    Another mindbreaking breaking folow me task
    9 Posts 4 Posters 1.1k Views 4 Watching
    • B
      bhnida
      hello to all,
      i am asuming i using the wrong aproach as the following tool is maybe not the right tool to do this.
      long time ago i had the feeling already it needed somthing to "BEND" things around others.
      now i have this saw like profile wich i need to be "BEND" around a circle ore elips surface
      ore other shaped lines
      but i ma not getting it 😞 maybe someone of you guys can give me a idea ? πŸ˜„
      the problem is that the saw like struckture must folow the thing...
      how can i make this profile follow the circle.skp
      • TaffGochT
        TaffGoch
        bernhard,
        The "follow me" tool extrudes a profile face along a path, and doesn't copy or bend existing constructions. There's no default tool to "bend" a construction around a path. However, you can copy constructs in a radial array, around the centerpoint of your circle.
        The attached is not a tutorial, but the end result of radial copying of a component around the circle centerpoint. Take a look at the individual parts of the model, and read in the Users Guide the description of "radial" copying. The method is something you should master, as you are likely to need it often.
        Taff
        RadialCopies.skp
        "Information is not knowledge." -- Albert Einstein
        • B
          bhnida
          thanks a lot for your expresions loud and clear.
          i understood and also managed some exept ONE THING tell me please how you managed this nice centerpoint in your sample.
          is there such thing like adding centerpoint ?
          thanks a lot bernhard πŸ˜„
          • TaffGochT
            TaffGoch
            bernhard,
            There is a centerpoint plugin provided with SketchUp, which will insert a guidepoint at the center of circles, arcs and polygons. You have to enable the SketchUp extensions:
            "Window > Preferences > Extensions" and check the box for "Ruby Script Examples"
            When you right-click on a circle boundary (not the face,) the context menu will now include a "Point at center" option.
            Taff
            • B
              bhnida
              WHOU works great,
              now another SU trouble maker is gone πŸ˜„)
              with the help of the forum i blow them out all time by time πŸ˜„
                jukkoo
                ok, that is a way to resolve this problem (radial copying), but what do we do when the path is a more complex curve? is there another way?
                • soloS
                  Yes there is, 'path copy' using copy along path. http://www.smustard.com/script/PathCopy
                  • soloS
                    An illustration of what I mean.
                    http://img241.imageshack.us/img241/9047/pathps8.gif
                    • soloS
                      And the other option:
                      REMEMBER! to weld your path first.
                      http://img392.imageshack.us/img392/4125/path2zl9.gif
