    SketchUp RUBY API Wishlist [way of coding wishes, please]
    107 Posts 46 Posters 59.0k Views 46 Watching
    • daikuD
      daiku
      This is music to my ears, Scott. Here's another vote for ruby control of dimension objects. CB.
      Clark Bremer
      http://www.northernlightstimberframing.com
      • T
        toxicvoxel
        Two requests:
        Simple methods for retrieving points,angles and distances without using a tool class.(Something as simple as 'getpoint' and getangle in AutoCAD's api. Maybe something like pt=Sketchup.utility.getpoint(prompt) for example)
        'Getangle' should offer the use of the protractor tool for input.
        Then a request for the Sketchup COM api: Include a 'runRubyScript' method that can be called from the api and returns the return value from the script.
          Matt666
          Hi all !
          One great improvment would be to have some control on inferences via ruby... Isolate, stop, start, etc....
          Frenglish at its best !
          My scripts
          • N
            NewOne
            Move (and rotate) axes from ruby !!! Actually, to be able to access any tool from ruby.
            regards!
              Matt666
              Hi all !
              One ruby improvment :
              • A command autolisp like function !! To have access to all native tools (like said NewOne), and to have possibility to control this tool !
                Command autolisp function work like that :
                To make a line :
              (command "_LINE" "0,0,0" "10,0,0" "")
              (command " 'International Name of the tool' " " 'first point' " " 'any point you want' " "")
              "" stops the command.
              One very intersting thing is you can insert pause that let user doing what he wants !
              (command "_LINE" "0,0,0" PAUSE" "")
              PAUSE stops process and let user giving a point, in this example.
              Another cool thing is an Autocad variable that show if a command (or tool) is active. And you can use it in the code !
              (command "_LINE")(while (not (eq (getvar "cmdactive") 0)))(command PAUSE))
              (getvar "cmdactive") returns 0 (no active tool) or 1 (one active tool)
              My scripts
              • T
                tomasz
                Selection display bug to be fixed, please.
                  Jim
                  Something I have been wanting to do is write a suite of general-purpose Observers based on the built-in ones. Most of the Observers are designed to be attached to a specific entity in a model (or to THE model) - the SelectionObserver, for example is attached to a model's selection collection. It just seems inefficient and error-prone for each plugin author who needs one to implement their own SelectionObserver when a single instance can handle all requests.
                  So, I guess I'm really proposing a simplified API for using Observers.
                  The way I see this API working is that a plugin would 'require' the observer file, which would create a single Observer instance. Then the plugin would 'register' methods in the form of blocks (or procs?). In my experiments, I used the Ruby Singleton class to ensure there is ever only one instance created.
                  Here is how I see the API being used (without getting into the details of the implementation):
                  # My Plugin
                  require 'app_observer' # Global AppObserver instance created
                  def hello(args)
                    puts "Hello #{args}"
                  # Register hello() to be called for an onNewModel event
                  id = AppObserver.instance.register("onNewModel") {|args| hello(args) }
                  # AppObserver attaches itself when its registry goes from 0 to >0 elements
                  AppObserver.instance.unregister(id) # stop calling hello for onNewModel event
                  # AppObserver detaches itself when its registry falls to 0 elements.
                  It really simplifies using Observers, which in turn could allow authors to create better plugins, with more advanced features, in a shorter time. It may also save on resources by having one and only one instance of most of the Observers (confirm?)
                  (related post)
                    david.
                    Jim,
                    Nice idea. Also, I'm curious if you mixed in the Singleton module to implement your singletons? I've found that I can't require a library module like Singleton unless I point directly to my Ruby installation directories. I realize that this isn't required to implement singletons, but it seems the most simple and consistent.
                      Jackson
                      Welcome to SCF Scott, it's great to see your involvement here!
                      Jackson
                      • scottliningerS
                        scottlininger
                        This is a fantastic idea. Attaching observers reliably to every component instance, for example, is challenging. So a helper script is one approach... another would be to create some uber-observers at the Sketchup level. Obviously, there are potential performance concerns with any of these.
                        • Scott Lininger
                          SketchUp Software Engineer
                          Have you visited the Ruby API Docs?
                        • JClementsJ
                          JClements
                          A standard for displaying script documentation, besides their description, in the menus:
                          The ruby filename, creator, version level; basically an "about" display for each script. Optional info could be copyright info, contact (email) link, website link, and display of a help file on a local drive.
                          An easier way to organize scripts in a user defined menu (there are scripts that do this now, but I wouldn't call them user friendly)
                          • T
                            tomasz
                            New method for a texture, very useful for exporters.
                            texture.alpha_channel? -> (true or false)
                            • W
                              Whaat
                              Ooohhh..that reminds me:
                              How about a method that samples the texture color on a face?
                              face.color_at(u,v)->returns a SketchUp::Color object.
                              Could be used for displacement mapping inside SketchUp for example.
                                Jim
                                @david. said:
                                Jim,
                                Hi David,
                                Yes, I used the singleton class from Ruby. I copied singleton.rb from the Ruby language installation to a 'ruby' folder in my Sketchup/Plugins folder. The Ruby singleton is very easy to use, and was simply the best and fastest solution. I think there are a few other files from the installed Ruby files that I needed also.
                                  morisdov
                                  Hello
                                  Inside SketchUp it works fine but when creating an AVI file with Export -> Animation
                                  the - Sketchup::Pages.add_frame_change_observer - is not firing between frames.
                                  Is there anything i should change or another observer i can use between frames in Export Animation ?
                                  404 Not Found
                                  (www.sketchucation.com)
                                    Jim
                                    One of the more important things that could be done using the Ruby API, and which would benefit nearly all users is a unified API for menus and toolbars. I don't mean being able to lock toolbars; I mean the possibility to provide menu and toolbar customization using a "Menu & Toolbar Editor" within SketchUp.
                                    The need is apparent in CadFather's Toolbar plugins; where he creates a collection of scripts and adds toolbar buttons for them. Although these are nice toolbars, they are going to prove difficult to maintain as scripts are updated and obsoleted.
                                    Really, there would need to be some registry that would:
                                    • "install" a plugin so that is is not located in the Plugins folder, and so not automatically loaded.
                                    • allow un-modified plugins to continue to function.
                                    • allow new/modified plugins to create new, or be added to, existing menus, submenus, and toolbars.
                                    • handle the creation of menus and toolbars at startup.
                                    The possibilities are fantastic, if you let your mind run wild:
                                    • allow menu/toolbars "sets" to be created.
                                    • allow plugins to be downloaded as-needed, or used online. (zero install: net_require "progrsssbar.rb")
                                    • check new versions of plugins online, and upgrade.
                                    Of course, I do not mean to remove the ability for developers to create their own menu or toolbars. But even if it's just for the numerous scripts that are single-menu, or single-button plugins, this would be an improvement.
                                    (related post)
                                      Matt666
                                      Hi guys !
                                      I wish one day, we would have access to print parameters via ruby... One day... 😄
                                      My scripts
                                      • T
                                        tomasz
                                        An important wish for ALL exporters, I believe:
                                        • a method to read a cropped region in 2point perspective view.
                                          As far as I am aware, currently there is no way to read it!
                                        Please!
                                        • T
                                          tomasz
                                          A Ruby method that will give us a real UVW coordinates of a projected texture, so exporters could use a single, original texture, instead of say 200 small textures of a photo mapped terrain.
                                          • chrisglasierC
                                            chrisglasier
                                            A switch (if it does not exist) to activate a ruby on selection of an entity or entities to allow interaction with a webdialog.
                                            See:
                                            http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=14299
                                            • 1 / 6
