    Word of warning to developers
    25 Posts 17 Posters 16.5k Views 17 Watching
      CPhillips
      Come on. Spill it. What plugin did you find a conflict with? πŸ˜„
        todd burch
        One of my paid scripts was broken by a free script. Names are being withheld until notification of next of kin. πŸ˜†
        • Didier BurD Offline
          Didier Bur
          DB
            πŸ˜„ 🀣 πŸ˜†
            • scottliningerS Offline
              scottlininger
              Another broad area of "wishlisting" is how we can best handle the problem of our scripts accidentally clobbering other people's. It's great that Ruby is such a flexible language, but we've all seen situations where two of us choose the same name for something and everybody loses.
              RickW has suggested to me that we form some sort of "official" policy and/or repository for handling this problem, and for reducing code rewriting, so that we all benefit from the collective knowledge of the group, but as of yet I haven't pulled together a proposal for the community. What are your ideas?
              Some possibilities:
              Create an "official" means for extending Sketchup.rb, along with a versioning system, so that we can extend the base API.
              Create some kind of name-spacing convention that we can publicize and encourage folks to use.
              I'm sure these are things you've all been talking about (I'm still catching up on back-messages.) I want something that's easy for people to use, from novice ruby programmer to expert. If it's too hard for people to understand and adopt, then we're wasting our time... What do you think? I'm all ears.
              • Scott Lininger
                SketchUp Software Engineer
                Have you visited the Ruby API Docs?
              • soloS Offline
                I am no coder so my opion is worthless however .... how about having all ruby's include the authors initials? IE adjust_textures_PJS.rb (hypothetical ruby)
                  Dik Harrison
                  Formally, I worked for a large government agency that developed their software internally, with development taking not only at development centers, but also at individual sites (170+), at least that is how it worked a number of years ago, now there is not much development going on now. Any way, back when everybody was developing or at least customizing for local use, each site was given a short code 3-4 letters that made their variables and routines unique. Using initials or some such would work in this situation, but a list of initials would need to be maintained, so that duplicated would not occur. Then a coder would simply add their code as a prefix or sub-fix to their routines and variables. For example, I would write a routine called something-wrh.rb, with a variable x-wrh. It would be up to me not to step on my own code.
                  Have fun...
                  Dik
                  • TIGT Online
                    The precepts of the law are these: To live honourably, not to injure another, to give each his due.
                    As Gaeius's strap-line says [in pig Latin]...
                    i.e. Remember: Be nice to others. Don't mess others up. Give others due credit...
                      Hi TIG - yes, a bit off-topic but hey... πŸ˜„
                      It's Institutiones Iustiniani 1.1.3
                      (I wrote my thesis in Roman Law at the Law School πŸ˜‰ )
                        Jim
                        I have been using my initials as a module name to encapsulate everything I release, although I think sometimes little things slip through the cracks.
                        Would a shared Google Docs spreadsheet be good enough to claim and register namespaces?
                                Name        |        Email        | Registered Namespace
                        Carl Coder          | ccoder@gmail.com    | Ccoder
                          scottlininger
                          Have people seen any errors from other ways that scripts mess with each other besides naming overlaps? For example, observers from script A are messing with the model before my observers from script B fire off?
                          • Scott Lininger
                            todd burch
                            There have been right-click context menu issues with validation routines. The classic issue here is HouseBuilder causing a beep if installed whenever any right click was done. Not so much a conflict as an annoyance.
                            I remember an issue one time with some script extending a base class of Ruby (like NullClass) and it causing issues. Don't remember the specifics.
                            What should probably be promoted is script authors subclassing Sketchup classes to extend them, as opposed to just extending them.
                              tomasz
                              I've got two scripts on my black list.
                              1st place : Matchbox Plugin 1.1 by antantantant
                              Population.rb
                              class Array
                                def * (n)
                                  temp = Array.new()
                                  i = 0
                                  if n.kind_of? Float
                                    each {|v| temp[i] = v*n
                                          i = i + 1}
                                  return temp
                                def + (n)
                                  if n.kind_of? Array
                                    i = 0
                                    temp = Array.new()
                                    while i < [self.length, n.length].max
                                      temp.push(self[i] + n[i])
                                      i = i + 1
                                  return temp
                                  elsif n.kind_of? Float
                                    each {|v| v = v + n}
                              Arrrrgggghhhhhhh..... !! Do NOT modify built-in Ruby methods, please!!
                              2nd place: Train Simulator 1.2 exporter by Paul Gausden
                              mstsx.rb
                              class Sketchup;;Color
                              	 def ==(c)
                              		 return (c.alpha==self.alpha and c.red==self.red and c.green==self.green and c.blue==self.blue)
                              Modification of original SU method, which can : 1st - give different results than other Ruby programmers expect, 2nd - prevents != method to work correctly.
                              Those bugs makes my life and users of my exporter harder. 😞
                              Author of [Thea Render for SketchUp](http://www.thearender.com/sketchup)
                                sepo
                                Matchbox is also on the Podium NO NO list.
                                  deerwood
                                  Hi all,
                                  though I not yet had any name clash problem, may I suggest a rule adopted from the Java world? The essential idea is to qualify/prefix "packages" with something unique in our internet world. Namely the domain of the author, reversed, optionally followed by some more specific info.
                                  So e.g. Jim's "jitter.rb" is qualified by "com_blogspot_sketchuptips" and the specific info beeing "jitter".
                                  And Ricks "GoldenGauge" is qualified by "com_smustard" (or maybe "com_smustard_wilson_rick") and the specific info beeing "golden_gauge".
                                  Following that idea the plugins working code would not reside any longer directly inside the "plugins" directory (unless it is an essential thing/library) but in some directory named after the domain inside "plugins".
                                  E.g. Jim's plugins ALL reside in "plugins/com_blogspot_sketchuptips" and ALL of the Smustard ones are present under the "plugins/com_smustard" directory, optionally further down in a dir named after the author ("..../wilson_rick") or a project ("..../common" or "..../utils").
                                  And, please, all other excellent plugin writers here around: I apologize to not have named you. But you'll get the idea, hopefully.
                                  To call/activate such a plugin on startup of SU there must be a minimal Ruby script directly in the "plugins" dir, requiering the real code. These would be one liners, but then named after the complete path to the plugins code. E.g. "jitter" would have this Ruby in the "plugins" dir (named "com_blogspot_sketchuptips_jitter.rb"):
                                  require 'com_blogspot_sketchuptips/jitter.rb'
                                  But it should be easy to just call a script common to a domain, that does advanced handling of (sub)scripts to be included. That script then just requires, what the final user wants to have. These require scripts (down to any level of the dir hierarchy) could easily be tweaked by users, by just commenting out "require" statements.
                                  Packaging of plugins into this hierarchie/concept is easy for every developer of plugins.
                                  Every plugin's author is known/can be reached (as long as his domain is existent).
                                  Cluttering of the plugins directory is reduced greatly, especially when the feature of just require'ing subdirs reqire scripts is used.
                                  What do YOU think?
                                  Best regards, deerwood
                                    RickW
                                    Interesting concept, and for creating Module names, it could work. However, locating files in subfolders by organization/author name conflicts with Organizer.rb.
                                    Currently, Organzier allows users to create subfolders in the Plugins folder that then become submenus in the Plugins menu, with the scripts located in those subfolders likewise having menu items in the respective submenus. For example, you could create a "Draw-Create" subfolder, then move all scripts that draw or create geometry in that subfolder. In the Plugins menu, there would be a Draw-Create submenu, and each file in that subdirectory would be represented in the submenu. It's a fast way for users to clean up both their Plugins menu and Plugins folder at the same time, while grouping scripts by like function.
                                    I think that a script that parses the new template file and can display the pertinent script information in a webDialog will go a long way towards helping users who want or need to know the author/contact information or version number to check for updates.
                                    RickW
                                    [www.smustard.com](http://www.smustard.com)
                                      deerwood
                                      Dear Rick, all,
                                      sorry, I wasn't aware of the organizer.rb. Hmm. Still not giving up on the subfolder idea πŸ˜‰ , what about more closely mimic that Java concept by having under "plugins" max 2..4 letter folders named after the top level domains, e.g. "com", "edu", "org", "net", "tv", "de" or "co"? Isn't the length of TLD's restricted?
                                      The organizer then could just ignore short folder names directly under "plugins", or, if neccessary, have a list of (additional) TLD names to ignore.
                                      Under the TLD folders there would be the appropriate domain name folders of the authors. So someones/Jims/yours/mine plugins would reside in
                                      • plugins
                                      • co
                                      • uk
                                      • someone
                                      • someone-else
                                      • com
                                      • blogspot
                                      • sketchuptips* smustard
                                      • de
                                      • georg-rehfeld
                                      For the module/class names I'm not any longer really happy with my proposal, because the names would be so exceptionally long/unusabale. Or did I miss some Ruby feature?
                                      Just brainstorming, not more.
                                      Best regards, Georg (aka deerwood)
                                      • Chris FullmerC Offline
                                        I think I'm not seeing what the problem is with having plugins just placed in the root plugins folder?
                                          deerwood
                                          Hi Chris,
                                          as told, I had no name clashes yet in any way. But I see myself "managing" my plugins already, though I'm still a newby.
                                          Especially because there are soooooo many, very helpfull plugins around/published in this forum πŸ˜„ (wow, thanks to all providers). I have to find a way to try these out and find the ones appropiate for my way of working with SU ... ever changing as I get these new great additions and learn to use them.
                                          And then: Rick warned, I wrote, what came up into my mind. Maybe, that is poor/not appropriate. It is meant as just a base idea ... brain storming, as stupid as it may be, should not be taken literally. Take just one idea out of it or come up with a totally different general approach. Collect as much of ideas as possible. Later on one or the other may be able to make use of the idea.
                                          Best regards, Georg/deerwood
                                          • DavidBoulderD Offline
                                            DavidBoulder
                                            Good thread. I may get in to a large ruby project soon, and I'm glad I ran across this. Will give me insight on how best to name and organize my code/scripts.
                                            David Goldwasser
                                            OpenStudio Developer
                                            National Renewable Energy Laboratory
