    Continue texture on next object ?
    5 Posts 4 Posters 631 Views 4 Watching
      Jorgensen
      Is it possible to continue a texture on the next object ?
      Right now I'm tryin to model a wall that is split up in floors, but from the outside I would like it to look like a single wall. It this possible ?
      I have tried to use the "match paint form" when editing an object - but that did not help 😞
      Any suggestions ?
        remus
        You could use a one big projected texture, and as long as it didnt tile it should go smoothly across the entire face.
          Jorgensen
          It's tree objects πŸ˜„
          • DanielD Offline
            Daniel
            Jorgensen, SU will apply all the textures from the same starting point, unless you adjust it on a surface. If you do adjust it's position on a surface, and you want to reset the texture on adjacent surfaces to align, use the eyedropper to selected the adjusted texture, and repaint the adjacent surfaces.
            My avatar is an anachronism.
            • Jean LemireJ Offline
              Jean Lemire
              Hi Jorgensen, hi folks.
              See this SU file for ideas.
              Painting an outside wall.zip
