    Solar system
    5 Posts 4 Posters 850 Views 4 Watching
      seanheadrick
      I was building this solar system to scale (not full scale) but I am having some trouble. The further out the planets get the more unstable their joint connection to the sun becomes. I also noted the bonding boxes on some of the more distant planets was considerably larger than the planet and joint they are bounding. I am wondering if the extents of the model are just too broad or maybe the distance between the planets and their joints is too far.
      Thanks,
      Sean
      AutoSave_soar systemscaledrawing.skp
      DO OR DO NOT, THERE IS NO TRY.
      • plot-parisP
        plot-paris
        ok. your model is definitely to big / the planets too far apart for SketchUp. I ran into massive clipping problems that occur precisely in this situation - a too large model (I think it is OpenGL related though).
        does it really have to be that accurate? you are not able to see the planets like that anyway...
        I would suggest you dramatically decrease the distance between the planets.
        • B
          Brettina
          Maybe it would work to scale down everything by 100? I don't know what the limit in SketchUp is, but using a scale would still be accurate.
          • AnssiA
            Anssi
            The problem with a solar system "to scale" is that when you reduce the overall size to a scale compatible with SU (a kilometer or two across might work) the planet models will be too small for SU to work with (some faces will be smaller than 1 mm). In the city of Helsinki there is a scale model of the solar system that spans several klometers across, with Saturn quite near to where I work. It is smaller than a golf ball, if I remember right, so even in that scale some planets will be about pea size...
            Anssi
              seanheadrick
              I appreciate your responses. I am preparing some models to show some teachers how SU might be used in the classroom to teach and engage students. I agree with the comments about the size of the model and how it is hard to view anyway. I think notations that relate the size of the solar system to things students can relate to would probably be more effective.
              Sean
