    Saying Hello
    14 Posts 6 Posters 1.2k Views 6 Watching
    • soloS
      welcome to GSCF Igor.
      • U
        UkrainianALFA
        alright... number 1.
        I am dumber than a doornail. I want to raise some structures, how do I type in a dimension for the height of the raise I want? When I start dragging and type in 12 feet, some weird things happened to the cursor, but the raise did not go to the height I wanted
        • boofredlayB
          boofredlay
          Can you attach a screen shot of what your cursor is doing?
          Are you using the Push Pull tool to raise the structure?
          • U
            UkrainianALFA
            yes sir, push pull tool.
            • boofredlayB
              boofredlay
              Are you actually typing in 12 feet or 12' ?
              If in fact you are typing the word feet after the number 12 then you are hitting shortcuts for more tools most likely.
              Does this help?
              • U
                UkrainianALFA
                Does this help?
                AHHH!! soo.. I just use the ' symbol. hmm.. simple enough. it's too bad I can't draw worth crap and thing still seem to look weird, one twelve feet seems to raise out of my structure, one seems to go back inside my building
                • boofredlayB
                  boofredlay
                  Keep at it 👍
                  Remember if you have questions and have a visual (screenshot) it will help us help you much better.
                  Good luck and goodnight from Alabama ☀
                  • U
                    UkrainianALFA
                    okay look here.
                    http://i36.tinypic.com/2cbiv4.jpg
                    I tried to rise the left side to 40 feet, I typed in 40' and it barely did anything. How do I turn on grids or rulers to see how big my shapes are? I even tried typing in 400' and nothing happened again.
                      mateo soletic
                      Igor,
                      Welcome to the forum.
                      and type in 12 feet
                      Why do You want to type in feet? 😕 Do You use feet in Ukraine?
                      Concept Illustrations
                      • U
                        UkrainianALFA
                        yes, I use feet. I walk every day on my feet! 😄
                        but anyways... I just use feet because so many of my online friends are in America.
                        • H
                          Hazza
                          Are you moving the area a little bit first? You move it any distance in the direction you want to go, then you type in the exact distance you need.
                          If you don't move it first how is SU supposed to know which direction to push/pull it?
                          See all of my SketchUp models here.
                          • MALAISEM
                            MALAISE
                            Hello Igor
                            Welcome on SU planet.
                            MALAISE 😄
