    [Obsolete] F-Spline (extension to BezierSpline)
    20 Posts 12 Posters 5.2k Views 12 Watching
      Matt666
      Another cool tool, Fredo !! Thank you !
      Frenglish at its best !
      My scripts
      • fredo6F
        Actually, you just need to download the bezierspline plugin, which is now on Crai Depot (with full doc included). It will automatically detect the sub-plugins that are present and load them.
        But you are right. Since the original post has been lost, it may be useful to re-publish it on the forum.
        • CadFatherC
          CadFather
          Thank you Fredo
          icons updated (packs also)..
          Fredo, if you do put your hands back into BZ_ please tweak the icons menu so we can have both 16 and 24 pngs (like TOS)
          Cheers
          16.rar
          24.rar
            Suman
            hanks for your works! ๐Ÿ‘
            • urgenU
              urgen
              ...thanks! ๐Ÿ‘
              --pupil forever...------
              • kenK
                ken
                Now I am confused. Could there be one place I could get all the current scripts and icons. Right now, I am not sure what to save, what to get rid of. So as of right now, my draw menu has many entries for drawing or ediiting curves.
                Thanks in advance for you help and scripts
                Ken
                  With all these new tools curves that is easy to have a start smoothing closed lines for the Soap Skin Bubble plug!
                  And if you deform it after with the Free Form Deformation plug that's infinite world of strange forms who is opened ๐Ÿ˜ฎ
                  Incidentally you can make some hull for boats or planes ๐Ÿ’š
                  • P
                    psychomuffin
                    I have a question that not really for this F-spline specifically, but for splines or beziers in general. I don't know anything about these other than that I like how rounded out they make geometry.
                    What I am wondering is if these spline or beziers can be used to smooth out non-coplaner lines.
                    An example of the application I have in mind (that I completly made up on the spot) is if, say, I want to make a cable that runs off a ledge, down to the ground, and is coiled up. I'd use lines to rough it in, then bezier it, then follow that up with a circle and follow me or something. Clearly, this is non-coplaner. Is that possible? (I don't know that math involved behind these) Or is there a better way to make that.
                    BTW, for those who wanted the rest of the plugin:
                    Link to archive:
                    http://www.crai.archi.fr/RubyLibraryDepot/Ruby/en_edi_page.htm
                    link to zip:
                    http://www.crai.archi.fr/RubyLibraryDepot/Ruby/Bezierspline.zip
                    • plot-parisP
                      plot-paris
                      psychomuffin, yes, you can create non-coplanar splines with fredo's tool. I was delighted to discover that.
                      the bezier tools automatically draw a curve on a plane defined by the first three control points drawn. but if you want to move them in the third axis (if you want to match the control points with certain points in your model for example) simply press the Ctrl button. the little rectange frame on the tip of your curser will suddenly become solid black, indicating, that you can move the point in all directions.
                      I discovered that, if you don't have points you can snap to, it makes sense to draw the curve in 2D first and later manipulate the points by moving them up vertically (after you "freed" the control vertexes by pressing Ctrl, press the up-arrow key to lock the movement to vertical).
                      another method would be to create the rough curve with simple lines first, then use the weld ruby to connect them to one continious form. now you right-click it and make it to one of fredo's polylines. and finally you transform this polyline to a bezier-curve of your choice (again with right click)
                      • fredo6F
                        @cadfather said:
                        Thank you Fredo
                        Cheers
                        CadFather,
                        Could you publish the icons in a Zip archive. I will re-release the whole Bezierspline pack later this week, with all extensons and your icons (respecting the convention _16 and _24). I am not able to decode RAR files actually.
                        Thanks very much
                        • CadFatherC
                          CadFather
                          my pleasure Fredo
                          Bezier Icons.zip
