c1b39c
                            ...this is a "medium quality" (600 pixel) output of the tree maker. I wanted to create something that is similar to a hazelnut tree/bush and well... this is the first trial. It has roots as well so I placed the origin a bit higher so that the roots merge into the ground a bit but this way some of the branches do so. πŸ˜„ ...
                            And a screenshot:
                            This is a great tool, Al!
                              Very interesting plugin.
                                Nice one, Alan; I haven't cared for the shadows this time (yet). Though it increases file size as well, if you mean to use it in native SU,it is necessary.
                                Another one of mine; a "Silver birch" (like) tree:
                                http://sketchup.google.com/3dwarehouse/details?mid=3df72c0a4f7104a3ffe3705437c1b39c
                                And the screenshot:
                                This time I think with a bit more crooked branches than in reality (BTW is this silver birch?)
                                  richcat
                                  Al your a
                                  http://nxt.accurender.com/emoticons/emotion-30.gif
                                  Leaf if attached if body wants.
                                  Take a look at AndriyG81 for some bark textures.http://www.sketchucation.com/forums/scf/viewtopic.php?f=40&t=13226
                                    Hi Richcat,
                                    Thanks for the leaf! And surely there are a couple of superb bark textures down there! πŸ‘
                                      digby dart
                                      Thanks Al Hart. πŸ˜„
                                      • soloS Offline
                                        Al
                                        When making Palm trees the bend option shows in the raytrace but not in the component, it straightens out.
                                          Alan Fraser
                                          Fill yer boots.
                                          http://local.wasp.uwa.edu.au/~pbourke/texture_colour/bark/
                                          Plus all the leaves you could ever want.
                                          Note: these are links to collections, not the images themselves.
                                          http://www.3dmd.net/gallery/index-22-page-1.html
                                          3D Figures
                                            richcat
                                            Heres another link from old post by ilay7k on leafs, but I have not tried it out yet http://www.polas.net/download/leaves.php
                                            • 1 / 8
