    Didier Bur's projection_extension.zip file
    17 Posts 8 Posters 4.2k Views 8 Watching
      Buzzer1001
      Hi Didier,
      First of all - many thanks for your scripts - they are indeed fantastic. When I see your name next to a script I know it's going to be useful.
      I've downloaded your Projection Extension v6 script and I like the improved toolbar - especially the place construction point option. The interesting thing I've come across is that even though the dialog box says it's in mm, it actually executes in inches - wierd. My model units are mm, so I'm not sure what's going on there.
      Anyway - keep up the good work!
      • Didier BurD Offline
        Didier Bur
        In what command ?
        Please precise what command executes in inches instead of your unit ?
        DB
        • CadFatherC Offline
          CadFather
          Hi Didier, when i place construction points i have to reselect the toolbar icon to place another one. - is this the way it works? (i thought i could keep clicking in the model to draw more points)
            Didier Bur
            yes. I'll see what I can do to change that.
            DB
              CadFather
              Thank you Master Didier. πŸ˜„
              • W Offline
                watkins
                Dear Didier,
                Do you know of a script that allows the following:
                • place cpoint on surface
                • select the plugin (call it projected_normal)
                • click on cpoint, click on surface
                • enter line length in VCB
                • plugin draws normal to surface at cpoint and to specified length
                I have a feeling that you might have written something like this before.
                Regards,
                Bob
                  Didier Bur
                  Hi Watkins,
                  No, I didn't... until this evening. I've PM'ed you a beta version to be incorporated in the projection pack if of any use.
                  Regards,
                  DB
                    benoram
                    I think this is the most logical place to ask this question, sorry if I'm wrong.
                    I've tried downloading your projections_V6 plugin/extension from your site at
                    'http://www.crai.archi.fr/RubyLibraryDepot/Ruby/em_geo_page.htm'
                    However there seem to be some files missing from the zip.. The only visible files are
                    Projection Documentation.pdf
                    projection.rb
                    However, the install PDF mentions a projection_extension.rb and a subfolder with several other files
                    Is there any chance you could send me the complete version?
                    Thanks again, its one of the most usefull scripts I've seen.
                    • free agentF Offline
                      free agent
                      @didier bur said:
                      Hi Watkins,
                      Regards,
                      hi didier is there any way i could get this betta too, we are getting alot more request to build meshes from point heights and it would be quite a time saver if i could add this z value in Sketchup
                      http://i167.photobucket.com/albums/u143/FreeAgent84/bug.gif
                      • W Offline
                        watkins
                        Dear Free Agent,
                        This plugin has been incorporated into the new release of projections (you should have 13 icons). Perhaps it is the number 13, but I cannot get it to work. The standalone plugin that Didier sent me works fine.
                        I have attached this plugin. Put a point on a surface, select the point and the surface, select the plugin 'Line perpendicular to face' from the drop-down menu, enter the line length, and as Didier might say, Voila!
                        I am hoping that Didier will not be annoyed by my posting the script.
                        Regards,
                        Bob
                        perp_line_plane.rb
                          free agent
                          hi watkins thanx for the quick reply, i tried to tool, wasnt entirly what i wanted (but thanx) in the end i need that construction point to be placed at the top of that line, i need to be able to quickly select construction points and place them at the given height (spot heights)... any thoughts?
                          • W Offline
                            watkins
                            Dear Free Agent,
                            I am sure that Didier could modify his script to do exactly as you require. You would need to consider your requirements before sending him a PM. For example, would you like to place N cpoints on a single surface or different surfaces, and then have them projected a given distance along perpendiculars to that/those surface(s). It would also be useful to have the option in the right click context menu.
                            In the meantime, just add a cpoint to the end of the line and delete the line.
                            Regards,
                            Bob
                              liit
                              @didier bur said:
                              In what command ?
                              I meet the issue too When use "P-P selected faces along their normals " and "P-P selected faces randomly" (projection_V6)
                              It executes in inches instead of MM!!
