    Cant get stuff to highlight
    11 Posts 2 Posters 908 Views 2 Watching
      JayPapaFlash
      Why are my arches not highlighted? I need to push/pull them individually but cant get them highlighted to do so. Whats wrong?
      http://i151.photobucket.com/albums/s152/jasonmartin206/SP32-20081106-003340.gif
      You don't know who's swimming naked until the tide goes out.
      • GaieusG
        Hi Jay and welcome.
        What I would suspect from this image is that there are no faces at all between those lines. If they are coplanar*at all (which I cannot tell from this angle), you could try "healing" the faces by redrawing the small, straight segments on the sides.
        *Faces can only be created by a closed loop of coplanar edges i.e. edges on the same plane.
          JayPapaFlash
          How can I put my .skp on here so you can see whats going on? I did the line thing like you suggested but i dont think it worked.
          • GaieusG
            Under the text area, when posting, there is a tab for attachments (see image)
              JayPapaFlash
              Let me know what you think.
              Partial highlights on arches
              • GaieusG
                Some of the edges are not coplanar. See attached file where I used the text tool do display the co-ordinates of some endpoints.
                I'd deinitely start over. Draw a big reactangle first which you can use as a drawing board making sure that all the edges are drawn on the same plane.
                kathy new version_nonCP.skp
                  JayPapaFlash
                  Awesome, thanks so much!
                    JayPapaFlash
                    Worked like a charm! Thanks again
                    Fixed arches
                    • GaieusG
                      Fine! πŸ˜„
                      Still you may wish to delete some extra geometry (see what I selected "inside") and orient your faces correctly (only the whites showing outside).
                        JayPapaFlash
                        I dont know if I still have some coplaner issues here, but I am trying to cover the surface of the large box to make it look like elevated terrain so I can color it in with grass.
                        kathy new version-1.skp
                        • GaieusG
                          Coplanar??? Have a look at this image!
                          Selecting all the surrounding edges and running "From contour" from the Sandbox tools will create a surface however.
                          kathy new version-1_1.skp
