    ⚠️ Important | Libfredo 15.6a introduces important bugfixes for Fredo's Extensions Update
    Importing pencil drawing
    8 Posts 5 Posters 898 Views 5 Watching
      barry gray
      Hi Gang, newbee here,
      I have a PDF of a 24"x36" architectural drawing. If I open in Photoshop or Illustrator and zoom in it's fine/clear. When imported to SU, I zoom in far enough to be able to see the detail well enough for tracing, the resolution goes to hell and it's unusable.
      What do I need to know before I pay to have a future job scanned?
      Thanks for any insight!
        remus
        SU can only handle textures that are 1024x1024.
        As a workaround you can split the image up in photoshop and then import the sections in to SU and join them up.
          Hi Barry,
          What you need to know first of all is that SU (because it uses OpenGL) can only handle 1024pixel wide/high images. So if you import any raster image bigger than that it will be "rescaled" automatically.
          PDF can be vector based however,so if you can get that and use any of your applications to export dxf/dwg, you can import that into SU as vectors.
          Another "workaround" is to chop up your image files into pieces and import them into SU so that you "join" them here.
          Or the best way would be to draw from sketch if you can get a dimensioned drawing. That would be the most precise.
            barry gray
            Thanks Guys,
            I opened in Photoshop, cropped out the extraneous stuff, down sampled to 1024px max.,imported to SU, all is well! Now I can easily trace it.
            Much Thanks
            • kenK Offline
              ken
              I use this program to trace difficult images. It also save in a vector format.
              Note, not free but also not expensive.
              Page not found
              Oops! The page you're looking for isn't available. Check the URL or return to the Iconico homepage
              (www.iconico.com)
              Ken
                mut
                i use qcad for this kinda thing, then save as dxf and import to sketchup
                http://www.StairBox.com We make stairs... easy
                  barry gray
                  Thanks Ken,
                  Windows only, I'm on a Mac. Oh well, looks good though.
                    barry gray
                    Mut,
                    I'll keep that one in mind.
