    Didier Bur's projection_extension.zip file
    17 Posts 8 Posters 4.1k Views 8 Watching
    • Didier BurD Offline
      Didier Bur
      OK OK, it seems there is some work for me to update all the scripts for V6.
      It's a pity that GSU developers don't care enough about us poor scripters... 😞
      (Autolisp for instance doesn't have this problem).
      As soon as I get some time to update the projection toolbar it will be done, along with tutos as well.
      My to-do-list is growing fast these days πŸ˜†
      DB
      • W Offline
        watkins
        Dear Didier,
        Many thanks for your positive response. I cannot imagine what your 'to-do' list looks like, but I'm glad it isn't mine. Having said that, mine is bad enough.
        Kind regards, and merci beaucoup
        Bob
          Buzzer1001
          Hi Didier,
          First of all - many thanks for your scripts - they are indeed fantastic. When I see your name next to a script I know it's going to be useful.
          I've downloaded your Projection Extension v6 script and I like the improved toolbar - especially the place construction point option. The interesting thing I've come across is that even though the dialog box says it's in mm, it actually executes in inches - wierd. My model units are mm, so I'm not sure what's going on there.
          Anyway - keep up the good work!
            Didier Bur
            In what command ?
            Please precise what command executes in inches instead of your unit ?
            DB
            • CadFatherC Offline
              CadFather
              Hi Didier, when i place construction points i have to reselect the toolbar icon to place another one. - is this the way it works? (i thought i could keep clicking in the model to draw more points)
                Didier Bur
                yes. I'll see what I can do to change that.
                DB
                  CadFather
                  Thank you Master Didier. πŸ˜„
                  • W Offline
                    watkins
                    Dear Didier,
                    Do you know of a script that allows the following:
                    • place cpoint on surface
                    • select the plugin (call it projected_normal)
                    • click on cpoint, click on surface
                    • enter line length in VCB
                    • plugin draws normal to surface at cpoint and to specified length
                    I have a feeling that you might have written something like this before.
                    Regards,
                    Bob
                      Didier Bur
                      Hi Watkins,
                      No, I didn't... until this evening. I've PM'ed you a beta version to be incorporated in the projection pack if of any use.
                      Regards,
                      DB
                        benoram
                        I think this is the most logical place to ask this question, sorry if I'm wrong.
                        I've tried downloading your projections_V6 plugin/extension from your site at
                        'http://www.crai.archi.fr/RubyLibraryDepot/Ruby/em_geo_page.htm'
                        However there seem to be some files missing from the zip.. The only visible files are
                        Projection Documentation.pdf
                        projection.rb
                        However, the install PDF mentions a projection_extension.rb and a subfolder with several other files
                        Is there any chance you could send me the complete version?
                        Thanks again, its one of the most usefull scripts I've seen.
                        • free agentF Offline
                          free agent
                          @didier bur said:
                          Hi Watkins,
                          Regards,
                          hi didier is there any way i could get this betta too, we are getting alot more request to build meshes from point heights and it would be quite a time saver if i could add this z value in Sketchup
                          • W Offline
                            watkins
                            Dear Free Agent,
                            This plugin has been incorporated into the new release of projections (you should have 13 icons). Perhaps it is the number 13, but I cannot get it to work. The standalone plugin that Didier sent me works fine.
                            I have attached this plugin. Put a point on a surface, select the point and the surface, select the plugin 'Line perpendicular to face' from the drop-down menu, enter the line length, and as Didier might say, Voila!
                            I am hoping that Didier will not be annoyed by my posting the script.
                            Regards,
                            Bob
                            perp_line_plane.rb
                              free agent
                              hi watkins thanx for the quick reply, i tried to tool, wasnt entirly what i wanted (but thanx) in the end i need that construction point to be placed at the top of that line, i need to be able to quickly select construction points and place them at the given height (spot heights)... any thoughts?
                              • W Offline
                                watkins
                                Dear Free Agent,
                                I am sure that Didier could modify his script to do exactly as you require. You would need to consider your requirements before sending him a PM. For example, would you like to place N cpoints on a single surface or different surfaces, and then have them projected a given distance along perpendiculars to that/those surface(s). It would also be useful to have the option in the right click context menu.
                                In the meantime, just add a cpoint to the end of the line and delete the line.
                                Regards,
                                Bob
                                  liit
                                  @didier bur said:
                                  In what command ?
                                  I meet the issue too When use "P-P selected faces along their normals " and "P-P selected faces randomly" (projection_V6)
                                  It executes in inches instead of MM!!
