Continue texture on next object ?
Is it possible to continue a texture on the next object ?
Right now I'm tryin to model a wall that is split up in floors, but from the outside I would like it to look like a single wall. It this possible ?
I have tried to use the "match paint form" when editing an object - but that did not help
Any suggestions ?
You could use a one big projected texture, and as long as it didnt tile it should go smoothly across the entire face.
It's tree objects
Jorgensen, SU will apply all the textures from the same starting point, unless you adjust it on a surface. If you do adjust it's position on a surface, and you want to reset the texture on adjacent surfaces to align, use the eyedropper to selected the adjusted texture, and repaint the adjacent surfaces.
