    Plug-ins load in default template
    5 Posts 3 Posters 462 Views 3 Watching
      rhankc
      Hi guys, I'm trying to figure out something I've forgotten....
      I am setting up a new computer, and getting SU to behave on the new pc like it did on the other one. Everything is o.k. except one of my plug-ins doesn't load at/when SU is started. I would like it to load automatically.I have saved it loaded into the default template...didn't work... any suggestions?
      Hank
      • V Offline
        Voder Vocoder
        Hank,
        Plugins do not depend on the template to load. Most plugins will load when SU starts up just by virtue of being present (that is, the *.rb file) in the SketchUp 6\Plugins directory, which SU reads at startup. In some cases, in addition to being installed in the Plugins directory, a plugin will have to be "enabled" by being checked in the list on Window > Preferences > Extensions.
        ~Voder
          rhankc
          Thanks Voder,
          So I'm assuming I have a problem with the loader script...
          Hank
            Which plugin is that, Hank?
              rhankc
              Hey,
              It is working now...The Script is RPTools, and there is a "load at start" selection in the working menu under the hammer πŸ‘
              Hank
