    Google Sketchup Pro 7 is out
    300 Posts 100 Posters 87.9k Views 100 Watching
      paulside
      I know that Layout is meant to be a presentation tool to display models created in Sketchup and looking at Layout 2 there have indeed been big improvements to enable this,
      But does nobody at Sketchup understand the need for a set of simple basic Cad design tools that can be used within Layout to convey details that may not be related to the actual model, but related to the project as a whole,
      There are a whole lot of current and more importantly potential users out here just waiting for this.
      Ah Well, we'll just have to live in hope for Sketchup 8.
      • StinkieS Offline
        Stinkie
        Just a bit of clarification.
        1. handle high poly count.
        One of SketchUp's lead developers, John Bacus, has actually asked users at Basecamp exactly what this means. High poly support when orbiting, when modeling, with or without inference.
        You see everybody whining about this feature but no one comes with any specifics and when they are asked for them no one replies. So by all means, SPECIFY what you mean with high poly support.
        ... huh? Coen doesn't know what we mean if we 'whine' about high poly support?
        Every other modeler worth its weight is handling millions and millions of poly's and maybe choking, not SU........it chokes on hundreds of thousands! Come on!
        Yes Scott, but the fact of the matter is that those applications don't support inferencing and/or not in such a superb way.
        If I turn off Edges and Profiles I can easily handle 500.000 Faces as well. But I was earlier talking about a model with just 50K Faces in a normal inference enabled scene. When you turn off Edges and Profile the inference engine is likely to be switched off as well (though I'm not sure about this) and whatever be the case it DOES provide me with 10x higher framerate.
        ... well, whaddaya know ... he does know what it means. I'm sure John Bacus does as well. πŸ˜„
        Coen, I don't mind if you defend SU. Not at all even. But I would like you to do it without dodgy rhetorics. Pretty please?
          remus
          Stinkie, that is what the developers told us. I dont see any reason for not clearly defining what is meant when you say high poly support.
          • Mike LuceyM Offline
            Mike Lucey
            Paul, I agree with what you say about the need for better 2D
            drafting capability in SU and LO2 and I believe you are right
            in saying that such features would be welcomed by many. It
            would in deed be a big seller for Google but I doubt SU will
            go this route as it is my understanding that SU policy is to
            'shake hands' rather than compete with 2D applications.
            Still, as you say one never knows πŸ˜‰
            Mike
            • StinkieS Offline
              Stinkie
              Remus, come on.
              • Alan FraserA Offline
                Alan Fraser
                Juan is right about installing as administrator if you are on Vista. I had problems with this during the beta. I guess that many more people are now on Vista than 2 years ago, so you may also find problems in re-installing some of the Plugins. I did, until I wrestled control of the Plugins folder back off my darned OS....even with admin priviliges.
                3D Figures
                  remus
                  Stinkie, im kind of between an NDA and a hard place, but to parphrase: do you mean better orbiting capabilities? faster modelling? do you still want inference to be on? specifics, essentially.
                  • StinkieS Offline
                    Stinkie
                    Aha. I meant: better orbiting capabilities with inferencing on. As it stands now, SU is brought to a crawl quite quickly when you import a couple of, say, nicely detailed sofas. Orbiting can be quite cumbersome in such a case. Shame, really. πŸ˜„
                    lol. The joys of Vista. πŸ˜†
                    • StinkieS Offline
                      Stinkie
                      @burkhard said:
                      Remus, come on.
                      What kind of discussions. No need to clarify anything if you are a simple user.
                      High poly support is selfexplanationed. To convert it is for professionals.
                      Hopefully you never had a ruby whish where you were forced to explain the coder how to do it. πŸ˜‰
                      Well said, Herr B. (Mind you, remus, this is not directed at you, but at the devs.)
                        remus
                        I had similar thoughts as well πŸ˜‰
                          Dik Harrison
                          I haven't looked too deeply yet at the free version I down loaded, but must say that I am pleased that I can now navigate (orbit, zoom, etc.) within a fairly complex model of my home, and I don't get stuck in objects and walls, and the navigating is faster and smoother. Given that, DCs and the improved Layout (don't use it now but it seems like it will now be a valuable tool), I will definitely upgrade my Pro license.
                          Have fun...
                          Dik
                          • david_hD Offline
                            david_h
                            self-explanationed
                            sounds like a good Bush-ism! πŸ˜„
                            • BurkhardB Offline
                              Burkhard
                              Remus, come on.
                              High poly support is self-explanatory . To convert it is for professionals.
                              http://www.ia-plus.de
                              • BurkhardB Offline
                                Burkhard
                                self-explanationed
                                πŸ˜‰he,he ..so it's better to correct it. 😳
                                  paulside
                                  Mike
                                  Mike, I don't mean all singing and dancing 2D cad tools, just the sort you can get with the free CD on computer magazines, just integrated into Layout thats all. That wouldn't be so hard or cause 2D CAD wars would it? πŸ˜’
                                  anyway enough moaning now. I'm off to play with Sketchup 7
                                  • F Offline
                                    fossa
                                    I'd say that if only one thing comes from all the posting and commenting here it is that GSU needs to develop a dialog between themselves and the pro users. Really that seems to be the heart of problem here.
                                      remus
                                      Rick, although i agree with most of what youve said, i think SU has moved on form its sketched based origins. It is so easy to create hugely detailed models, if only SU was faster!
                                      Larry, i have to agree. I cant help but think a huge amount of hassle could have been prevented if there was a good dialogue between developers and users.
                                      • F Offline
                                        fossa
                                        They clearly need to issue a formal plan stating the direction they are headed with the software. If they would have discussed it, this entire thread wouldn't exist.
                                        • N Offline
                                          numerobis
                                          ignoring multicore these days is a complete joke to me. it's totally clear for everyone that there will be no substantial improvements in processor speed in the near future - the future is multicore! ok, implementing multicore usage for modeling seems to be not that easy but i think i has to be done because it's seems to be the only way to speed things up. And why not using multicore for the rendering part? seeing 3 cores sleeping while exporting a picture takes half an hour is really annoying...
                                          definition of "semi high poly":
                                          http://img201.imageshack.us/img201/1599/skpstatisticssc2.th.jpg
                                          http://img201.imageshack.us/images/thpix.gif
                                          this skp file has 140mb on the hdd and needs ~1gb ram! and i would call it only "semi high poly". in max i can handle 7 mio polys or more without such big problems...
                                          and it's not only about display and modeling speed... saving such big files is veeery slow in skp and importing objects with some 100k polys is taking ages. when i have to copy/paste only a few polys from this skp file to another sometimes i wait for 15-30 min before skp is responding again...
                                          and 64bit support becomes quite useful if you try to export a model like this for rendering (or as dwg/3ds) and skp likes to crash at ~1.6gb ram usage...
                                          πŸ˜’
                                            roadkill
                                            it is a shame so many of you feel very disappointed about this release, maybe it was always impossible for Google to meet up such great expectations and waiting so long to release V7 only increased it by 10 fold. Now don't forget that when you pay peanuts you get monkeys... i am sorry to say some of you expected a version capable to deliver what a five times more expensive application still does not! I still think that pound for pound this application remains one of the easiest to learn and use and fills a niche of the market that few others can compete with and if you are after something more sophisticated then there's dozens of other programs out there that you should try, but don't expect it to meet all your expectations. I have used a few and despite the incredible progress most developers can still learn one thing or two from this humble application....
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 12 / 15
